How can I tell if a power surge hit my laptop and ruined it? I can't even get it to boot up
  • Computers & ... Master
  • 5,660 Answers
Steven, A) One eye symbol is a sign of the Illuminati. 2) You gonna give up? Just started here. Enough of the assumptions. 3) Need to discern here; A) Not boot up. Means computer seems to turn on, but Windows doesn't show up. (I'm not a MAC man) B) Doesn't turn on. This would be your, "...there isn't even a flicker." Fan doesn't spin, LED's do not light,...nada. Now post the laptop manufacturer name, and model number in a Comment. (You could wake up tomorrow, and say, "Oh, just another day", or you could say, "I fixed my laptop.")
Posted on Nov 07, 2012
  • 130 Answers
It could either be that the motherboard is fried or the Hard drive has just gotten slightly corrupted. If you have the Windows install disk that came with it you could boot that up and then go into repair mode (press R) and then run "chkdsk /r" this would fix a hard drive issue. However if your laptop will not turn on at all when you press the power button then it is likely dead.
2 Suggested Answers
  • 3 Answers
SOURCE: Compaq Evo N600c won't boot up
Check voltage of AC adapter with voltmeter and make sure voltage matchs the output noted on the adapter and the bottom of the laptop.
Make sure the voltage is steady and not jumping all over. If you have another adapter with the same output voltage and AMPs equal to or greater than the required AMPs, try that. This will rule out the adapter if you still have the same problem.
Posted on Jun 18, 2009
Is the module of lg tv 32ld330-mb affected when theres a lighting strike???is there a chance to be fix??
The damage from a lightning strike tends to be random. Sometimes it's minor, and only a few parts are affected. Other times, many parts are ruined, or destined to fail soon as a result of the current surge.
If the strike came over the power line, the input surge protectors in the power supply should be replaced, even if they look good. It would be prudent to replace the entire power supply. If you had the set plugged into an external surge protector, that should have taken most of the hit and should also be replaced. (Some surge protector manufacturers will pay up to a certain amount for repair or replacement of equipment plugged into their products if it is damaged by lightning.)
If the lightning came over an unprotected input cable, fixing the set would be a gamble. You could end up changing a lot of modules, beginning with the main board.
Jan 30, 2015 | LG Televison & Video
Asus m4a87td Power Surge
Cup of coffee says it is the PS.. First item a surge hits and .......A mo bo will perform a test before it boots up and if all signal voltages are not present properly it simply will not boot up. Hope that your cmos did not get corrupted.
Aug 30, 2017 | ASUS M4A87TD EVO Motherboard
A power surge will usually cause a short circuit or some melting. Look inside to see if anything has been damaged.
Nov 02, 2012 | Dell Latitude C610 Notebook
Presario SR1303wm power blinking when turn on.
My best guess is that the card somehow got a surge.
Consider yourself lucky that only this card took the hit.
Since you have a surge protector, let me ask you this. Was the surge protector connected to a power socket which is earthed?
they generally come with a guaranteed protection, and as long as the surge protector is connected to a earthed socket, the manufacturer of the surge protector should be contacted and will generally reimburse or replace your product up to a predetermined maximum value.
If not, depending on the graphics card and the manufacturer's (in this case, PNY) warranty, you might be able to have it RMA'd.
Then again, in all honesty, PNY isn't the best when it comes to providing RMA service... So I wish you good luck, and I hope my answer has helped you :)
Jul 14, 2012 | HP Compaq Presario SR1303wm PC Desktop
My dell died after a power outage
If the laptop is completely dead, have the power supply charger checked for correct voltage, if power supply is no good go to www.ebay.com type make and model of laptop, refine search to power supply. If on the other hand it is okay the motherboard will need to be checked by a professional to see if it can be saved.
Jun 03, 2012 | Dell Latitude D620 Notebook
Why is my acer emachine charging blinks in red
That is a signal that your battery is almost dead or drained. If you have the power cord plugged in and the battery is not charging at all, that means the battery is dead and you need to purchase another one.
In windows xp you should be able to click Start/Control Panel/Power Options. When the power options window opens click the Power Meter tab. It will tell you if your battery is charging.
Now to isolate if it's really the battery that's dead or if it's the Power Cord that's bad. You might really be operating on battery power even though you have the power cord plugged in.
1) Turn the laptop off and remove the battery. Turn it back on with only the power cord plugged in. If it comes and and boots up ok, then your power cord is ok.
2) Turn the laptop off and this time put the battery in, but leave the power cord off. Now hit the power button and see if it boots up. If it does that means you might have a little power still left in the battery, but since it was not charging when the power cord was plugged in, the battery is bad because you verified in step one that the power cord is good.
Mar 21, 2012 | Computers & Internet
Compaq CQ4010F Desktop PC won't turn on after a power surge
You probably and lets hope so, have an Electro Static Charge Buildup on your desktop. Remove the Power Cord and Press and Hold the Power Button for 30 seconds. After 30 Seconds plug the Power Cord back in the hit the Power Button. If it boots then you had an Static Charge Buildup. If it does not boot and you say it happened after a power surge then either your Power Supply or Motherboard is possibly damaged. Do you hear fans, hear the disk drive running, see lights, hear the CD Rom click once and see the light on the CD Rom drive com on briefly after you hit the Power Button. If so it would seem that your power supply is ok.
Mar 18, 2012 | Compaq CQ4010F Desktop PC (NY650AAABA)
Hi there,pls help I have problem with this. Power not come at all..it was working fine till the we had a power outage then while the computer was on then the outage went back on my monitor just didnt work...
Hello derick, Unfortunately power surges have been known to have some pretty nasty effects on your computer hardware. If you turn on your power (may have to toggle the power button behind your computer before pressing the button, worth trying in each position just in case) and your computer doesn't come on at all. This means that if none of your lights come on AND none of your fans come on, then your power supply may have blown out in the surge. If this is the case then you can't even begin to try and diagnose the rest of your PC to see if it's working. You need power to attempt diagnostics on your other components. Even if you replace the power supply, there is no guarantee that it was the only thing that was ruined by the surge. I hope this helps you out derick, and wish you better luck in the future :(
May 15, 2011 | Computers & Internet
Power Surge Problem
Have an electrician check that outlet to make sure you got a proper 3 prong ground.  Then buy the APC surge protector.  They are made to prevent surge spikes in sensitive electronic equipment.  Take the Samsung back to the store and exchange it out before your warranty expires.  Just tell the store it don't work and you don't know why.  Don't tell them you fried the onboard power ic chip from a line voltage spike in your home.
Nov 15, 2009 | Apple iBook G3 Mac Notebook
Inspiron 9100 - will not turn on after power surge
try unplugging it from the mains adapter and take the battery out. Leave the battery out for a full two minutes then replace the battery and try turning on with battery only first. If this boots up okay then add your adapter.
Nov 08, 2008 | Dell Inspiron 9100 Notebook
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
