Question about Western Digital My Passport Essential SE 1TB External USB 20 Portable Black 1 TB Hard Drive
The transfer rate was really slow when pasting data into the hard drive. Transferring data FROM the drive was comfortably speedy. Tried formatting the hard drive but failed to do so. Format process starts and gets stuck at 0 per cent. Tried formatting through windows explorer and through DOS with no success.
  • 130 Answers
The best method is Right Click on My Computer then Click Manage. Then click Disk Management under the storage category. then right click on the drive and select quick format. are you trying to change the formatted type?
Posted on Nov 07, 2012
SOURCE: Unable to access external WD 500 Gb drive: "You need to format the disk"
I have battled this for a few days. Your mentioning USB leads me to a possible solution.
I had a 500GB drive and put it in the USB enclosure and could only see 128GB one time, 138GB another. I found that external drive enclosures have their own IDE controller chips with older ones limiting the size of the drive they are able to "see".
The best test is to internally mount the drive (perverts will read this differently than intended and risk injury due to shock!) to make sure it can be seen. If so then the next best step is to spring for a new drive enclosure, one that supports the higher capacity drive. It worked for me! My old external enclosure's IDE controller could not handle the higher capacity drive and the new one was perfectly happy with it. Good luck! - Andy C
Posted on Apr 09, 2009
  • 630 Answers
SOURCE: External usb hard drive wont format on windows vista
Download a free disk partition manager from somewhere and use that to format it. Western Digital used to have some disk utilities on their website which would do it so it's worth looking there.
Posted on Aug 21, 2009
  • 923 Answers
SOURCE: external hard drive not detected
Check your jumpers on the hard drive. DON'T leave it connected very long if the jumpers are not set for master / slave (furthest away/ closest to the IDE port on the computer or it can mess up the circuit boards on one or both drives! If you are using only one hard drive, set the jumper(s) for "cable select" (often abbreviated CS). If it still doesn't detect the drive, the drive may not have an "active" partition on it. You can solve that by booting to your OS installation CD -- assuming you have one!
Posted on Feb 02, 2010
SOURCE: WD external Hard drive 320 GB hangs my computer everytime connect
all solutions are not helpful, if u just use safe mode then there is no problem with hard disk, its a problem of some services, u just try with safe mode.30-40% people has same problem.
girish
Posted on Feb 05, 2010
SOURCE: Data recovery from Portable Hard Disk
There are tools that will undelete & unformat you drive.
look here for free one.
http://www.softwarepatch.com/software/filerecovery.html
and here for a selection.http://www.freebyte.com/filediskutils/
finally this one is great but costs. http://www.easeus.com/
Posted on Feb 07, 2010
How to fix slow reading, copying, and formating Transcend StoreJet 1b
You could try running a disk degfragmentation utility. That isnt going to do much though.
If the transfer rates really bother you and if your system supprots a USB 3.0 or thunderbolt interface, I'd recommend getting a new drive.
Aug 22, 2014 | Transcend StoreJet Computers & Internet
HOW TO INCREASE SPEED OF DATA TRANSFERRING.
First of all, press the Caps Lock button, it really helps.
Make sure that your PC's USB port is actually a USB 2.0 (or 3.0). There are no options to increase the speed of a flash drive, it is determined by the microcontroller used in the drive.
Jun 14, 2013 | Transcend TS16GJFV30 16GB JetFlash V30 USB...
Wd 1600 not working
Western Digital My Book hard drives use USB 3.0 and USB 2.0 speeds to transfer data from the hard drive to the computer and vice versa. When your My Book external hard drive is not performing properly or not turning on, you can troubleshoot the problem before sending the hard drive back to the manufacturer. Correctly powering up and installing the My Book are essential for transferring information and avoiding corruption.
Run your fingers up and down the power cable that connects to the back of the My Book hard drive and the wall outlet in your home. Feel for breaks or tears on the cable and replace the cable if needed. Check the pin on the back of the hard drive where the power cable meets the drive. Make sure the pin is straight and will make contact with the power cable properly. If the pin is bent, send the hard drive to Western Digital for repair. Plug a different device into the power outlet you are using to make sure it works properly. Use a device that you know powers on correctly. b> Slow Transfer Rates b> Open your computer's tower and check over the PCI adapter card that gives you the ability to achieve USB 3.0 speeds. Make sure that the adapter card is installed correctly per your manufacturer's installation manual. If the PCI adapter card is not installed correctly, you will not be able to transfer data in the 3.0 speed. Disconnect any other external hard drives connected to the system. When two hard drives are connected via USB, they share the transfer rate bandwidth and slow your transfer speeds down. Run a Windows Update to change the USB driver on your computer. Click "Start" then "All Programs" and then "Windows Update." Run the update and choose your correct USB 3.0 driver from the list. Click "Install" at the bottom to install the driver. Hope this helps.
Jan 05, 2013 | Western Digital My Book Essential Edition...
If I look through control panel the drive is recognised and appears on the list of devices but when I go through my computer the drive is no longer mapped. I do not have any backup of the data on the...
Hello bev4819 ,
Go to the Controm Panel and select " folders options \ view "
Check " show hidden files , folders and drives "
Uncheck " hide empty drives in the computer folder "
Your drive will now appear in the Computer Folder .
Best regards ,
fanaudi .
Apr 28, 2011 | Western Digital Elements powered by WD 320...
I have bought a 640GB Transcend Hard Drive.But when I was transferring Bulk Data , I got a error mesage saying that due to some I/O error the data cannot be copied so you have the option to skip...
You can retrieve your data with data recovery program.I have succeed to recover data from crashed hard drive with Tenorshare data recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash.Download a trial version and scan your hard drive for free to check out whether your files can be recovered.Luck! http://www.any-data-recovery.com/index.htm
Mar 15, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Hi, I am having problems transferring files from my macbook pro(never had this problem its like its locked out my laptop) to the hard drive it keeps telling me "The item cannot be moved because LaCie...
Yup because you formatted in NTFS yesterday on your friend's windows. only window pc's can write to the hard drive.
so you will need to reformat it under mac to mac extended.
or if you want to FAT if you want to write from both platforms.
please note that FAT file size is limited to 4GB's..
you could download NTFS write drivers for mac but it is unsafe and data can be corrupted.
Mar 11, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
External hard drive not recognized
Some of the externals have mapping issues in Windows.  Although the TB shows in devices, you may need to remap it (right click on My Computer for mapping options) and in some cases, changing the drive letter will fix your problem.  There's really no 1 definitive solution for these.  If you're unable to fix the problem by remapping or changing the drive letter, you can partition the drive to recover your data.  As far as the slow transfer rate goes, almost all externals are formatted in FAT.  This has issues of its own with safely removing devices and slow transfer rates.  I prefer to format my externals and flash drives in NTSF for more reliability.  Best of luck.
Jul 21, 2009 | Buffalo Technology Computers & Internet
Cannot transfer any files from my computer to my external hard
Did you install the drivers for the drive? Is it recognised in Windows as a device? If not, try reconnecting and Windows should prompt you to install the drivers, Assuming the drive is recognised by WIndows, then are a few causes for not transferring data. I've attached a link to Western Digital's FAQ regarding Data Transfer problems with your drive....
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_alp.php?p_sid=nCt181pj&p_accessibility=0&p_redirect=&p_lva=1017&p_li=&p_page=1&p_new_search=1&p_search_type=answers.search_nl&p_sort_by=&p_search_text=transferring+data
Several page of possible solutions are listed above.... however, you can refine the search if it is only happening when running specific apps or @ specific times. The answer you seek is located in this link. If you can provide more details on the type of file(s) you are trying to transfer and how, I'll refine the solution for you....
Jan 14, 2009 | Western Digital 250GB MyBook External USB...
Transferring info to sanDisk 1GB
Did you eject it through the software or pulled it out of the USB
This is very common the flash drive recommends that you do this so that your data is saved
(please feel free to leave a rating)
Aug 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Western Digital My Passport Essential SE 1TB External USB 20 Portable Black 1 TB Hard Drive Logo
54 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
