Question about Dell Axim X50 Pocket PC
I have a Dell Axim X50V with no idea of how to it own I have got a charger and charged over night but not sure how to turn on
I have got a charger and charged over night but not sure how to turn on . I tried hard reset but did nothing. I think i push and hold the orange light at top but no sure.
5 Suggested Answers
SOURCE: Hard reset
I could not solve the problem till now. I decided to send it to a repair shop in Chennai INDIA.
Posted on Jul 13, 2008
SOURCE: Dell Axim X50v won't turn on after 6 months of no use
Perform a hard reset.
1. Hold the reset button on the back.
2. Hold the Power button down.
3. Release the reset button.
4. Release the Power button.
5. Press the Contacts button when prompted.
Hope this helps!
Ken Akiyama
Posted on Aug 11, 2008
KingDWS
  • 1606 Answers
SOURCE: Dell Axim x50v won't charge. Just stays orange and
Replace the battery with a new one and it should behave afterwards.
Posted on Mar 23, 2010
  • 32 Answers
SOURCE: I can't get past the
no. USE A TOOTH PICK if your finger is too inaccurate
but if thats not working there is a way to get past the 'align screen' screen. Connect the device to your computer.
From activesync, browse your device, and delete a file called 'welcome' from the windows/startup folder. (haven't done this in a while, so those might not be the exact names)
It should then start up without going through the whole setup thing that it does the first time you start it up.
also try wiping the corners of your pda gently with a business card. This may help as unresponsive screens occur due to dust trapped under the casing.Remeber to practice this every 3 months.Good Luck :)
also ~~~ OK. This is not for the mechanically un-inclined. The short answer is that the touch screen membrane is separating from the display panel and MAY be fixable by inserting pieces of rubberized foam. The following is a post of someone else in another forum www.mobilitysite.com.
I have recently exhaused my patience with the ever-changing screencalibration and decided no matter what, I was going to resolve thesituation or destroy this useless handwarmer in the process. My unit isoff warranty so with little to lose I charged ahead.
Having tried most of the suggested solutions on the forum with limitedand intermittent success, I got out my golden screwdriver and poppedopen my X50.
Using a jewellers screwdriver (xActo would work as well or better) Iremoved the adhesive covers over the case screws. I had a very smalltorx (#5 or 6 I believe) screwdriver purchased from an online cellular phone parts outlet(couple of bucks) and it easily removed the 4 screws (remove batteryfirst!).
I slid a thumbnail under the upper left (or right) corner (the cover isjointed between the silver and black on the edge) and pried the caseslightly open to verify it would part and slowly worked it down theside and the case. It popped off suddenly and without incident (and noshedding of parts/springs/buttons...etc.).
Underneath the entire display plate and touch screen appeared in goodcondition. I gently cleaned the face and edges of the plate where thecontact strips for the touch screen were clearly apparent. Using myPDA stylus, I pressed gently but firmly on the screen over the contactstrips and ran the stylus around the perimeter of the screen plate,ensuring that solid contact was made to the strips. They did not appearto have separated or delaminated in any way but due to the otherexperiences of forum members I expected there was some issue of loss ofcontact. My troubles incidentally began after a waist-high drop of theunit while in its case.
After the "burnishing" of the edge of the plate, I deftly cut twonarrow strips of the "frosted" scotch tape variety and using the tip ofthe jewellers screwdriver and my fingers, placed them directly on thedisplay plate over the top of the contact strips at the top and bottomedges. I did not do the left/right edges as I had never observed theproblem on vertically drawn lines. The tape was applied to "encourage"more pressure and better contact of the touch screen with the top andbottom contact strips.
Re-assembly of the case was not complicated, but pay attention to thespeaker bud and ensure that it returns to the flange in which it isheld as you mate the silver cover plate with the black case. Replacescrews and torque gently but firmly.
I actually tested my unit prior to re-assembly and the EKG pattern Iused to get from drawing a horizontal line across the top of the screenwas completely resolved.
So far it is working without any problems. If your screwdriver is notgolden (or you are faint of heart) locate a friend who is mechanicallyinclined with small devices to perform the surgery. I did not take anyphotos of the surgery as the patient expressed confidentialityissues...sorry. Maybe someone else can snap a few if they try the fix.
This worked for awhile but after about a year the problem returned...my next solution/post...
OK...latest developments...the problem has returned somewhat.
I disassembled the case again and "burnished" gently the touch screendirectly above the conductive traces around the edges of the membrane.Again, the problem resolved itself. My take is that there is some sortof delamination of the screen with the conductive paths that ishappening.
Today's therapy for the problem was to take some 3/8" round,adhesive-backed, soft foam rubber pads (the kind you might buy to puton the bottom of a book-end to keep it from scratching the bookshelfetc.), and cut into small 1/16" wide strips. I placed these strips overthe top of the touch screen membrane, directly over the conductivetrace. I did not do the same on the bottom as the problem has alwaysbeen observed (and corrected) with the top strip. You could use largerdiameter pads to simplify the process but the essential issue is theymust be "VERY" soft and spongy (these are really unique in thatcharacteristic). I believe I obtained them from Lowe's. Anyway...if youuse something that is not really spongy, you will likely cause the caseto bulge/deform from the pressure (or worse yet, crack the LCD from thepressure). The thickness of the pads I have is around 1/16".
You could conceivably use a number of other materials to accomplish thesame effect...but you essentially need to use something that willsquish down without exerting too much pressure (soft/spongy) and yetmaintain that pressure in the long term (can't be something that willpermanently deform). Soft foam weatherstrip might be a candidate butmust be trimmed down to a thin height.
The problem is once again resolved. I do note a very slight curve tothe case above the top edge of the screen but it's not excessive anddoes not appear to deform the display (confirm this by viewingreflection distortion of the screen surface). Over time as the foamrelaxes somewhat, this should diminish, yet gentle pressure shouldcontinue to be exerted on the membrane.
Anyway...that's the latest from the "out of warranty" repair attempts.
Good luck.
Posted on Mar 07, 2011
MY DELL AXIM CHARGER DOESNT SEEM TO WORK AND I WANT TO KNOW IF I CAN GET A SUBSTITUTE CHARGER
contact the manufacturer we do not have items here for sale , just advice , some good ,some not so much
Nov 03, 2016 | Dell Computers & Internet
Dell axim X50v manual download - how to get this download please.
Sure! Yoiu can download it from this location.
Hope it is what you were looking for.
Anyway, please, let me know if you need further informations.
Regards,
Carlos
Jul 01, 2012 | Dell Axim X50v Pocket PC
Axim x50, buttons all work, syncs without a problem but sometimes freezes
You might need to hard reset it or update your Dell Axim x50
it is important to know if you have an x50 or a x50v. here are two vids. first one is for x50, x51. second one is for x50v, x51v.
Dell Axim x50, x51
http://www.youtube.com/watch?v=9K2P_SNTuGo
Dell Axim x50v, x51v
http://www.youtube.com/watch?v=vEDvCklrNs0&feature=fvw
Dec 15, 2009 | Dell Axim X50 Pocket PC
My dell axim pocket pc charges but will not turn on when i disconnect it from the usb cord
the same thing happen to me. Change your battery. I chaged mine with a new one and then it worked fine.
Sep 28, 2009 | Dell Axim X50v Pocket PC
Dell Axim x50v PDA turns on when screen is tapped
If your PDA turns on when u press buttons if u go to settings u choose if u want it to turn on for any button or just the main button
Aug 06, 2009 | Dell Axim X50v Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
Blue screen with dell logo??
This is usually called the "Blue Screen of Death" and the system tries to dump memory
See if you can Read any of the text which may detail the error
Try starting it in safe mode by tapping F8 every few seconds during startup
If it starts post back and i'll tell you how to use system restore
If it still fails then call in an Engineer
Oct 14, 2008 | Dell Axim X50v Pocket PC
give me some more information as to what exactly occurs. Your battery may be dead. i could be just uncharged. It could be an AXim problem. Be more specific so i can try to help you.
Aug 07, 2008 | Dell Axim X50v Pocket PC
Will not turn on
1)check the wire of your charger if it is good
2)check your battery
3)check the connection of the battery on your cellphone maybe there are some connection that are disconnected
4) In general check your power supply.
Jan 25, 2008 | Dell Axim X50 Pocket PC
Dell Axim X50 Pocket PC Logo
150 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
