Question about Proform Exercise & Fitness
Won't incline Haven't used it in a while and I went to use it this morning and treadmill won't incline manually. I push the incline button and I hear three beaps like I was pushing the wrong button. Can't find my manual to see if there is a procedure or if it is broken.
    Top Expert:
  • Proform Master
  • 12,223 Answers
Please RUN the software calibration for troubleshooting, Go to see the instruction manual or goes under the hood and follow the instruction guide.
see the diagram attached.
Posted on Nov 08, 2012
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: My Proform treadmill will not incline. It is stuck
My proform treadmill is stuck on the highest incline (10) and it doesn't budge from there..Help my workouts are killing me!
Posted on Jun 24, 2009
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
avpowerstn
  • 22 Answers
SOURCE: The treadmill does not incline.
Try Re-Calibrating 1st, here's how.
With the Treadmill off, press and HOLD the SPEED UP & STOP
keys, while holding the speed up & stop keys insert the Safety key (Magnet) release the speed up & stop keys. now press and release the stop key. now press the "incline up key" let the treadmill go to max incline,after it stops press and hold the "incline down key" let it go to minimum (completely lowered) you should now be re-calibrated.
Posted on Jan 28, 2010
SOURCE: Treadmill incline stuck @ steepest level (highest)
MAKE SURE YOU STAND TO THE SIDE OF THE TREADMILL WHILE PERFORMING THIS
1)Connect the wall power to the treadmill
2)Remove the safety key
3)Hold down the red stop button and red increase speed button (this is the red triangle next to the start button)
4)Insert the safety key while holding both buttons down in step3
5)The treadmill will now go into a diagnotstic calibration mode
6)Let go of both buttons in step 3 and press the oval stop button once
7) Now press the up arrow green incline button once(This is located to the left of the yellow program button)
8) Allow the treadmill to go through a calibration cycle, once it completes and stops moving remove the safety key count to 3 and reinsert.
Posted on Feb 28, 2010
I have a proform 505cst. When I push start, the motor seems to short out. The motor controller LED blinks four times.
Customer Reviews: Proform 505 CST Treadmill (2014 Model)
www.amazon.com/Proform...Treadmill.../B0048HS02...
Amazon.com, Inc.Start here. ..... I was worried it would fall out with the vibration but, as I mentioned earlier, ... The 10% incline and the max speed on this unit more than serves the need ...The sound from the belt and motor is very acceptable (but then its only been .... This morning i was using it for the first time and this treadmill seems great.
Amazon.com : Proform 505 CST Treadmill (2014 Model ...
www.amazon.com > ... > Cardio Training > Treadmills
Amazon.com, Inc.Start here. ..... The ProForm 505 CST Treadmill is designed to get you moving. ....This morning i was using it for the first time and this treadmill seems great. ... I would suggest for anyone that gets this to open up the motor cover and take a look at ...graphics on the instruction manual and figure out what piece went where .
505 CST ' Proform
Jan 11, 2016 | Proform 505CST Treadmill Walking Deck
Horizon treadmill won't incline
Step 1:
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
Jan 04, 2013 | Exercise & Fitness
Incline motor ran away, won't work after replacing
see the diagram attached and test test the input motor voltage, if there are the motor is faulty.see my personal TIPS.
God bless you
Nov 18, 2012 | Proform XP 580 Crosstrainer Treadmill...
Incline won't shut off
Please RUN The software calibration for diagnose, troubleshooting and fix it.
download your inst.manual from www.iconservice.com or www.fitness.manualsonline.com and proceed according
God bless you
Jul 18, 2012 | Icon Proform 560 Crosstrainer Treadmill
Some of the Vision Fitness t9450 treadmill incline and speed quick keys stopped working along with the manual speed and incline buttons
It sounds like you have a membrane issue. There are a number of different T9450 models and they all have slightly different consoles. You'll need your serial number to help pinpoint the parts you need. Your best bet is to go through the manufacturer (johnsonfit.com) and have them help you get the correct membrane and overlay.
Jun 08, 2017 | Dmm Vision Fitness T9500 Treadmill
The treadmill does not incline. Motor runs when the button is pushed but no movement.
Dec 23, 2009 | Epic 425 Mx Treadmill EPTL88105 !
Jan 08, 2009 | Exercise & Fitness
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Exercise & Fitness Logo
137 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
