Question about Drills
My dewalt drill is 3pin 110v I need to step up to 240v
115v~ 50Hz 6.0A 650W Never seen this plug on a power tool before but then I'm a real novice maybe that's why. It's a 3 pin plug the like used for electricity hookup for a RV/camper van/ moble home I can be contacted at jamierowson@hotmail.co.uk if you have any thoughts Jamie Rowson
    President:
  • 643 Answers
You cant convert to 240 the plug you have is a 30 amp 115 volt
Posted on Nov 07, 2012
shaggyrat
  • 1224 Answers
SOURCE: Dewalt 18 volt compact drill
yes this is normal the spark keeps motor from stalling out by taking away the friction spark by making own spark
the clunk is the drill brake so you dont brake your hand when screw goes in all the way unlike old drills that kept going even when your hand was attached to it
Posted on Jun 05, 2008
Buffalo12980
  • 625 Answers
SOURCE: Question about Dewalt 18 volt compact cordless drill
sparking on any portable tool is normal. I don't understand what shaggyrat said about the sparking, but we'll let it just go at that. the drill uses a johnson motor and the gear train is a planetary gear drive. the clunk is the play in between the drive gear and the first planetary drive. the drive is built up over several stages inside so you can get the needed torque to drive screws etc.
stug_57u
  • 99 Answers
SOURCE: dewalt 18volt drill xrp dc988 in pieces
If you are in the U.K. go here fore tech help and service dealer locator etc https://service.toolcommerce.com/products/HomePage.aspx?BrandId=2&language=en-GB&country=GB
If you are elsewhere go to www.dewalt.com and you can navigate to other countries etc from there.
Posted on Oct 26, 2008
  • 398 Answers
SOURCE: when in drill mode the tork still kicks in on my dewalt
there is a gear and a clutch as agier said in the head. if its old it looses its catch, youll need to take it apart and look at it. the torque setting just tightens on the head the more you tighten it the less it will give( the ratcheting you hear when you set it low) .expensive drill so its worth trying to fix. how old is it? as for drilling thru knots and hard wood make sure your bits are sharp, you can spend alot of time trying to drill with a dull bit. do you sharpen your bits? i do alot of drilling with battery drill thruout the year and believe me a sharp bit is waaaay easier. though ive never had to sharpen concrete bit because they always break when they get old and i buy new.
so your saying it stops completley when you hit something hard, right. does it ratchet?
Posted on Apr 23, 2009
SOURCE: Replacing a power cord for a Dewalt electric drill
some of the dewalt drill switches have a one way trap (like) for the wire. you push the wire in and the harder you pull it gets tight on its self. your wires go in the bottom of the trigger look right on top of each wire there is a small **** (no bigger then 3/16) for a flat head screw drive. In the **** you will see a small lever, it needs to be turned at the same time pull. It will help to have a friend.
Posted on May 27, 2009
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
  • For Battery Type: Ni-Cd Ni-MH
  • Input Voltage: 110V-240V
  • Smart Charger for Dewalt 7.2V ~ 18V Ni-Cd Ni-Mh Li-ion Battery
  • For Brand: DEWALT
  • Color: Black
  • Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
May 04, 2015 | Dewalt Drills
It won't work
You can take it to a repair center like Sears, but they charge $29.99 for diagnosis! You're better off pitching it and buying a new one.
May 08, 2012 | Dewalt Drills
Where can I find a 240v Bosch 11240 SDS Max Rotary Hammer drill that I can take and use in Ghana
You'll be hard pressed to find one that doesn't run on 110v. You might be able to look on ebay and buy something from the UK like this for example:
http://www.ebay.com/itm/Bosch-GBH4-32DFR-NEW-Multidrill-4Kg-Rotary-Hammer-With-Accessories-240V-/160648807099?pt=UK_Home_Garden_PowerTools_SM&hash=item25676a42bb
Or you could just get a power adapter. Make sure they will work for the amount of amps that the tool will be pulling.
Mar 20, 2012 | Bosch 1 916 SDS Max Rotary Hammer Drill...
Hi. I have a charger for 18v Dewalt Li-Ion (dc9130 120v 60hz) and I'd like to find a circuit diagram so I might be able to convert it to use with 240v 50hz. So I probably need the diagram for the 240v one...
most chargers will fuction on 240/50 hz, look closely at the writing on the charger, it may say. I have laptop chargers and have used the overseas with no problem, that being said, you might try contacting dewalt and asking them if you can do it. Like I said, it probably already will work without doing anything. i have seen some devices (amplifiers mostly) that have a switch on the bakc to switch voltage, ( I don't recall ever seeing a switch to change line frequecny though), hope this helps a bit
Mar 10, 2011 | Dewalt Drills
I have a 240v drill and need it converted to 110v as I can't use it at work. It is the Hitachi DC 30PC2.
Unfortunately thi sis not really possible internally, you need to purchase step up transformer 110V/115v 220V230V/240V with at least 2A rating, 50Hz/60Hz frequency and at least Watts as are on your drill, that is, I am afraid only solution to your problem. Check prices of the transformers as maybe purchse of new drill will be less expencive.
As you did not stated where you are, I cannot advice more closely where you can find these, for beginning I would suggest chasing one (step-up!) on auction sites and electrical wholesalers, tool dealers.
Aug 18, 2010 | Drills
Want to change my 110v plug on my dewalt radio to 240v
Your radio must be a import from the U.S.A. Your radio will not work on 240v YOU WILL BLOW IT UP!!! You need a step down transformer 240v to 110v to goto your radio, you will have to do a search on Ebay in Power tools. You sould notice the lead on your 110v radio is not like normal flex as its only single insulated for 110 volts.... Don't put a normal plug on or you may have to call the fire brigade!!
Nov 01, 2009 | Dewalt DC011 AM/FM Radio
My dewalt radio does not work it was a 110v and someone told me you can swap it to a 240v so i swaped the plugs and it came on for about 2 mins and then went off i've replaced the 110v plug and checked the...
sadly , chances are you blow the whole power supply on it. you should check with your local servicenter for an estimate on the repair. the units that are made for USA are 110v
Jul 23, 2009 | Dewalt DC011 AM/FM Radio
Dewalt charger
Ok, for easy way, you can just put a 1~2A diode in series of the input 240v power wire, so the after voltage would be around 120v, but for precaution it is better that you put two diode in series, it will give you same result. In addition, I have already tested it on a similar charger, it works fine.
p.s: I do have a similar one that is also 110v, I compared it with other 240v one. They worked same.
Jul 03, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Changing Dewalt charger from 120V to 240V
all i can say get a seperate step up transformer fron 110v to 220v.then just plug in charger to the step up transformer. make sure that u have 2 consider the frequency in ur country.
Change 120v chager to run on 240v
all you needs is a step tranformer from 110v to 220v ac
Nov 13, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Drills Logo
78 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
