Question about Fujitsu LifeBookS6120 Notebook
My # key isn't typing on my lifebook A series
  • 130 Answers
Try pressing and holding the key down, and then releasing. Additionally try to blow some air under the key (compressed air is preferred). If that doesn't work then gently try to pull up on the key, usually pulling gently left or right, this will hopefully pop off the key so you can see if something is stuck underneath. once you have examined underneath then replace the key by simply snapping it back on by pressing it downward in its slot.
Posted on Nov 07, 2012
One of the linkage bars for the type bar is missing on my Royal KMM Typewriter
Depending on the size of the holes in the type bar you can make one from a thick paper clip or swap one from a little used key like ; or 1 (you can use lower case L) This isn't a perm. repair.
DickyO
May 23, 2012 | Royal Office Equipment & Supplies
Where can we order the key to change to combo?
A Df-59 key can be purchased through this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx Call them to order it @773-809-3667 Obviously it isn't really $0.
Or try this source:
http://www.ckilock.com/Mpage18.asp
The tenth item down is the key & spanner wrench for $9.
Mar 12, 2012 | Simplex Kaba Ilco Unican L1000 keyless...
Msi net book web cam not working
Hopeless? Doubt it.
If memory serves, there isn't data on the computer on how to activate, and use the webcam.
Camera icon is in blue on the F6 key.
Hold down on the Fn key, and at the same time tap the F6 key.
On the screen should be the option to turn the Camera on.
Nov 12, 2011 | MSI Wind U100-030US Laptop
HP G62 laptop the "a"
You can pull the key from the keyboard by wiggling it back and forth and pulling gently, like a loose tooth. One it's out, you can position the key back onto the spot where it belongs and then push it on. It may take a few tries, but as long as the connector isn't broken, you should be able to get it back on.
Aug 19, 2011 | HEWLETT-PACKARD Hp G62-225dx Laptop
My 2001 Sienna shakes when I apply the brake. I don't know the problem. It passed inspection so I am assuming it's not the brake. Please advise.
The car isn't driven when inspected
Your only choice is to recall, if you had the
brakes apart every year, to clean off rust,
inspect,lube & if necessary machine or replace
parts.
You can not drive year after year & not have
braking issues.
Some times the work you pay for isn't done
correctly & they put issues in there.
Never assume anything in life
Always inspect or test things,& trust no one
Jul 12, 2011 | 2001 Toyota Sienna
I've had my WDBAAF0015HBK My Book for a few months, but now I have a new computer and went to attach it but it doesn't register. I can't hear anything whirring around inside it, but the front...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jun 20, 2011 | Western Digital My Book Essential...
How do you turn the printing sound off as you type?
If you are talking about a beep on each key depression CODE "S" if you are talking about the printing noise you must have the display option, if this isn't a WW6 but a WW30 ets there is a key in the right thst says print mode.
DickyO
May 03, 2011 | Lexmark Wheelwriter 6 Series II Typewriter
I'M TRYING TO URN OFF CAPS LOCK ON MY FUJITSU LAP TOP LIFE BOOK A SERIES BUT CAN'TSEE A CAPS LOCK KEY?
Just press the key with arrow pointing down, it is above the left shift key.
Hope this will help!
Sep 10, 2010 | Fujitsu Siemens LifeBook S7010D Notebook
Fujitsu LifeBookS6120 Notebook Logo
35 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
