My wife tried to run the washer when the generator was on. now the washing machine gets power, but will not begin the washing cycles. Which part needs to be replaced?
What is the model number of your unit?
110.42824200. sorry for the delay, lost power AGAIN from the snow!
No porblem. I hope you have recovered well. I want to be sure here before I give you the shocker. You have power to the display but it won't start, correct?
yup. We lost power due to the hurricane, and my wife tried to run it while the house was being powered by the hurricane. I ordered and installed the Microcomputer (#8181769, new part # 285925). When I installed the micrcomputer, I heard a click, and the front door locked. The washer still gets power, however the cycle will not start. Now, the door will not unlock. Thanks for your help!
I meant powered by the generator
OK,you will also need the control interface and possibly the motor control. But since the water does not start to enter the machine I think it is the interface. Here is the part to order.http://click.linksynergy.com/fs-bin/clic... Don't worry if this doesn't correct the problem. The parts come with a 365 day, any part any reason return policy.
You can't run the machine on a generator, it will take out the electronics. As you see now. The power fluctuates to much on a generator . Keep me posted!
Thanks Rich! I will let you know if it works
SOURCE: Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
SOURCE: Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
SOURCE: Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws
under the bottom edge on the front of the washer. HINT: If you prop up
the front feet of the washer with some small blocks of wood, this will
make access to the screws much easier.
2. With the screws removed,
the lower panel should drop down then come off. If the panel sticks, a
light tap on either side will knock it loose.
3. Reach your hand up
inside the washer behind the front casing on the right-hand side. This
is where the door latch assembly is located.
4. At the bottom of the
door latch assembly is a small pull tab. This is the manual release for
the door. Pull the tab straight down and the door will come open.
Sometimes
these doors will not unlock for whatever reason. If there are no error
codes being generated, this could have just been a momentary glitch. If
you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
SOURCE: We have a Kenmore Elite Calypso, it is not washing
Hi
Thanks for using FixYa. Error
code LD means Long
Drain. It flashes when washer takes longer
than 5 minutes to pump out water to a point where the operating pressure switch
resets.
Error code CA means Average
current limit. This error code will display
if the load of clothes is more then the normal load. Also if current
limit breaches then status signal comes back from the motor controller. The
unit will return to standby mode and display CA. Average current trip occurs if
the current draw at the motor windings is greater than 5.55 amps in 2 seconds.
This error occurs if there is a problem with the drive motor, thermal protector
or motor controller. Over-loading the unit may cause this problem.
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
SOURCE: Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
