Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
How to change screen size on a sony trinitron tv manually
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: I have Trinitron Sony Television
I think what your asking is for an on screen service menu?? That wont fix your problem. It sounds like you have a vertical height problem where the screen doesnt fill the entire screen with the Picture. The adjustments wont go out like that for no reason and all by them selfs. The vertical sweep IC went bad and is going to have to be replaced. This is not a job for the end user. You should call an experienced tech to assist you with this repair. Good Luck
Posted on Aug 12, 2006
  • 579 Answers
SOURCE: blank screen on sony trinitron tv
The problem with this model is the large parts due to poor wave soldering. Locate the transistor Q605. Using a small wattage soldering iron melt the solder and add a little solder to all the large parts in the area. Small wattage = 15 to 30 watt. Stay away from the surface mounts they are not the problem. I resoldered the following: D647
Q605 C690 D645 D620 R691 Q691
These parts are located on the main board, the one the power cord connects to. Carefully press the clip on the left side of the board (as you look at it from the rear of the tv) carefully pull the main board back and out of the rails. You will find the parts on the right side of the main board about 2 inches over 2 inches down.
Posted on Dec 31, 2007
SOURCE: Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Posted on May 25, 2008
Sony kv-32hs420 screen mode doesnt work
Display ratio usually is a setup choice but bear in mind that old movies and old TV programs will display in 4:3 ratio. Remotes usually have no control over screen size.
Dec 28, 2013 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony 34" XBR TV Picture does not fit on Screen. How to change setting?
Have you tried going to menu then to video options, screen size should be in that menu, also have got a zoom funtion on the remote, if so try using that. Do you have the owners manual, if not I will try to find a copy in PDF file format, just let me know.
Oct 13, 2008 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My picture is smaller than screen size..
the only thing I can tell you is go to menu and check for screen size or what else fails read the manual
Nov 16, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
How do I adjust the screen size on a DVD I'm viewing on my 36" Sony Wego TV? The top and bottom are cropped. Thanks!
On the remote control press the "Screen Mode" button to cycle through all available screen modes.
Apr 20, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Picture and text extend beyond screen
Your tv needs to be put into service mode with the original Sony remote control and then set the vertical\horizontal size parameter to the correct values and then burn the new settings to memory
Google " sony tv service mode " and you should find the procedure. Good Luck! Write back if you have problems.
barneyluc
Oct 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron WEGA 20" Problem
change the tact switch of tv/video coz its deficteve.
Sep 30, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
I have trinitron Sony Television.. i got some problem with my TV, the Vertical screen size gone out of focus... I want to know about remote control Commander Codes from which i can resolve my problem and...
Aug 12, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
186 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
