Question about Breville JE900 Juicer
Breville JE900 Leaving Juice in the Pulp and Pulp in the Juice After a Few Years Use
After a Few Years Use, my Breville JE900 is Leaving Juice in the Pulp and Pulp in the Juice. The juice is thicker than used to be and the pulp has to be squeezed thru a cloth bag to get all the juice out. What parts need replacement? If I can't buy replacement parts I surely ain't ever buying another Breville Juicer again. There is no reason those parts shouldn't be availble - juicer technology has NOT evolved that much in the last couple years.
  • heygirlb1970
    heygirlb1970 Dec 29, 2012
    same thing has happened with mine, its only fairly new but lost all the paperwork so can't return, abit anoyed as i in the mood to juice again, did you have any luck
No problem. question: can you juice wheat grass with the breville juicer?
Not really. You'll get wet pulp and a big mess to clean, not to mention the waste of your expensive products. Here's why-
Best juicer machines for wheatgrass and leafy greens
Aug 16, 2011 | Breville BJE200XL 700 Watts Juicer
The juicer overheated and stopped working
The motor sounds like it overloaded, I doubt it has a thermal cutout fitted (in which case you could leave it off for a while and see if it works) I doubt it has this feature and if it is the motor then the unit should be replaced.
Jun 20, 2010 | Breville JE900 Juicer
HOw do i clean it?
flip down the lever to pull it all apart.
rinse out the lid, food pusher and base(that the mesh filter sits in).
scrub out the mesh filter with a dish brush or the included brush if you have it. be carefull the grater-like parts at the base are very sharp. make sure it's clean by holding it up to the light. if there are any particles left clinging to the mesh it will seriously interfere with the effectiveness of your juicing.
you can line the pulp collecting jug with a plastic bag so that you dont have to clean that out as well.
it's best to clean everything immediately. if for some reason you can't, at least rinse the plastic parts and leave the mesh basket to soak until you can get back to it.
if you have any dried food or staining on any of the parts then a soak in water with lemon juice in it (maybe the juice of 3 or 4 lemons) should help soften up particles and strip away stains.
hope this helps....
Jan 09, 2010 | Breville JE900 Juicer
I cant get the filter out of my Breville JE900
hmm, i cant tell if this is the same as my juice fountain. mine just twists to the side and then you can lift both pieces out together. then the filter just falls out when i turn it upside down.
Jan 02, 2010 | Breville JE900 Juicer
Breville Juicer not juicing properly
MY WIFE HAS ONE AND IT'S LIKE A LOOSE CANNON. IF IT IS LEAKING FEED IT
VERY SLOWLY.
Jun 29, 2009 | Breville Juicers
Missing Parts
I think I can help. I am now using my son's juicer he didn't want & have my old one & happy to break it up for parts. It is a JE 90 J so I assume the fitting would be the same. You are welcome to ring me on 0408 352 211 for further enquiries. Cheers Kas
Jul 06, 2008 | Juicers
Juice extractor - dismantling after use
Look at the dismantling and cleaning procedure in JE95XL Juice Fountain Plus user manual on Page 14 and 15. Procedure is the same with JE900.
http://www.breville.ca/site/EN/products/je95xl/je95xl_manual.pdf
This is what manual doesn't tell you: clean the 3 spring loaded pins on the side of the motor clutch. Sugar and pulp may get inside and seize them when dries up, thus making very hard to separate the basket/cutter from the clutch.
Apr 01, 2008 | Juicers
Missing Parts
www.brevillle.com
Nov 04, 2006 | Breville JE900 Juicer
Breville JE900 Juicer Logo
46 people viewed this question
Top Breville Juicers Experts
just-ice
Colin Stickland
Colin Stickland
eyecam
Are you a Breville Juicer Expert? Answer questions, earn points and help others
