Question about DeLonghi Microwave Ovens
Hello we have a Delonghi AG925EFY in the office, it is no longer heating food. On the top there are some red lights flashing at the top end of the microwave, icon 1 and 4 are flashing. Please could ypu give some advice time for a new microwave ? Thank you
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Posted on Nov 09, 2008
bestdarngood
  • 3037 Answers
SOURCE: it turns on ...lights up but doesnot heat or warm the food
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
ginko
  • 19396 Answers
SOURCE: LG Microwave does not heat food
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on Apr 27, 2009
SOURCE: AC925EQK microwave. flashing light, not heating up
Mag tube Shot
Posted on Aug 29, 2009
Testimonial: "thanks very much"
How to fix microwave with bang, flash
That was the magnetron tube breaking. Too expensive to fix. Better to go and buy a new microwave.
Feb 04, 2013 | DeLonghi MW 535 Microwave Oven
Light is on but it is not heating up the food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 17, 2011 | DeLonghi Microwave Ovens
My Delonghi AM820AGX microwave no longer heats up liquids/food. It turns on and looks like it works, but when I test the liquids/food, they are still cold. I could have possibly changed the settings...
It souds like a busted MAGNETRON, and replacing it usually costs almost the price of a new oven...
Nothing to do with a setting... Sorry!
Apr 15, 2011 | Microwave Ovens
Hi, i have an ac925efy delonghi microwave oven, i bought it manufacturer refurbished and when i switched it on there was a big bang and a flash. it came from what looked to be the back top right hand...
From your description it is the magnetron that heats the food that has gone, I suggest that you take it back for a refund, because if you decide to fix it the repairs will run you more than what the microwave oven is worth.
Jan 16, 2011 | DeLonghi MW 535 Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
It turns on ...lights up but doesnot heat or warm the food
Benjamin
Apr 17, 2009 | DeLonghi MW 605 Convection/Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Lisa
Lisa
tfelton3
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
