Question about D-Link Computers & Internet
Enable WMM in DLink interface - D-Link Computers & Internet
  • 2,878 Answers
You may be referring Virtual Servers under Advance. This will allow specific apps access via specific ports. There is also a similar application setting tab. Again in Advance.
Posted on Nov 07, 2012
What Is the Difference Between the WMM Mandatory Switch and WMM Function Switch?
The WMM function switch controls the entire WMM function of an AP. The entire WMM function includes the WMM mandatory switch and EDCA parameter.
The WMM mandatory switch controls whether the terminals that do not support WMM can connect to a WMM-support AP.
http://www.thunder-link.com/S9700-SWITCH_c157.html
Oct 19, 2016 | Computers & Internet
How to Enable WMM in DLink interface
If your hardware supports WMM (wi-fi media), the box to enable/disable the feature is on the Advanced Wireless page. Click on that in the left column of the D-Link router page. Then click on the Advanced tab. Check the box to enable the WMM feature; it's the third from the bottom.
The next step is to make sure that the WMM feature is enabled on your other hardware. This may be partially enabled in the Wireless driver. (Go to the device manager to check this driver. The Ad Hoc QoS Mode under the Advanced tab lists WMM for some wireless networks.) However, you may also need to enable the QoS Packet Scheduler in the Wireless Network Connection Properties (general settings tab).
What OS is your computer running? What type of wireless adapter is in your computer? If you add a comment with that information, I can provide additional information for modifying the network settings.
I hope this helps.
Nov 07, 2012 | D-Link Computers & Internet
How to enable wireless multimedia
Got this from Apple website:
his applies only to third-party routers. Apple AirPort products do not have a setting to enable or disable WMM.
WMM must be enabled for devices to connect. Disabling WMM on your wireless router can prevent the following Apple products from connecting to an 802.11n Wi-Fi network:
  • iPad
  • iPhone
  • iPod touch
  • Apple TV
If you are unable to connect to an 802.11n Wi-Fi network on any of these devices, check to ensure that WMM is enabled and configured correctly on your wireless router. If you require additional assistance, please contact your router manufacturer.
Jan 28, 2012 | D-Link Computers & Internet
Lost my security key for dlink
Open router admin interface , click on Besic/Status. There you can have the security key..
Thanks and regards.
Sep 04, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I have Dlink DSL-2640T. I cannot signin Nimbuzz. Please advice...
First change the interface ip of Dlink and then try to connect
Dec 12, 2009 | Computers & Internet
Asus A626 WiFi
I fixed my problem with my D-Link DIR-625 router by going and changing a couple of things. I'm not sure which one did it, but this is what I changed:
1. Under the advanced tab turn off 'Wi-Fi Protected Setup'
2. Under the advanced tab - Advanced Wireless option:
Advanced Wireless Settings Transmit Power : High Medium Low
Beacon Period : (20..1000)
RTS Threshold : (0..2347)
Fragmentation Threshold : (256..2346)
DTIM Interval : (1..255)
802.11d Enable :
WLAN Partition :
WMM Enable :
Aggregation Limit : 8 Kbytes 16 Kbytes 32 Kbytes 64 Kbytes
TPC Max Gain : (0..50)
Aggregation Max Size : (2000..65535)
Aggregation Num Packets : (1..64)
Force Short Slot for 11N Clients :
Short GI :
Dec 11, 2008 | ASUS MyPal A626
Wireless connection keeps dropping after about a day.
I had the same problem (see Jan 09) but I found the solution:
I had trouble with the router resetting from time to time, that was fixed by upgrading to firmware 1.05. But I still had the wireless problem.
For me, disabling 'UPnP' (advanced->advanced network) and disabling turbo G mode (setup->wireless setting) did the trick.
Work great since then, both my laptop and my media center stays connected, going on one month now.
Hope it can helps other.
Nov 25, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Using just the VOIP part of a Belkin all in one router??
You will probably need to set it up differently, I do not know the belking router, but normally the VOIP functions only work on the wan port of these routers so you should make the connections as follows:
INET ---> (wan) DLINK (lan) -----> (wan) BELKIN (voip) --> Phone
|--------> Wired Computers
|--- ) ) ) Wi Fi computers
On the DLINK enable DHCP and set a fixed IP for the Belkin router, either by setting the belkin in an IP outside the DHCP pool or setting it from the DHCP server.
This configuration workd well with a DLINK and a Motorola (vonage) router I have.
Apr 23, 2008 | Computers & Internet
Computers & Internet Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
