Question about Vacuums
Shark Steam and Mop Vac - Model MV2010- My shark is heating up but not steaming. What could be the problem?
Solution number 2 works. however, you don't have to take it apart, the base plate has a steam hole in the center, just clean out with a paper clip. watch out for the residual steam, it actually helps clean out the mineral deposits
Posted on Feb 17, 2013
SOURCE: My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Posted on Feb 06, 2009
heatman101
  • 43501 Answers
SOURCE: shark steam mop does not create steam. 7 mos old
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
a
Posted on Sep 26, 2010
SOURCE: shark steam mop model 3101
Here is the webite to purchase the carpet attachment for your steam mop.
http://www.fixya.com/support/t704954-shark_steam_mop_model_3101
Before you buy the carpet attachment, you might want to read this review. I found it very helpful because I couldn't find much on how it works on your carpet or any reviews on the attachment. Her comments were all positive.
here is the link:
http://www.epinions.com/content_425654455940
Posted on Sep 17, 2008
satch498
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Posted on Jun 30, 2009
SOURCE: My Europro shark steam mop won't steam, light on but no steam.
Hard water deposits. I ran some white vinegar through mine, like a coffee maker, and it worked for a while, but clogged again. So I unplugged it, let it cool and turned it over in the bathtub and squirted a small amount of Lime-Away into the hole where the steam comes out. Let it soak for 5- 10 minutes and it is working like is is brand new.
Posted on Oct 10, 2009
My shark vac and steam model mv 2010 pump wont come on help?
If your not using distilled water the machine is probably loaded with mineral deposits from hard water and is plugged. you can try running some vinegar through it which may or may not work depending how plugged it is.
Oct 22, 2013 | Shark Vac Then Steam Mop MV2010 NEW
Shark 2-in-1 Vac Then Steam
Steam frame and pad
must be attached to the cleaning unit
in order to use the steam function
manual > http://www.sharkclean.com/manual/MV2010_11_IB_ENG_110103.pdf
Apr 15, 2013 | Shark MV2010 Vac-Then-Steam 2-in-1 Vacuum...
My shark vac then steam will not steam anymore and I am doing everything right. How do I fix this problem?
im not familiar with that brand but i am an electrician and vac tech. i would if i were you i would check and make sure the heating element had power at its connection. if there is power replace the heating element. plenty of online vac parts stores have schematics along with a parts list to help you locate part in vacuum.
Feb 13, 2013 | Shark MV2010 Vac-Then-Steam 2-in-1 Vacuum...
Vacuums Logo
929 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
