Question about Sylvania G-Netbook
How do i reset my computer to factory settings with a password protected windows CE netbook
  • 70 Answers
SOURCE: I can't remember my administrative
TRY TO BOOT IN SAFE MODE IF POSSIBLE OR THERE SHOULD BE A RESET BUTTON ON THE PC TRY THAT BUT BE CAREFULL U MAY LOOSE ALL UR DATA ON THE PC
Posted on Nov 13, 2010
SOURCE: How do I reset my password to Windows CE? I do
compre esta netbook y tengo internet en mi casa le instale el codigo y no logro que se conecte que puedo hacer
Posted on Jan 29, 2011
  • 1267 Answers
SOURCE: I recently purchased the Sylvania
It is looking for the password that you set your router to or network key.
couple of ways. You can reset your router, then it will default to factory settings and then it will delete your password and open itself up to not needing a password to get on your network. However, anyone can connect to your network, so you will have to enter into your networks menus and reset a password to prevent this, then set that password on all of the computers on the network now. You generally access your set up menu by typing your server IP address into your browser address bar, which is ususlly http://192.168.1.1
This is not all conclusive as some routers have other access methods, but the majority use the above. It will also require a User and a password and the default is usually admin and password or password1 for the default. If however, you have set a password then you definitely have to reset.
Reset is usually a small button , some recessed in a small hole that requires a tooth pick or un-bent paper clip to push into the hole and hold for 15 seconds with the power on the router. Sometimes turning the power off of the router for 2-5 minutes will cause it to reset.
You can also force the laptop(or any client of that server) that you are using and is connected to the internet to give you the english translation of the password. Click on your WiFi icon down in the right corner, A window opens,right click on the name of your network that is connected, click on properties, click on "show charcters." The network key(your password) will be revealed
Posted on Feb 01, 2011
  • 1267 Answers
SOURCE: /i bought a sylvania netbook has windows ce can i
No! you cannot use anything made for W7 on CE as of yet.
Please try to follow the detail below.
It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Additional Information
When I try to sign on with the red X showing, I get "The page cannot be displayed If I then double click on the icon down in the right corner I elucidated above, RT28701 opens up to "Internet Protocol (TCP/IP) with all zeros in the IP address field, and Subnet Mask, with no entries in the default gateway. That is a clue to me that the auto sign on has not found a viable network or needs something else. If I then click on Wireless Information tab, The list of available networks appear in the box. The machine keeps trying to associate my previous entered name site with my prefered site and tells me the signal is good, but it cannot link up. This is a signal to me that it has lost my Network Key or that the software has failed or both. I then click on advance and delete my prefered network and hit OK, this will force the software to ask me for my network again, and notice that the prefered is missing. I click on the name of my network again and then hit connect., then the Wireless Network properties window opens up and I can insert my Network Key again after I uncheck the "The key is provided automatically" box. I enter the key and hit the OK button. I still do not get a connection, so I reboot the machine, and wait for about 30 seconds and the machine synchs up because the little RED X under the icon has disappeared. Now the machine will hook to the internet as long as I want to, but sometimes when I turn the machine on it will not synch, so I go through the above sequence again. The secret is once you have entered your key and ask for the machine to synch up you have to reboot. Why? I do not exactly know, but I suspect that the WiFi driver looses it
You may also want to look at TIP at: http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard
  • 1267 Answers
SOURCE: reset the password for windows
If this is a SYNET07526 using Win CE, then you will have to re-flash the system in order to get rid of the password that you have forgotten. See my TIP for flashing the SYNET07526 at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Posted on May 21, 2011
Forgot password to mini netbook useing windows ce
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://www.tech-faq.com/reset-bios-password.html
hope this helps
Sep 13, 2012 | Computers & Internet
Forgot my windows ce password need to rest my laptop back to factory setting
Forgot windows password, we can use Windows Password Reset to reset our windows password.
The steps are:
Step1:Download and install Windows Password Reset from http://www.windowspasswordreset.net
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove your Windows Password
So easy,right?
Jul 08, 2012 | Computers & Internet
Forgot password on the acer netbook with windows7
Have you forgot windows 7 password?
Now, we'd recommend you a professional Windows password recovery software- Windows Password Reset as your reference.
As an easy method to reset Windows 7 password , there are only four steps as follow:
Step1: Download Windows Password Reset Deluxe and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
Jun 20, 2012 | Acer Tablets & eReaders
Password reset for Win ce on a sylvania netbook
Resetting password & user name on Windows:b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
Oct 24, 2011 | Sylvania G-Netbook
I recently purchased the Sylvania wireless Netbook whose operating system is Windows CE. On our two desktops at home both use Windows 7. My computer downstairs is wired but through the use of a Cisco E...
Jan 31, 2011 | Sylvania G-Netbook
How do I reset my password to Windows CE? I do not remember setting a password and it does not have a link that says reset your password on the netbook????
Jan 28, 2011 | Sylvania G-Netbook
Im stuck on the login page dont remeber the password wanna reset the whole thing
There are 2 things what can be done.
1. Crack the Administrative password by following the steps in the link below http://www.clazh.com/how-to-hack-or-crack-a-windows-xp-administrator-password/
2. Take the computer back to factory setting which will wipe out all the data on your computer and get your computer back to factory settings by inserting the restore disc
Jan 10, 2011 | Samsung N150 (36725723009) Netbook
Locked out of Windows CE 6.0
I have the "smartbook" Windows CE6 netbook, got it on eBay. Within minutes it failed, and would not boot up past the first screen. I complained to the seller, and was kindly sent a docx document with instructions on how to make a recovery "disk" on an SD card. This saved my netbook, and I've had to use it five times so far as the OS dumps frequently. I'm assuming all these 7" "netbooks" are fairly identical, the boot card would probably restore yours. You have nothing to lose at this point, if we can get each others' email addresses I'll snd it to you, you can decide whether you want to proceed. Are you still out there?
Feb 16, 2010 | Computers & Internet
Sylvania G-Netbook Logo
233 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
