Question about Maxi-Cosi Familyfix Base Isofix only
I have Broken the handle on isofix base which releases the seat. Where can I take it to get it fixed?
  • Maxi-Cosi Master
  • 1,629 Answers
Hi
If you're in the UK and the product is under 2 years old, please contact your retailer with your proof of purchase and they can arrange for it to be sent to our engineers for inspection / repair work required under warranty.
If you're in the UK and the product is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to discuss booking it in for chargeable inspection / repair work required.
If you're outside the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab on the right side for your enquiry to be sent through to the customer care team in your country.
Posted on Feb 17, 2013
Bruce Boogie
  • 242 Answers
SOURCE: We have a cabriofix car seat on a family fix base
Get back to where you bought it for a replacement - these things HAVE to work perfectly to keep your child safe - don't try to "fix" it you could live to regret it.
PLAY SAFE
Posted on Mar 13, 2011
  • 419 Answers
SOURCE: Hi, weare missing the bars that fit under the
If you purchased the carseat without the bars, then this is a Cabrio and not a CabrioFix carseat, and nothing can be done to adapt this to become a CabrioFix.
I hope this helps.
Posted on Sep 15, 2009
  • 419 Answers
SOURCE: what's the difference between Easybase (non
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
Posted on Oct 12, 2009
pan_stak
  • 182 Answers
SOURCE: how do you remove the isofix base from the car
Every ISOFIX base has a button which you can press and release the base from the car seat.
Usually it's a round one at the junction of the ISOFIX base and it's LEG
Posted on Jul 29, 2011
Dorel UK
  • 1629 Answers
SOURCE: how do you release the support leg of the
Hi Emer,
On the support leg there is an area of grey plastic with grip-friendly texture. Grab hold of the support leg using this section and squeeze - there is a button either side of the support leg that you will depress by squeezing this grey section which will release the support leg.
Posted on Oct 12, 2011
How do I remove the Bambino Elite Isofix car seat from my car?
I had exactly this problem! First I could not find my user manual, but luckily Bambino provides it online. Then you discover that removing the seat is not covered in the manual... (Bambino, take note!)
I eventually figured it out (the items in bold are mentioned in the manual):
- Remove the top tether (the strap that goes over the top of the seatback and clips in behind the seat).
- Rotate the adjuster buttons (2 knobs, one on each side of the car seat near the bottom) anti-clockwise so that the ISOFIX anchors can extend. The seat will now be loose but still clipped in.
- Pull both release buttons (small sliding catches on the ISOFIX anchors, close to the red+green indicator) towards the front of the seat so that the ISOFIX indicators turn red. The seat should now be free!
Sep 18, 2014 | Baby Gear
My family fix isofix base will not release the maxi cosi car seat We pull the lever and it doesn't release the car seat Is the unit broken or can it be fixed If so how can I fix it Or if it is broken is...
Hi Melanie
To override release the carseat from the base, use a pair of long nosed pliers to reach the wires that are inside the base. They can be accessed underneath the grey button on the base. Pull the wires toward you and the carseat can be lifted from the base.
This is an issue with the base, not the carseat, so the base needs to be sent in for inspection and repair required. Please contact the customer care team for further assistance. 87985515-e848-4733-8df0-f4baae5e6226.jpg
Jan 15, 2014 | Baby Gear
How to remove the isofix base from the car seat
Hi
Is it removing the carseat from the base or removing the base from the car that you're having difficulties with?
Feb 03, 2013 | Maxi-Cosi Familyfix Base Isofix only
Maxi-Cosi Familyfix base Isofix base warning beep
Yep, there's a switch underneath to turn off the sound, but the lights will still work.
Jan 31, 2013 | Maxi-Cosi Familyfix Base Isofix only
How do I release the maxi Cosy cabrio from the family fix isofix
Press the button on the front of the FamilyFix base and it will release the carseat.
Mar 16, 2012 | Maxi-Cosi Baby Gear
I have the isofix easy fix base. It will not come out of the car. We press in button in and pull and it does not move at all. It's almost like the locking mechanism has jammed. Any suggestions?
Good Afternoon
On either side of the EasyFix base you will see a small square opening with the yellow IsoFix point showing through it. Take a flat head screwdriver and slide into this hole facing toward the front of the car and gently push the screwdriver handle so it ends up facing the rear of the car - this should unlock the IsoFix mechanism. You'll need to do it on both sides if both sides are stuck.
If this doesn't work, or once you have done this, take the base back to your retailer with your proof of purchase if it is under 2 years old and they will be able to assist.
Aug 14, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How do you remove the isofix base from the car seat?
Jul 29, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
Sep 25, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
What's the difference between Easybase (non isofix) and Easyfix base (isofix)? can I use the second one for both maxi cosi cabriofix and car seat up to 3.5 year?
I hope this helps.
Sep 25, 2009 | Maxi-Cosi Baby Gear
Maxi-Cosi Familyfix Base Isofix only Logo
2,398 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
