Question about Seagate Computers & Internet
Hard disk repair - Seagate Computers & Internet
  • Seagate Master
  • 27,725 Answers
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive
hope this helps
Posted on Nov 08, 2012
Blue then red light. Why is it not seen by the computer?
There are so many things to be considered why the hard disk drive are not detected by the computer. Poor data cable, defective power supply and worst the hard disk drive. Let's say your hard disk drive having a problem. Here is the best link for you
The World of Full and Free download and install this software it will repair most common hard disk problem. This video tutorial will help you to scan and repair your hard disk. HDD Regenerator 2011 have a nice day
Apr 14, 2015 | Computers & Internet
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
When drive turned on blue light appears then red light comes on & computer cant see hard drive
There are so many things to be considered why the hard disk drive are not detected by the computer. Poor data cable, defective power supply and worst the hard disk drive. Let's say your hard disk drive having a problem. Here is the best link for you The World of Full and Free download and install this software it will repair most common hard disk problem. This video tutorial will help you to scan and repair your hard disk. HDD Regenerator 2011
Apr 14, 2015 | LaCie Computers & Internet
Smart failure predicted on hard disk repair
This means either your hard disk is about to fail or it already has in which case you will need to purchase a new HDD (hard disk drive) and then contact acer to purchase recovery disks or if it is still under warranty then contact for service.
Jul 19, 2014 | Acer Computers & Internet
Laptop wont start up desktop asks for system disc
Your hard drive has become corrupted. If it's windows try putting in the operating system cd and doing a repair install. Alternatively you could go into the repair console and see if it's teh Master Boot Record simply needing to be repaired.
Here is an example of repair install step by step:
http://michaelstevenstech.com/XPrepairinstall.htm
Of course I would read through the whole thing before attempting this. If you do not know how to do any of this I suggest taking it to a local repair shop.
Sep 21, 2011 | Toshiba Computers & Internet
Hard disk is not running frm last boot
hi,
- This means that your operating system may have collapsed and needs repair.
- To repair, enslave your hard drive to another machine by:
- Make sure the second computer has a good operating system.
- Remove the hard disk from your computer.
- Remove CD/DVD Rom from the second computer and fix your hard disk on
that drive.
- Start the computer.It will display that you're running on two drives.[Unix]
- Press F1 to save changes and continue.
- The machine notes one drive needs repair and starts the repair process.
- After it has completed and opened your system, turn it off and remove the
hard disk.
- Fix it on the first machine and start it.
- If this fails,you may need to format the hard disk.
GOOD LUCK!
Sep 11, 2011 | Maxtor (6L250S0-20PK) (6L250S020PK) 250 GB...
My western digital hard disk wont work how to fix it?
There are many possiblities for your hard drive.
You can use the following that software to repair your hard disk.
  1. Western Digital DM (Disk Manager)
  2. Spin Rite
  3. Hard Disk Regenerator 1.1 or later version
If you professional or understand computer better, you can repair your hard disk to use one of above mentioned software.
Good Luck
Nov 21, 2009 | Western Digital Computers & Internet
Hard disk repair
is it an external hard disk and does it get detected by windows.. if so try chkdsk /f on the disk.
Aug 31, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
Hard disk problem
i suggest that you'll buy another hard disk.. repairing hard disk is a tough job.. machines had done it, it is a very difficult job if its manually repaired... your hard disk maybe damaged if your system can't detect it. Just make sure that the cables are properly place/attached.
Jan 25, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Problem in hard disks
You cannot repair the hard disk. But if the data on the disk is very very important, you try to recover the data from the hard disk, this recovery is not hundred percent.
Jan 03, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
