Question about Palm LifeDrive Mobile Manager Handheld
Dead LifeDrive The microdrive died in my Lifedrive. With the dead drive it would boot to the PalmOne screen and stop. I replaced the drive and now when I plug it in to charge it will charge for a while then start to boot (on its own), and stop at the PalmOne screen. The replacement drive was purchased on eBay from someone who upgraded to a CF in his LD. I don't believe the current problem is the hard drive. Could it be the battery or is it the motherboard or something I won't be able to fix easily? Any guesses?
  • Anonymous Nov 15, 2007
    ld wont power up no sign of life
  • 1,606 Answers
I would guess you bought a dud micro drive or its been cleaned off. You could try a hard reset and see if it fixes itself. Perhaps the fellow cleaned off his information but hopefully he left the restore partition alone. You can rebuild that if you extract the files from the 2.0 upgrade and so on. There are a few tutorials on how and what to do on some of the hardcore LD sites.
Hopefully you didn't harm the board itself with a static discharge. I've seen a few guys do the swap and end up with a dead LD but usually they don't see anything at all.
Posted on Jul 09, 2009
Lifedrive won't start. Neither will it reset,
Unfortunetly that usually indicates the harddrive has failed on you. Try a power on hard reset. It is the same as the hard reset but the power need to be plugged in as well.
If you look there are several places that will replace the drive with either a new drive of a compact flash card. The card is the way to go as it increases battery life but is about 10x faster acessing stuff.
Dec 13, 2009 | Palm LifeDrive Mobile Manager Handheld
Palm lifedrive wont' boot stuck on palm screen
This sounds like the issue where the LifeDrive is stuck in a loop. You can see how to break the device out of the system loop on the Palm Knowledge Base article (26419) located HERE.
Hope that helps get you up and running again!
Sep 12, 2009 | Palm LifeDrive Mobile Manager Handheld
When the lifedrive dies duo harddisk, there are
You have two options one is of course a replacement drive but the other is replacing the little hard drive with a flash disk. The flash drive is nothing more than a 4gb compact flash memory card that happens to use the same connector as the Hitachi hard drive. Of the two I'd go flash myself.
The flash disk is faster and uses far less power so your battery life can increase by quite a bit. I think it is something like 10% of the power. Next to the display this is the single biggest power item. I've heard of the useful battery life increasing anywhere from 3x to about 6x after doing this. You can get the drive or flash from several places online. These are the same CF cards as used in many cameras. Most also offer the installation service.
Here is a link to one place but do a few searches and compare prices etc. Just search for lifedrive, flash, drive or lifedrive hard drive replacement and you should get quite a few.
http://www.usedpdaparts.com/Lifedrive.html
Jul 12, 2009 | Palm LifeDrive Handheld
My lifedrive when plugged in comes up with the logo (palmone) however the screen will not change. Ive tried a soft reset and a hardreset does anyone have any suggestions. I have used this very little....
Unfortunetly that is typical of the internal microdrive having died on you. If the hard reset doesn nothing then that is most likely your problem.
You can replace the microdrive but if you want to improve your LD you can get it changed to use a compact flash disk such as a SanDisk 4gb card. It will run much faster and for longer. This is a simple thing to replace either but given the choice I'd go with the CF. There are several place that will repair your LD for you if you don't want to fix it yourself. You should end up spendingunder $100
Jul 07, 2009 | Palm LifeDrive Handheld
Lifedrive wifi
Does the wifi work at all after it resets? Have you applied the level 2 palm srvice pack to the LD? I believe the update changes how the wifi operates. If you go to www.palmone.com and go to the lifedrive page you should see a list of downloads for it. If you click on the 2.0 update there is a description of how to tell if you need this or if it is already installed. You just need to check the version of one file. Download and install the patch and see if that fixes everythng.
If that doesn't fix it you may have a more serious problem that could require replaceing or fixing the LD
Oct 27, 2008 | Palm LifeDrive Mobile Manager Handheld
Lifedrive sick
Try a hard reset and if that doesn't work ( the erase program hangs up), then your hard drive is dead and must be replaced.
Nov 10, 2007 | Palm LifeDrive Mobile Manager Handheld
My Lifedrive won't boot up
Seems the LifeDrive Micro Drive is the killer on these Palms. Mine did the same thing and after extensive online research I found that the micro drive can be replaced with a Compact Flash card which is much more reliable. Apparently there are only certain CF cards that work with the LifeDrive though. I have found at least one retailer that sells a compatible CF preloaded with the Lifedrive software. The route I took for repair was to send it out to a guy that advertises his service on eBay. You send in the LifeDrive, he diagnoses it for $5, and can install the CF card with software for $89 (he waives the $5 if you have him fix it). I am looking forward to getting mine back in permanent working order! Here is the link:
http://myworld.ebay.com/itsnothere/
Oct 14, 2007 | Palm LifeDrive Mobile Manager Handheld
Dead Harddrive
YOU NEED TO BUY A NEW ONE SOUNDS LIKE THE ACTUAL THING HAS BLOWN
Apr 13, 2007 | Palm LifeDrive Mobile Manager Handheld
Dead; will not boot up
I to have the same problem. Palm will switch a refurbished on to me for $175. To talk ot their tech support will cost $25. I have decided to do 1 of 2 things. 1. replace the microdrive with a 4Gb Compact flash and if that is not successful, just throw it away and NEVER get another Palm product. Mine died just after the warranty ran out. 12 months plus a few days.
Sep 10, 2006 | Palm LifeDrive Mobile Manager Handheld
Dead Lifedrive
I im not mistaking this unit has a 1 year warrantee. I would contact the #v below to see how to get this back up and alive. Good luck 847-262-PALM
Apr 15, 2006 | Palm LifeDrive Mobile Manager Handheld
Palm LifeDrive Mobile Manager Handheld Logo
248 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
