Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Kenmore 9661 oven not maintaining proper temperature
What could be causing this problem?
  • 163 Answers
HIIYou seem to have a problem with your oven probe sensor change that and you should be fine..good luck..
Posted on Jan 05, 2009
Kenmore gas oven 790.78804501 takes an hour to get to 400 degrees
When my oven would not maintain the proper temperature, the thermostat was replaced.
Jul 02, 2016 | Kenmore Ovens
Calibrate everstar wine cooler display
There is no calibration. You can adjust the thermostat to get the proper temperature. If you cannot maintain proper temperature using the thermostat, several different problems can cause the same symptom. Refrigerant leak, defective thermostat and txv are some problems that can cause lack of maintaining proper temperature.
Jun 09, 2014 | Furniture
My oven is not maintaining temperature
check the door gasket is in good condition.if the door is closing fully properly.check the ground level.
Apr 13, 2014 | Frigidaire Ovens
I have a hotpoint gas oven the will preheat , but not maintain temperature
That pretty much sounds like a weak igniter thats causing your troubles, while the igniter first comes on to preheat the oven its seems to be ok,yet once it has been on for a while the igniter is getting weak and not allowing the gas to flow properly once its hot. By replacing the igniter the oven will maintain tempature.
GENE
Sep 28, 2011 | Kitchen Ranges
Model # 36275621302 stove not maintaining proper temperature. Takes long to bake. Broiler comes on ok. Bottom burner gas comes on and ignites in preheat but then the igniter glows hot but the gas doesn't...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Oct 28, 2010 | Kenmore Ovens
Oven gets up to correct temperature but sometimes fails to maintain temperature. [does not re-light sometimes] sears kenmore model #362.75621300
sounds as if your bake igniotr has gone , or is going bad, if you remove the lower tra in oven cavity it will expose the "glow coil ignitor" after removing the power source you can unscrew and remove the ignitor form the burner bar and bring to local repair company for replacement ignitor, 50-90 bucks depending on which part it is, essy enought repair
Oct 13, 2010 | Kenmore Ovens
Kenmore Electric range does not maintain temperature setpoint.
How do you know the thermo sensor is working correctly when it gets hot?. No I think the thermal sensor is defective, it is cheap to buy.
May 04, 2017 | Kenmore Ovens
Kenmore SF367.....Contantly relighting during cooking?
This is a normal function of your gas range. I own a similar model and it operates the same way. The gas is not required to be on continuously to maintain the oven temperature and will relight periodically when the internal temperature drops below the prescribed set level.
Jul 04, 2009 | Whirlpool SF367 Gas Kitchen Range
Oven doesn't maintain temperature
When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
121 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
