Question about Curtis Klu 7-inch Touch Screen Mobile Internet Device
I've read the manual and it says nothing in reguard to whether or not I can turn my tablet on and use it while it is charging for the first time for 10 hours.... I'm quite anxious to try out this new device, but i dont want to interrupt the battery from charging correctly or have any negative affect for future performance.
    President:
  • 643 Answers
Yes You can
Posted on Nov 07, 2012
    New Friend:
Mines charging but can't get it to turn on and light is red
Posted on Sep 24, 2016
I bought 4 ZEEPAD 7DRK Rock tablets for my grand kids for Christmas and 2 of them will not even turn on. The 3rd one worked for 3 days and it also will no longer turn on. I've tried charging them...
Hi, Zeepads have an issue with powering on....when charging it is best to use the mains charging as it is more powerful....if you are sure they have been fully charged then try this:
Hold the power button down for about 2-3 minutes.
Listen for a small click.
Take finger off of power button and wait for about 30 seconds.
Hit the power button again.
Hopefully you should see the start up screen, post back with the results!
Jan 01, 2015 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
My CURTIS KLU LT7035J tablet only works when I have it plugged in. It won't charge and I have been trying to charge it for days ? Nothing in the manual on what to do...should I return it or is
Please ensure you are using the correct power adapter that came with the tablet. If it is the wrong voltage/amps then the charging function will protect itself. If it uses a micro USB end then try charging via a computer USB port using a USB to Micro USB cable. This should work and will possibly eliminate the Tablet from the diagnosis. DON'T try to make your own power solution from a combination of cables/adapters because it's potentially dangerous to both you and your tablet.
Dec 01, 2014 | Curtis Tablets & eReaders
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
I can't get my battery to charge. This is a new tablet, I've only had it for about a month
I purchased A Coby tablet from Fingerhut and it did the same thing in less then a week and the connection fell inside the device so i returned Their piece of junk... i now have a bigger better one from stoneberry and a smaller Samsung Galaxy 2 from Qvc :)..i pau $60.05 in
Jan 08, 2013 | Coby Kyros Android Tablet
My tablet won't come on I've had it charging so the battery should be full is there something I can do?
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
Jul 02, 2012 | Coby Kyros 716829701508 Tablet PC
My Android tablet was on the charger charging, and I was using it, then all of a suddenly turned off and now I can't get it to turn back on, what's wrong with it?? I've only had it 2 days
u have 2 options 1 is to get the tablet reflashed or the most common problem is that u have overcharged the battery and it will need a new one this problem is very common in tablets as opposed to i pads as the tablets only get the bottom market parts where as the ipads get higher quality components
May 16, 2012 | HTC Tablets & eReaders
My Nextbook 7 won't turn on
Every tablet has a button sequence, the reason being for a fresh restart. Either you unplugged it before full recharge, or didn't use proper charging adapter or cable.
There is a solution to avoiding this but first get tablet started by:
Hold power button and volume up button for eight seconds, release and hold power button again, tablet should turn on.
If not, do the opposite hold power button, volume down for eight seconds, then power button. You need to do this with proper adapter and charger you tablet came with plugged in. You may also need to do this more than once.
Once your tablet has started up, the way to avoid this is to swipe right on screen until you see settings app, should be round looking similar to a sprocket, or clock gear.
Open settings / display / sleep. I set mine for 30 mins.
Now you no longer need to power off you tablet manually, thus skipping the button sequence process.After unplugging from charge adapter you will still need to press power button to start.
Hope this helps I have yet to have this problem again, and remember to always let your tablet fully charge before disconnecting.
Jan 11, 2012 | Tablets & eReaders
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Open Questions:
See all Curtis Klu 7-inch Touch Screen Mobile Internet Questions
Curtis Klu 7-inch Touch Screen Mobile Internet Device Logo
Top Curtis Tablets & eReaders Experts
Michael Harrier
barez
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Curtis Tablet and eReader Expert? Answer questions, earn points and help others
