Machine flashing f63 washing machine - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
If this is a Miele washer, open and close the door and press cancel and pause twice that should reset it.
Posted on Nov 07, 2012
SOURCE: bosch exxcel 1200 express washing
I had F63 on Bosch washing machine (Maxx 7). I waited 5 days for a repairman and all he did was reset the washing machine processor, like this: 1. Turn the program knob to 6 o'clock 2. Hold the RPM button 3. While the RPM button is held, turn the program knob 1 click clockwise (to Rinse) 4. Release the RPM button.
This is similar to F21 which also happened to my machine. Apparently both errors are related to power surge/power cut.
Posted on Nov 19, 2010
SOURCE: hi,i have a washing machine miele w 3000 tech
Mine is W3844. Miele's technician said the Wather Path Control Unit (part # 6271992) need to be changed.
Total Cost: (HKD)
450 for todays check cost
1100 for the part
250 for the labour to change the part.
Posted on Jul 16, 2010
Daniel S
  • 4323 Answers
SOURCE: I have F63 flashing on Bosch exxcel 7 washing
Hi
Error F 63 means Functional safety error. It appears when processor has broken SAFETY ERROR. To reset this error you'll have to switch ON/OFF the washer to reset the error. If the issue persists then check whether washing program is halted or aborted, if the washer doesn't advances to next cycle then you
Posted on Nov 27, 2010
  • 251 Answers
SOURCE: My Miele 1374 washing machine
heres your problem..
3.33 Fault code F63, water path control unit In normal operation mode the display shows Technical fault. The Check inlet LED flashes rapidly. The programme is interrupted. The drain pump is activated for 120 s. Cause Water path control system faulty. The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note: Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy Check the water path control system. tool1.gif?leaf=true Check the water path control system circuit for an open or short circuit, and correct insulation.
Posted on Jun 14, 2011
walesarumi
  • 6993 Answers
SOURCE: F63 is flashing on a
This is what Bosch say about it.
F: 63 Functional-safety-error - processor is broken SAFETY ERROR - switch ON/OFF for reset Normal mode:
- washing program is aborted - replace control - door is unlocked, if possible - operator control actions are blocked - the current indication is frozen Basically, it would appear that the main pcb has gone faulty. (This is the "replace control" instruction).
I've no doubt you've tried switching it off and on again. Try unplugging it for 20 mins. How old is the appliance? Bosch machines have a 2 year warranty. Good luck.
Posted on Jul 05, 2011
Siemens fd8705603477 flashing f63
this is NOT the model number
this is your serial number
F63 ive seen before on other models
and its a water intake issue
Sep 04, 2014 | Siemens Washing Machines
Fault F63
Roger
Depending on the model number - (guessing its a W48XX series) F63 is a water path fault - This is the control unit that directs the water flow to the proper path (pre-wash, detergent, fabric softener ect..... ) Sometimes and audible clicking can be heard when this unit fails as it trying to switch to the proper path as per the program being ran.
Dec 08, 2013 | Miele Washing Machines
Miele fault F63
F63 on certain washers is an indication of too much soap is being used. If you live in an area where the water is hard and your not using too much soap you have a clog in one of the hoses used for air. Try to do a hot cycle with white vinegar. On other models the F63 is indicating that the water intake valve didn't find it's position. If this is the case just run an additional cycle.
Jan 21, 2012 | Miele Washing Machines
Machine reading F63
I hope a way to delete this code from the screen
I waited for 20 minutes and stopped flashing screen
Will not disappear
Press any buttons after the screen has stopped flashing
Jun 20, 2011 | Washing Machines
My Miele 1374 washing machine just had a fehler f63 error. What does this mean and is it fixable?
Jun 05, 2011 | Miele W 4800 Front Load Washer
Bosch excel 7 with F63 error code Cleaned the
my dishwasher will not dispose of the water and remains stuck on a cycle
Nov 27, 2010 | Bosch Washing Machines
Bosch exxcel 1200 express washing machine not working, F63 flashing on display,are the brushes on the motor worn out?
Oct 25, 2010 | Washing Machines
Miele w3033 tech fault f63. what to do?
i have washing machine miele gala grande w 3000.and i have a tech fa ult f63.what is this?
Jul 04, 2009 | Washing Machines
Washing Machines Logo
754 people viewed this question
Top Washing Machines Experts
