CRT TV with a white line half way up the screen
My brother-in-law has a CRT TV that has a white line half way up the screen and there in no picture above that white line. The picture is fine below the line but not above it. Any Ideas? I am unsure of the model number I believe it is a Samsung. If needed I can get more info on it. Thanks
  • Andrew Hawkins
    Andrew Hawkins Jan 06, 2009
    Thanks, that should be a piece of cake for me, I swapped out the convergence ICs on my big screen and it works fine. Thanks again
    Novelist:
    Scholar:
  • 67 Answers
The white line is result of a Vertical failure. Believe it or not, the whole picture is contained in that one white line, but it is not spread out from top to bottom on the screen.
Usually, a vertical failure is IC or capacitor related. Should be an easy, fairly inexpensive fix for a competent repair shop.
Hope this helps you...
Posted on Jan 05, 2009
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
My tv has half a picture the other half is white
You hereby reports that the one side of the screen do not display picture, and the other side have. Is it seen vertically or horizontally. Will you please provide a detailed description of the fault you see on screen? google.com/+GopakumarGopalan
Nov 24, 2013 | GE 31GT660 TV
Evenly spaced vertical lines
Hello
Check the smoothing capacitor to video output supply voltage, usually derived from any one winding of the LOT. It will come around 10uF350VDC to 47uF 350VDC range. If this capacitor is faulty, or gone less in capacitance with time, this type of fault will occur. Check the green volour output transistor on the video output card, can be located attached to the neck of the picture tube; for any loose soldering or leakage. OK.
Oct 19, 2011 | JVC AV-32P903 32" TV
I HAVE A HALF SCREEN. BOTTOM HALF LOOKS GOOD TOP HALF HAS WHITE LINES WITH A BIGGER WHITE LINE SEPARATING THE TWO. IS THE PICTURE TUBE GONE OR IS THERE AN ADJUSTMENT I CAN MAKE? TV IS A RCA F25645
This is commonly known as a vertical deflection problem. It cannot be fixed with an adjustment, but requires changing some electronic components. Namely the vertical output IC (integrated circuit) and in addition usually in this model a resistor which may appear to be burned.
Jun 15, 2011 | RCA F25645 25" TV
White lines on the screen.sounds ok.picture is coming behind white line.
Lines means Screen Drive is overdriving, try adjusting the Screen control on the FBT flyback Transfomer, adjust it down. If that does not Clear out Problem then replace the CRT Board that is connected to Picture Tube.
Jan 22, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
We have a 27" MTS Stereo color TV. There are white horizontal lines at the top of the screen. We do have a DVR with Direct TV. How do we fix?
U can't.Only horizontal lines on the top parts of the tv screen or the lower parts of the picture screen.Or very light horizontal lines mix in with the tv screen pictures.The "CRT" the picture tube is slowly dying of old age.Quicker than they supose to.The late 90" these problems case show up alot more in standard tvs using CRT tube.Because the CRT and analog design about to be faze out of the market place.The glass molding and those radiation matrials,they used to make those "CRT" picture tube materials,not as good as before.
Aug 03, 2010 | Sansui Televison & Video
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Televison & Video Logo
544 people viewed this question
Top Televison & Video Experts
