Changing brushes on motor of Bosch WFL 2450 washing machine
My Bosch w/machine seems to do everything but spin and someone told me that it may the brushes and I would br gratefull if I could get a bit of advice on how to do it
  • 2 more comments
  • oswaldcutaya Jan 12, 2009
    Yes thank you very much.
  • quercus29 Jan 24, 2009
    hi, so it sounds like i can replace the brushes myself, is that right? where do i get the brushes? also, how can i tell if that is the problem?
    thanks in advance for your help
  • Anonymous Feb 19, 2009
    how do i change the brushes in a bosch classixx 1200 washing machine ??
  • Anonymous Mar 22, 2014
    no power on front
  • Washing Mach... Master
  • 3,463 Answers
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
  • Barry Coates
    Barry Coates Jan 08, 2009
    Did you manage to change motor brushes o/k from the advice I gave?
How to remove *** wire from bosch wfl 2450?
Here you go....
http://www.scribd.com/doc/187416757/Bosch-Maxx-Wfl-2450
Aug 21, 2014 | Bosch Washing Machines
Slow spin
Check the carbon brushes on the motor for wear.
Apr 20, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My bosch classixx 1000 washing machine is not spinning at the end of the wash cycle, and when set to spin it does not spin, what can i do?
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl vote me 'very helpful' for the free help, thnks!
Apr 03, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I want to change the brushes on my bosch washing machine
Some bosch you can buy cabons brush on its own cost £10/£25......Some models you need to fit half motor with brushes located within, cost of parts £60 approx from espares.co.uk
Feb 23, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFD 2473 - wont spin. I've taken out the filter and found a broken washer in it. Can't work out where the washer comes from? Doesn't seem to fit the filter. Having cleaned the filter, washing machine...
Even if the pump is not working, then so long as there is no water in the washer, it should spin
If it does not, then I would suspect the motor brushes are worn out.
You need to remove the motor to check the brushes, if they are less than 2 or 3 mm long then they need replacing.
I do not think the washer you found is off the pump,more likely out of someones pocket.
Hope this helps with your problem.
Dec 02, 2009 | Bosch WFL 2063 Front Load Washer
F05 Fault code
this will be the motor brushes
Jul 07, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Won't spin
The most obvious thing that comes to mind is that the brushes need replacing in the motor
You will have remove the motor to check them.
The brushes are located at the rear end of the motor, you will see the wires going to them
Plz rate this solution.
Thanks.
Dec 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washer fills and will drain but not wash.
i remember click is the motor relay engaging.
reason for no rotation may be the motor brushes.
take back panel off, disconnect motor elec plug, undo fixing bolts and withdraw motor and you can then check brushes. also check condition of commutator - series of copper segments brushes run on
Sep 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Jun 01, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Wont spin, and arcs.
2 bruhes in motor
replace motor brushes
use correct brushes from bosch
Oct 09, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
1,932 people viewed this question
Top Washing Machines Experts
