Question about Exercise & Fitness
Can't get it to incline
    Top Expert:
  • 12,223 Answers
Run the software calibration for troubleshooting. read your instr. manual for entering to the calibration or goes under the hood motor and follow the instruction guide
see the diagram attached. Lube your motor and shaft,etc.
Posted on Nov 08, 2012
Proform xp 550e had a problem with incline...plastic guide piece was brittle and broke apart....hubby made a new guide piece... Incline & incline motor now works perfectly provided you hot wire it! ...
Hi There, I think the motor control board, or MCB, has a couple of Triacs (Transistor looking things) bolted together on that unit. The lift motor plugs in near them. If one of these Triacs shorts or is damaged, it will act "Live" at the connector, and drive up or down constantly, pinching and/or damaging the lift. There are a few causes of constant elevation in either direction....
1) Up / Down key stuck
2) Bad logic signal from the console(unusual)
3) Pinched or damaged console cable
4) Shorted Triac or failing MCB
You can contact jatinah electronics for repair at 75 for these units. Good Luck!
Jan 10, 2015 | Proform Exercise & Fitness
The incline motor has recently been replace, but now the incline doesn't work. i've tried to recalibrate it but it isn't working. any other ideas how to fix the incline.
does it work at all?if not there are connections on the control board that may have been left off. remove the motor hood and chech the incline motor. its usually in the center
Sep 29, 2014 | Exercise & Fitness
I have the Nordic 9i incline treadmill. I can't
see the owner manual.download free.www.fitness.manualsonline.comsee the video attached.God bless you
Mar 15, 2013 | Exercise & Fitness
I've 2000 Mercedes Benz ML 320.One night I backed up & parked in the Garage the next morning it won't go forward. I noticed the that REAR WHEEL on passenger side was locked up. What's
The only suggestion is to place the vehicle on
stands & remove the wheel to check out the issue
To speculate from the internet-- is just that.
To have something happen while you sleep
is odd,so I would be inclined to go with something
like an electronic parking brake issue,if that applies
Nov 14, 2012 | 2004 Kia Sedona
Proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
May 16, 2012 | Proform 860 Competitor Treadmill
What does Err 7 mean on the Fitnex t30 treadmill?
For the Fitnex T30 treadmill, the error 7 (listed err7 on the display) code means that there is a fault with the incline motor. My problem was the incline motor had burned out probably from usage, and during my research, this seems to be a weakness for the T30 model. You can remove the front plastic cover, unscrewing the 4 phillips head screws to reveal the electronics board, belt motor, and incline motor. With the power on (do not touch the board or wires 'cuz you could be electrocuted) check the board located next to the power switch. If the board's two lights are lit green, then your incline motor has probably ceased to live. Just in case, make sure to check with a flashlight, all those capacitors. One of them could have blown out and I'm not sure whether the green lights would indicate that. If one is blown the cylinder end will be bulged as if the cylinder 'popped'. You can see that the cylinders are stamped with a plus-sign. This is a built-in weakspot to allow an 'explosion' to puff out that plus-sign stamp. It will be fairly obvious if one has kaboomed. Make sure the wires are intact as well. Use a dustsprayer to blast all the grime and dust off the board and wires and motors. If all looks good, it's probably your incline motor itself that has gone kaput. Now let's get that motor out! Turn off the power and remove the power pIug from the outlet! First, I removed the grounding screw (green wire), unplugged the 4 prong main switch and 3 prong secondary switch from the motherboard that connect to the incline motor. [Just a footnote, inspect the connections of those wires into the incline motor just to be sure. If all is well, continue motor removal]. Next, use wrenches to remove the top nut and bolt securing the incline motor. Then, gently tip the entire treadmill on its side and do the same to remove the nut and bolt from the incline bar across the bottom of the treadmill. Now flip the treadmill rightside up. Remove the incline motor. I ordered the same motor, used and rebuilt, from sbarker (Ebay id), sbarker10 (Amazon id) for $54, shipping included. You're not going to get a better deal than that. A new replacement motor from a exercise equipment store online wanted $200 which is just not worth it. From order to arrival, took 4 days. Follow the same procedure in reverse order to install your new motor. Everything should work fine. If you're still getting the error than there must be a wiring issue between your board and the incline motor, or the board itself is faulty, but then that's beyond my knowledge of this particular problem. Don't worry though, with what I've found, the incline motors are poo-built, so if you're getting this error in the first place, I'd bet the farm it's a burnt incline motor. Good luck
Jul 12, 2011 | Fitnex T30 Treadmill
My treadmill t-30 keeps on posting error 7. I can't find my manual, so what does this mean? Thanks!
May 19, 2011 | Fitnex T30 Treadmill
The treadmill does not incline. Motor runs when the button is pushed but no movement.
Try Re-Calibrating 1st, here's how.
With the Treadmill off, press and HOLD the SPEED UP & STOP
keys, while holding the speed up & stop keys insert the Safety key (Magnet) release the speed up & stop keys. now press and release the stop key. now press the "incline up key" let the treadmill go to max incline,after it stops press and hold the "incline down key" let it go to minimum (completely lowered) you should now be re-calibrated.
Dec 23, 2009 | Epic 425 Mx Treadmill EPTL88105 !
Exercise & Fitness Logo
57 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
