Frigidaire electric furnace blows units circuit braker
Model b3bm036kb
2 Suggested Answers
  • 4339 Answers
SOURCE: We have a 1999 "Thermal
DO NOT install a 20 amp breaker, you can cause a fire. The breaker is rated for the WIRES, and unless you change out the wires, the 15 amp wires will overheat and can cause a fire.
Typically, A/C units need dedicated power, with nothing else on that circuit.
One step that you may try is a new 15 amp breaker. Once a breaker starts tripping, is starts tripping earlier....
You may wind up running a new circuit for the A/C, if you do, size it for the A/C.
Posted on Jul 18, 2011
FURNACE WILL NOT CUT OFF WITH THERMO PULL BRAKER THEN REINSERT BRAKER FURNICE WILL STAY OFF UNTIL THE THERMO IS RESET SAME THING HAPPENS AGAIN .WHAT PART IS BAD
If you have a programmable thermostat do the batteries need replacing? Test and re-insert. While there check for any loose wires on it, or at the furnace circuit board. Also make sure none of the wires are touching and metal parts and getting chaffed or shorted. If they are the shot will keep the unit from shutting off and/or cause short cycling.
Mar 01, 2015 | Intertherm 56000 Btu Gas Furnace
Electric furnace coleman model # 3120A751. It won't shut off on its own. Just keeps blowing hot air any ideas?
something is wrong in the 24v. make sure no wires touching each other both behind the tstat and on the circuit board in the furnace.
and obviously r to red w to white y to yellow.....
Jan 27, 2015 | Coleman Heating & Cooling
How do i fix my proseries water pump
unplugging it while it was runnong shouldn't damage it, probably just the circuit braker. check to see if there is a button or some type of circuit braker on the unit and reset it, if it does not have one check the circuit braker that supplies it power. (in your braker box)
Jun 23, 2014 | Pool & Spa
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
I have a frigidaire model fef364dsa and it blew circuit braker and now beeps and flashes f 11
F11 is for the clock/timer board error and will need to be replaced. Here is the part to order.
Be sure the unit is unplugged before replacing the part!
Also, take note of the wire harness connections.
Nov 05, 2012 | Frigidaire Ovens
Keeps blowing the brakers model #MWG9115SL
DONT USE IT!
There is an obvious short circuit in the unit. I am surprised you would persist in giving yourself the stress over such a unit as well as risking a fire outbreak in the unit.
Repairing microwaves is just not economically viable, you can pick up a refurbished one or a good working second hand one for about $50-100 A repair is about $200-300 with labor.
Dump it, but first cut off the power cord so some other poor soul doesnt think they found a baragain on the tip.
Please rate my help++++Thanks for using FIXYA
Nov 22, 2009 | Microwave Ovens
Circuit Braker Jumps Off
You probably have a burnt out element. They almost always short out when they burn out. If it is a coil unit it may be visible. A smooth top unit can't be diagnosed without removing the top glass. Most of the time you can do this yourself. Sometimes when a burner goes it will ruin the switch also.
Mar 29, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Oven door won't unlock
kittyboy The first step I would recommend you to do is to turn the circuit breaker on, then set up the oven clock. Start the self clean for any amount of time, wait about 30 seconds and push the cancel button. Most of the time it helps to eliminate the problem. If it would not help, let me know and we will go further. In that case I will need the complete model number. If it is the free standing range, you can find it on the frame behind the bottom drawer. Gendos...post back
Feb 26, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
