Question about Tecnik Ovens
Slack oven door on Tecnik 8085
The main (bottom) door on our Tecnik 8085 oven is slack. When the door is closed there is about ¼" gap at the top between it and the seal (which I think is in good order). Can I adjust the hinges to address this problem? Is there another solution
  • Tecnik Master
  • 3,463 Answers
The hinges cannot be adjusted, the only solution is to replace both hinges.
Plz rate my comments.
Thankyou..
Posted on Jan 05, 2009
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
How do you adjust doors on imperial ICV-1 convection oven
The turnbucke system behind the lower panel is relatively straightforward but one buckle is LH thread the other is RH thread. Slacken both locknuts and adjust the buckles until the LH door lags by the thickness of the RH door when they are just coming together (a rough approximation). Don't have too much tension on the chains and lube the chains, gears etc with a copper based grease. It has been known for the little grub screws in the bottom cogs to come loose. You'll need an allen key to tighten them up.
After all adjustments check the chain 'slack' by quickly opening/closing the doors when at about 1/2 open. There shouldn't be so much that the LH door doesn't react reasonably quickly to the change of direction, but not so tight as they are like bow strings.
Mar 08, 2013 | Imperial ICV-1 Turbo-Flow Single Oven
The oven keeps beeping periodically for no reason.
When you have most of your stuff off, like early morning, switch the circuit breaker in your main fuse box on and off. This will reset the oven, and everything else in your house, so be careful. Also check the door is sealing correctly, push it in when closed to see if there's slack in it.
Thanks
Adam
please leave me some feedback
Feb 18, 2011 | Miele H 4780 B Single Oven
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
I have a tecnik tkc 1255/ss range oven serial no 0704020076 COD. 0.41019xst0sq i need a replacement main oven door handle
You dont happen to have the LPG jets that were supplied with the cooker do you? I'm having trouble getting hold of any?
Thanks,
Apr 19, 2010 | Tecnik Ovens
My oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
New world twinline 4000 oven - bottom oven door won't shut properly - looks as though the hinge(s) are too slack
You are right in thinking it is the door hinges that is the cause of the problem .they are non adjustable, so only solution is to replace both hinges.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Ovens
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Main Oven Issue??
the clock need to be set to work the main oven
Dec 03, 2007 | Tecnik TKC8525 Double Oven
Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Mar 10, 2007 | Miele Novotronic H350-2B Electric Single...
Ovens Logo
294 people viewed this question
Top Tecnik Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Tecnik Oven Expert? Answer questions, earn points and help others
