Question about Ingram GMS90904CXA Heater
I have a Goodman Heater model number GMS90904CXA and the fan is making a loud noise. I'd like to replace the fan and motor but don't know model # of the motor and fan???
  • dwkcool May 11, 2010
    if you are going to replace both you need to go to a Goodman dealer and all you need is the model and serial# off of the unit
    Problem Solver:
  • 13 Answers
The motor will have a horsepower and rpm on it. pull it out and take down to a local parts warehouse they will have a replacement
Posted on May 16, 2009
  • smith7881 May 16, 2009
    Pull the motor and take it down to the local parts supplier they will help with a replacement
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
What 39 s your problem Goodman gas heater the fan is loud and makes a clunking noise
Check the fan wheel to see if something got "sucked" in.Ex.paper or insulation. If wheel is clear but looks bent do NOT bend it back, it should be replaced to spin TRUE
Oct 28, 2011 | Goodman GMS90703BXA Heater
I turn the thermastat to heat on my goodman gms90904cxa and the inducer fan does not come on and after a couple of seconds the lights blink 3 times
Hello, a 3 blink pattern indicates a open limit switch. Most of the time a dirty filter, dirty blower wheel, weak blower motor, can cause the limit switch to open.
Oct 02, 2011 | Goodman Heating & Cooling
Our Goodman furnace just started making a a very loud grinding noise when the furnace turns on. Also the temperature in the house keeps dropping so we have to keep adjusting teh thermostat. Any advice on...
If it makes the noise before the blower comes on it would be the exhaust fan. If it makes the noise when the blower comes on then I would say either the blower motor or bearings to the fan.
Dec 27, 2010 | Goodman GMS90703BXA Heater
I have a Goodman 3 ton 70,000 BTU gas furnace that has started making a rattling noise from a small fan with a 1/4 " rubber hose leading away from it. I was told that it has something to do with...
its the fan which takes the fumes up the flue its the combustion fan the hose goes to the pressure switch you will need make ,model, serial number of heater btu input , you can replace this your self just swop like for like , try looking on line for a price .
Dec 06, 2010 | Goodman GMS90703BXA Heater
GMS90904CXA IR Blower continues to run after it
it sounds like the fan control switch is not shuutting off when it cools down look at the fan diff settingson the fan control you may be able to adjust this
Feb 03, 2010 | Goodman GMS90703BXA Heater
My heater on my goodman heatpump/air conditioner fan don't come on and it make a loud noise
Compressor will make a sound as refrigerant pressure builds. Could be a few things wrong. With breaker off!!! Check first see if you can spin fan blade outside if moves freely it is okay. If Hard to move Fan motor Bad. Next check what they call duel capacitor remove out side panel it look like these. Top of these should be flat, if it has a bulge on the top capacitor has failed has 3 or 4 leads on it usual 6ca8bc8.jpg
Dec 02, 2009 | Goodman GMS90703BXA Heater
Furnace gms90904cxa I have 3 blinks what s the
Pressure switch is not working, plugged air intake or exhaust pipe, dirty air filter, debris in condensate hoses, debris in pressure switch hose.
Oct 18, 2009 | Goodman GMS90703BXA Heater
Screehing noise when furnace is running
usuall a schreeching noise during blower opperation is bad berrings which would need to be replaced. Most unit warrentys for newer units cover five year parts and sometimes 10 for heat exchanger. But most do not cover labor. Or the blower may just be off balance and metals are rubbing. eaither way your proubly gonna need a tech. good luck
Mar 17, 2009 | Ingram GMS90904CXA Heater
99 Grand Prix Heater only works on 5 makes a Loud noise
hi there
it sounds to me that you have two problems the
loud noise is the heater motor bushings is worn out causing the loud noise and vibration
also you will have to replace the resistor
once the motor is replace and the resistor replace all should be ok
don
Mar 09, 2009 | 2000 Pontiac Grand Prix
Heating & Cooling Logo
168 people viewed this question
Top Ingram Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Woodburn
Thomas Woodburn
Andy
Are you an Ingram Heating and Cooling Expert? Answer questions, earn points and help others
