Question about Toshiba 2060 Copier
The copier keeps saying to put doc. feeder down and i it is. I ha
Don't know what is going on but in the readout box keeps telling be to put doc. feeder down when it already is. Once I open and it resets then place the doc in the feeder it gives me the same message again. Have to restart all over. It works fine when i just place on the glass and copy
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
When you lift/ open the ADF you should see a tab in the back corner (slightly in from the corner) of the ADF. This tab is for the machine to see that the ADF is closed. Make sure tab is there. On its sister model they used a depression switch, check that and make sure it is there and working properly.
Posted on Jan 05, 2009
Machine says unable to calibrate, claims jammed paper in the doc feeder,
Check the sensor arms and make sure they move freely and are free of paper debris.
Feb 24, 2015 | HP Office Equipment & Supplies
WONT MAKE A COPY IN TOPFEEDER
Check the connection of the doc feeder to the copier. if you open a cover on the doc feeder does reflect on the copier? Ensure the doc feeder is aligned there is a small magnet right front side of the doc feeder that sits on top of a switch (Can not be seen underneath front plastic the copier when down. Adjustment bolts for the doc feeder is the rear right hinge only.
Mar 21, 2014 | Konica Minolta Bizhub C253 With Document...
My c-20 copier will not print from glass. prints blank pages. will only print the ones placed on the feeder.
I know this silly, but you put the originals on the opposite end of the glass. I don't mean to insult anyone, but I don't know your experience with this machine.
The fact that it copies thru the feeder, tells me the copier is ok. The doc feeder uses the same optics.
hope this helps
Feb 07, 2011 | Xerox CopyCentre C20 Black and White...
Document feeder door open
The doc feeder is the one on top, there's a sensor in the hinge at the rear. If the tab is broken from the top cover, you need to fold a piece of paper and put it inside the horse shoe shaped sensor to get past the error.
Nov 12, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Place doc , feder in the down postion
Something is blocking the Original Present sensor in the document feeder. The machine thinks you are trying to use the doc. feeder to make a copy. Clear the obstruction and this should remedy situation.
May 23, 2009 | Toshiba E-STUDIO 450 Copier
power supply has the fuse open that feed the voltage for the ardf
Mar 20, 2009 | Toshiba E-STUDIO 450 Copier
The copier keeps saying to put doc. feeder down and i it is. I have to lift cover to like reset the thing.
There is probobly a mictroswitch mounted on or near the hinges that detects the feeder position. See if it is loose or bad.
Jan 05, 2009 | Toshiba 2060 Copier
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
Doc cover open
Yes there is and I know your problem have a look at the left hinge on lid that you lift to put down an original for copying, it will be breaking apart, the switch is black in that same corner on doc feeder base, as the hinge breaks apart the doc feed lifts in that corner causing "doc cover open" cause that switch no longer gets pushed in when lid is shut
Dodgy repair - tape switch closed, but doc feeder will not work properly/can use glass.
Repair - Easy removal of three screws and replacing 20buck hinge bought from brother dealer...part no.LE8731001 Hinge assy left.
Now that's FIXYA!
Nov 19, 2007 | Brother MFC-8440 All-In-One Laser Printer
234 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
