Question about Refrigerators
Ice maker gets cold enough to freeze water but water does not remain in trough. How can I cycle the machine manually?
  • wholemkt105 Nov 08, 2012
    Wonderful. Share a website with you , (http://www.wholesalemkt.net/ ) Believe you will love it. We accept any form of payment.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the make and model number of your unit?
Posted on Nov 08, 2012
aborcass
  • 2651 Answers
SOURCE: ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Posted on Mar 06, 2008
  • 12 Answers
SOURCE: Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Posted on Mar 10, 2008
SOURCE: Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Posted on Apr 18, 2008
maklean
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    SOURCE: b195 ice maker not making ice
    the solenoid might have packed it in
    Posted on Oct 27, 2008
    Ice maker Manitowoc QD-0212A
    This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
    Jul 13, 2013 | Kitchen Appliances - Others
    Mine alway,s freeze up and well stop working
    Cleaning should be performed every 6 months. 1. Harvest problems may occur if the following procedures are not preformed every 6 months. 2. Remove the ice machine front panel. 3. Make sure all the ice is off the evaporator. If ice is being made, Wait for cycle completion, then turn the machine "off" at the ICE/OFF/WASH selector switch. 4. Remove or melt all ice in the storage bin. 5. Add recommended amount of NICKEL SAFE ice machine cleaner to the water through according to label instructions on the container. 6. Initiate the wash cycle at the ICE/OFF/WASH switch by placing the switch in the WASH position. Allow the cleaner to circulate for approximately 15 minutes to remove mineral deposits. 7. Depress the PURGE switch and hold until the ice machine cleaner has been flushed down the drain and diluted by fresh incoming water about 15 min. 8. Terminate the wash cycle at the ICE/OFF/WASH switch by placing the switch in the "OFF" position. Remove the splash curtain and inspect the evaporator and water Water spillway to assure all mineral residue has been removed. 9. If necessary, Wipe the evaporator, spillway and other water transport surfaces with a clean soft cloth to remove any remaining residue. If necessary, remove the water distribution tube, disassemble and clean with a bottle brush, Reassemble all components and repeat steps 2 through 7 as required to remove residue. 10. Turn off ice machine water supply and clean the water trough thoroughly to remove all scale or slim build - up. If necessary, remove the water trough to reach all splash areas and float.11. Prepare 11/2 to 2 gallons of approved ( EPA/FDA) sodium hypochloride food grade sanitizer to form a solution with 100 to 200 ppm free chlorine yield. 12. Add enough sanitizer solution to fill the water trough to overflowing and place the ICE/OFF/WASH switch to the WASH position and allow circulation to occur for 10 minutes and inspect all disassembled fittings for leaks. During this time ,Wipe down all other ice machine splash areas,Plus the interior surfaces of the bin, deflector and door with the remaining sanitizing solution. Inspect to insure that all functional parts,fasteners,thermostat bulbs (If used ), etc.are in place. 13. Depress the purge switch and hold until sanitizer has been flushed down the drain. Turn ON the ice machine water supply and continue to purge to the diluted sanitizing solution for another 1 to 2 minutes. 14. Place the ICE/OFF/WASH switch to the "ICE" position and replace the front panel. 15. DISCARD THE FIRST TWO ICE HARVESTS. If this dose not help your problem let me know and we can solve it.
    Dec 15, 2012 | Ice-O-Matic ICEU220HA Undercounter Ice...
    Not making enough ice
    What is the ambient air temperature in the location it is installed??
    Aug 27, 2012 | Ice-O-Matic Ice o matic Iceu220a Cube Ice...
    Whirlpool refriigerator ice maker not working
    With ice makers it is almost always one of two things. The ice maker itself, or the water valve. Figuring out which one is easy, and I will help explain.
    First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
    In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
    If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
    At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
    If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
    If I can be of any further assistance please let me know. good luck!
    Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
    May 29, 2010 | Whirlpool GS5SHAXN Side by Side...
    Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker stopped making ice
    With ice makers it is almost always one of two things. The ice maker itself, or the water valve (valve is located on the backside of the frig, bottom right hand side almost 100% of the time). Figuring out which one is easy, and I will help explain.
    P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker.
    May 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
    Ice maker will not fill with water
    Quick facts: If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
    P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker. However, if you still get water through a dispenser (if you have one) then this cannot be the case.
    May 26, 2010 | Whirlpool Refrigerators
    Hooked up water to frig and got water in door but no water to icemaker. Any ideas?
    Make sure the lever is down on the ice maker . Also , can pour about 2/3 cup of water into ice maker , so it will freeze and start the cycle . Otherwise , wait , and when the ice maker gets cold enough , it will cycle on its on to start the ice making procedure . If you get water to the door , then it's connected properly , and water will go to the ice maker , if the water valve and ice maker are in working order .
    Sep 09, 2009 | Kenmore Refrigerators
    Water freezes in trough that supplies ice maker on side by side. Defrost unit and it functions properly till ice bin fills then ice fills trough terminating ice making. How to correct?
    The trough (fill tube) is freezing up , due to a sloow leak from the water valve . The valve needs replaced . A small piece of debris , dirt , sand , etc , gets between or caught up in the rubber bellows , not letting the valve close completely . This debris will "scratch" the bellows (has to remain smooth) internally , where is will continue to catch debris , so , replaceing the valve (piece that the wall water line connects to ) has to be done . Even dissasembling and cleaning will not remove the scratch inside .
    Aug 22, 2009 | Refrigerators
    Ice Maker inlet tube freezes up.
    Try runnning a manual test of the defrost cycle, could be that you are not getting enough airflow to the frig side, while the frig side is calling for more cold. Becuase the frig side is calling for more cold, and not able to get there it is causing more airflow across the water tube.???
    Aug 16, 2009 | Frigidaire Refrigerators
    ICE MAKER INOP
    Check the water control valve on back and bottom of refrigerator. One side is for the dispenser and the other side is for the ice maker. When the ice maker begins a cycle the thermostat inside the ice maker begins to warm the bottom with a heating element to allow the ice to move freely and then dump into the container beside it. As the cycle reaches its final resting place a limit switch is pressed inside the ice maker to refill with water and start the process again. So if the water valve does not open and the tray remains empty and the ice maker will try to cycle again if the thermostat says that it is cold enough again. Check your model number again and I will try to get you some drawings. The number looks good but can't seem to pull it up. Let me know what you see and find. Try filling the tray with tap water and see if it will cycle after freezing. Thanks, Sea Breeze
    May 20, 2009 | GE Refrigerators
    Refrigerators Logo
    35 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
