Question about iLO 2600 Television
Wont get signal
When i turn on the tv i get a a blue screen and on the top corner it says "compontent no signal" and i cant change that video or nothing
    Problem Solver:
  • 11 Answers
You are on the tv's component input. If the button of the remote that says video won't show you the other sources on the tv do it by the buttons on the side or top of the tv that say source. Go to analog or digital depending on the broadcast you are receiving.
Posted on Jul 23, 2007
SOURCE:
My Celestial PT4266AU TV HDMI input won't read from my PS3. it just blue screens and says mo signal in top right corner. Can anyone tell me if it's something in settings or is the HDMI broken
To change the aspect ratio to default, do the video reset (while in standby (red light). Hold the power until it beeps once for turning on then once again to do a video reset)
After going into the video settings after the reset it should be there to change it. If you still don't get a picture try it on another TV. If there is still no picture you may have busted the HDMI port.
Oct 30, 2017 | Televison & Video
I keep getting a blue screen on my Insignia TV. Cable box still shows the channel and I can change channels but nothing on screen. No sound either. This TV is not even 3 years old yet.
A blue screen indicates no video signal, if you change the video input to a DVD player is it still a blue screen? If yes then the TV is defective. If no then some how the signal is being lost to the TV from whatever source you use for watching broadcast TV
Apr 05, 2017 | Televison & Video
I have a Polaroid FLM-373B 37 " tv and I get a blue screen with "No Signal" in the top corner. Cant seem to get it to find a cable signal, dvd signal or anything. I have successfully...
That situation clearly indicates that no signal is coming to the set in its present setting. Have you checked to make sure that the tv's input is set on the right input setting. Mine always defaults to "Antenna" which drives me nuts cause I get that big blue screen with "no signal". It seems to do that at the slightest provocation, too. After 5 years, I still have to think twice before checking it. If that is not it, make sure that the cables are plugged in. If that doesn't fix it try another type of input such as HDMI or S video, composite, etc - one that you are not using. Don't forget to switch the input to it. Good luck!
Nov 06, 2010 | Polaroid FLM-3732 Television
TV is turned on-only see blue screen that says Video
if only see blue screen indicate no video signal, check the yellow cable.
Apr 13, 2010 | Sanyo DS13204 TV
No sky no happy
Unplug from the main power and that should reset your sky box. If still no signal get the dish looked at by a tv aerial company.
Apr 07, 2017 | Philips Televison & Video
I have a crayola tv/dvd and it is locked.
it is blocked, go into the menu and reset the parental settings
Aug 04, 2009 | Rio Go Video DDV9475 Dual Deck VCR
Blue screen on my tv; lock on screen how do i remove it
Go to menu and look for lock function and turn off. blue screen. tv is muting video bucause it is not getting any input signal .
Apr 24, 2009 | Televison & Video
Red lock in corner of tv
blue screens are common when your set cant find a signal. might of switched it to video mode .find your menu on the remote and go to cable channels and press the autotune and should find and remember all usable channels
Feb 23, 2008 | Prima CV2011 TV
Olevia tv repair
I CANT GET THE AUTO SELECT FOR CHANNEL TO SELECT
Feb 12, 2008 | Olevia LT32HVM 32 in. LCD Television
Tv monitor turns blue during forward or reverse vcr search
On some TV's the screen will go blue if there is not a strong, solid video signal present. This is to prevent the showing of very snowy or all snow channels, or garbled, mixed-up external video signals. This is normal. On some VCR's the video signal changes when the FF or REW search feature is used, and this could trigger the TV to go to blue screen. The only way around this if you can enter the TV's menu and turn off the blue screen feature.
Jun 23, 2007 | Panasonic PV-V4020 VHS VCR
Televison & Video Logo
223 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
