Question about Maytag 24 in. MDB9150A Built-in Dishwasher
Soap door opens--but not all soap gets used-
Similar problem--the soap door opens, but only about half the soap gets used. Maybe the door does not open at the proper cycle. Anyone else have this problem, and a solution?
  • 142 Answers
Low water pressure, will cause this problem, as the water is not being forced about the dishwasher, you may have a blocked filter.
Posted on Jan 27, 2009
Soap is not dispensing soap dispenser will not open up when I run the machine. Not soap is in the area for a blockage. Please advise what I can do. Thank you Terri
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Mar 25, 2011 | Kenmore Dishwashers
GE Harmony top load washer: The soap tray when filled with liquid soap will not properly dispense the soap when the water is filling the machine and the soap tray remains full of water and soap at the end...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 11, 2011 | Dishwashers
Soap door doesnt open
Hi
Daniel
Jan 07, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Soap does not dispense, door is open but alot of soap is left behid
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 01, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Soap dispenser door is opening at the wrong time. At the end of the cycle the dishes are dirty and there is still soap in the dispenser.
Hi
Daniel
Dec 18, 2010 | KitchenAid Dishwashers
The soap dispenser on our BOSCH dishwasher, SHE4AM, won't open during washing cycles. Please help
Hi
Daniel
Dec 13, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
The soap dispenser won't open during the cycle on my 15782 model Kenmore Dishwasher. I am using gel pack soap...so I do not have old soap caked in the receptical. Any thoughts?
Hi
Daniel
Oct 26, 2010 | Kenmore 24 in. 15782 / 15784 / 15789...
Soap dispenser lid doesn't open
Hi
Oct 25, 2010 | Whirlpool Dishwashers
Soap dispenser will not open
Hi
Oct 20, 2010 | Jenn-Air Dishwashers
The soap dose not dispence
Hi
Oct 20, 2010 | Maytag MDB3100 Dishwasher
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
82 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
