Question about Mossberg Sport & Outdoor - Others
Broken forearm on a mossberg 535 shotgun
After shooting the shotgun i went to pump out the old shell and load the new one the forearm just slid and does not engage anything. when i took it apart some pieces of the synthetic forearm fell out. i cant find a replacement forearm anywhere. help! please!
  • 243 Answers
I'd be amazed if Mossberg didn't have one available. Give them a call.
Posted on Apr 20, 2014
    Habit-Forming:
  • 143 Answers
It's a common part. The Mossberg 500 forearm is the same type. Yours is a pinned version identical to a Maverisk 88 forearm. Any Mossy 500 "slide action tube" or a pinned Maverick 88 forearm will fit it perfectly.
Posted on Sep 03, 2016
  • 43 Answers
SOURCE: Have I possibly damaged my Browning 16 gauge
Europe loads 2 1/2" and 2 3/4" shells for 16 gauge shotgun as standard and the US only loads 2 3/4" shells. If your shotgun chambers the 2 3/4" shells it should be OK. You can measure the chamber and see if it measures 2 3/4". You can also check your barrel for and bulges in it by looking down the barrel with a bore light shinning down the other end. A bulge should be able to be seen with the eye. If your gun has any bulge, do not fire it again. You will need a new barrel. But It should be OK and I would not expect their to be any bulges.
Posted on Nov 14, 2009
Testimonial: "I goofed my 1st try so here goes again. Advice was very helpful to a neophyte; knowledgeable, understandable & timely---Thanks a bunch! KW "
SOURCE: cant get forearm stock off mossberg 12ga 88, not like other mossb
a gunsmith told me it was a complicated solution for someone not knowledgeable in shotguns on this particular model. this answer i believe was backed up by a friend with 20 years of firearms experience who explained to me a complicated series of step that might work..
Posted on Dec 30, 2009
SOURCE: mossberg 500,12 ga. shells will not feed
this is Richard, what did you find.??? ktoffour@msn.com
Posted on May 27, 2010
ZJLimited
  • 17970 Answers
SOURCE: I never got an answer to my original question
This site has no specialists in the area that you need answers (weapons). If your delaer cannot offers details about this "bugs", try to find addition al information in the guns forums: thefirearmsforum.com/showthread.
Hope helps and good luck.
Posted on Jan 14, 2011
  • 220 Answers
SOURCE: Mossberg 500 20 ga shotgun
Poke it out with a clothes hanger...or a thin poker.
Posted on Apr 21, 2011
Just bought an 835 pump foerarm loose and wobbles is that normal ita a 12 gauge mag
assume this is a Mossberg. All pump shotgun forearms wobble from side to side and feel loose. As long as it functions properly (loads and ejects shells), nothing is wrong.
Nov 23, 2016 | Cars & Trucks
How do you load a mossberg 88 maverick 12 gauge shotgun ?
this is the same for your maverick 88.
Sep 14, 2014 | Optics
Mossberg model 88 manual
Yep. The back end of a Mav 88 is identical to the Mossy 500. Same gun, after all. The front end, forearm is the only real diff accessory-wise. You'd need to buy a Mossy action tube (the forearm steel) to put a forearm on your Mav. Stock, yes....forearm, no.
May 17, 2013 | Optics
Mossberg 500, shell will not eject
did you check the elevator to make sure its not applying the pressure on the cartridge interrupter and cartridge stop? or that one or both aren't damaged and over bent. the ejector slot on the bolt isn't damaged, or the action slide bars.
Dec 28, 2012 | Mossberg 500 AllPurpose Field Shotgun 20...
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
Feb 02, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
What is the difference between a Mossberg 500 and a Mossberg 535 max 4.
The 535 is simply a slightly stretched model 500. It can chamber and fire 3.5" shells where the 500 will only handle up to 3" shells. The guns are identical in function and pretty much identical in parts except the stretched bits.
Nov 26, 2010 | Mossberg Sport & Outdoor - Others
How do you load a 12 gauge pump action Mossberg (500)? There is no magazine for it, but, is mag ready. How do you manually load?
The loading port is on the bottom of the reciever. You mention that it is "magazine ready"? Mossberg shotguns have a tublular magazine underneath the barrel, surrounded by the action bar and front grip.
Loading the magazine entails holding the shotgun in one hand, taking the shell in the other with the folded end facing the front end of the barrel. Place the shell in the magazine opening (on the bottom) and push it up with your fingers and forward with the thumb of the same hand. It will go completely forward of the silver/blue lifter and stay there when you let go. (the action must be closed to load the magazine).
Alternately, you can open the action and pop a shell into the ejection port on the right side, close it back up, and shoot!
Sep 17, 2010 | Mossberg Optics
Hello, does the mosberg 1000 super 12 semiauto shotgun shot both 2 3/4 and 3 inch shells ? It show that it is chambered for 3".
A shotgun will shoot anything shorter than the max length specified. The only problem you may have is lightly loaded smaller shells may not cycle your gun. Most 3" magnum semi autos will cycle 2 3/4 inch shells just fine.
Aug 08, 2010 | Mossberg Sport & Outdoor - Others
Cant get forearm stock off mossberg 12ga 88, not like other mossb
Dec 27, 2009 | Sport & Outdoor - Others
Remington 1100 12 gage won't load a shell from the magazine
Are you shooting very light load?
Have you tried different ammo?
Light loads may not produce enough energy to work the action properly.
If different ammo doesn't help, make sure the two holes inside the barrel ring are clean and gas from the barrel can pass through. Next I would check the o-ring for cracks. If you shoot lots of shells (competition clays) the recoil springs inside the stock or over the magazine tube may have become weak and need replacing.
Jan 12, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Sport & Outdoor - Others Logo
245 people viewed this question
Top Mossberg Sport & Outdoor - Others Experts
Colin Stickland
Colin Stickland
vgrechniw
vgrechniw
Level 1 Expert
RichardL
RichardL
Are you a Mossberg Sport and Outdoor - Other Expert? Answer questions, earn points and help others
