Need diagrame for potterton composite gas valve 402923
I need a diagrame or schematic of how this valve works and details of ajustment
  • Heating & Co... Master
  • 2,460 Answers
Look on The Baxi Potterton wed site you can down load manuals there or ask there tech line
Posted on Nov 08, 2012
Schematic?
A schematic, or schematic diagram, is a representation of the elements of a system using abstract, graphic symbols rather than realistic pictures. A schematic usually omits all details that are not relevant to the information the schematic is intended to convey, and may add unrealistic elements that aid comprehension. For example, a subway map intended for riders may represent a subway station with a dot; the dot doesn't resemble the actual station at all but gives the viewer information without unnecessary visual clutter. A schematic diagram of a chemical process uses symbols to represent the vessels, piping, valves, pumps, and other equipment of the system, emphasizing their interconnection paths and suppressing physical details. In an electronic circuit diagram, the layout of the symbols may not resemble the layout in the circuit. In the schematic diagram, the symbolic elements are arranged to be more easily interpreted by the viewer.
Schematics and other types of diagrams, e.g.,
Transit map, a schematic map (i.e. not drawn to scale, stations are equidistant, lines are drawn at 45 and 90-degree angles)
Schematic of a drive train
Chemical engineering schematic
exploded view of a 3D-engineering drawing
Jan 22, 2016 | Computers & Internet
Need a wire schematic for a deep fryer gas valve elite efs 40
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 28, 2015 | Imperial EFS-40 - Gas Elite Deep Fryer -...
How can I download an installation guide for potterton ep6002 programmer
Unfortunately unless you are trained as an installer of Potterton equipment you will not be able to get any advice from Potterton, they don't even supply direct to trade, everything is supplied through nominated suppliers, ie; Plumbers merchants.
This programmer should be quite easy to install I would have thought, in general all remote programmers have a mini wiring diagram on the back of the unit, though this will only show connections for the programmer outputs, ie heating on/off and water on/off.
If you require a wiring diagram for a complete heating system, you need to know the type of heating plan you have/are installing.
Hope this helps, if you need any more info get back to me.
I have just googled this and you can actually purchase from Amazon (not that I would do myself, I would use the merchants) there is a wiring diagram on the site. Just google Potterton EP6002, it comes up straight away Good Luck
May 23, 2014 | Garden
Need Manual
Try the baxi potterton wedsite you can down load manuals there or they have at tech line
Nov 24, 2012 | Heating & Cooling
Diagram of carb to ajust the screws to make mortor work right
!. or
2.
Are where you might find details since you have not mentione make/model of your motor.
May 10, 2012 | Motorcycles
Potterton wiring diagram
Look on the baxi potterton wedsite you can down load mauals for your potterton or e-mail there tech line .
Feb 10, 2012 | Heating & Cooling
Ihave an old potterton netaheat 6/10 the pilot will light but main valve won,t open it was working fine until we had several power cuts any ideas thanks
Sounds like your gas solenoid has failed, you need to contact a gas safe engineer to fit you a complete gas valve and carry out the safety checks required.
Jul 13, 2011 | Heating & Cooling
Replacing an ST699 with a ST9400C following repl wiring diagram, but programmer does not come on. Is the diagram incorrect? Wiring colours do not follow any of the plans. Syst has room stat, cyl stat,...
Disregard wire colors. Instead wire by terminal designation. In other words :
Wire on "R" Terminal on old thermostat to "R" Terminal on new thermostat no matter the color.
Jun 14, 2011 | Honeywell Heating & Cooling
We have a gas whirlpol that was converted to
on the gas valve there is a orfice a pin hole you can ajust the size of the orfice by tighting the ajustment a little a 1/4 turn . it is on the valve where the gas gos out to the bunner usualy a 1/2 in open wrench fits on it its made of brass you have to open the top to see it there is also a air ajustment where the bunner fits over the gas valve orfice if the flame is red open it more if its to hot close the air a little make the flame red then turn the gas down tell its blue agin
Oct 20, 2009 | Whirlpool Ovens
Heating & Cooling Logo
131 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
