Question about Dishwashers
Bosch SGS3062GB not filling
The timer does not advance at all - the machine sits making a whirring noise, but does not fill with water. The previous cycle seemed to drain OK. Are there any repair manuals for these dishwashers? Also, does anyone know how old this model is, it may just be time for a replacement!
  • 1462 Answers
SOURCE: dishwater fills with water, hot...but doesnt wash?
when in the wash phase, listen for a low hum near the wash pump. if you hear this it indicates the wash pump capacitor is faulty or something jammed in the pump.after that you will have to access the wash pump and check if there is any supply to it
Posted on May 04, 2007
  • 641 Answers
SOURCE: DISHWASHER WONT FILL WITH WATER
I don't think that the problem is relates to the leaking water. Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Posted on Sep 10, 2007
bigg t
  • 640 Answers
SOURCE: Dishwasher tub slowly fills with water after after completion
the internal parts of the valve are sticking open randomley.the diaphram/piston in the valve most likley have lime deposits on it due to poor water quality.you would need the water valve assembly but before you buy this part i would look where the water line goes into the dishwasher and it will lead you to the valve.remove the valve from the unit and disassemble the valve.clean all the internal parts in the valve and reinstall.75% of the time this works ,if not change the valve.
Posted on Jan 24, 2008
  • 276 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
Machine fills and water just sits.
if the timer doesn't advance from either position,then its your timer motor and you will need to trace the power to the motor off the timer,if it has power then the motor is defective and you need to replace the timer unit
Apr 30, 2010 | GE WDSR2080D Top Load Washer
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Problem with a indest wil143s
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 06, 2009 | Washing Machines
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Whirlpool WTW5800SW doesn't always agitate
Sounds like you may a bad lid switch. Do you hear any clicking noise when the lid gets shut. The clicking noise is the lid switch activating.
Dec 26, 2008 | Whirlpool WTW5800SW
Machine fills with water & then clicks but goes no further. It will drain but no other function seems to work
That is probably a problem with the timer.
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Oct 11, 2008 | Bosch Washing Machines
    Ammana nav8805e
    If your washer fills but the timer cycle doesn't advance-replace the timer. If your washer fills the time cycle advance, and still not agitating your agitator is at fault.
    Sep 02, 2008 | Amana NAV5800A Top Load Washer
    Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
    Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
    May 23, 2008 | Kenmore Washing Machines
    Cycle will not start
    sounds like your machine is not taking in any water at all, which is the first thing the dishwasher wants to do on all programme settings.The constant whirring noise you refer to will be the water valve trying to take water into your machine.As yours isn't filling in the first place the programme cannot progress without water and it will just sit there whirring.Anyway, to resolve this matter I would check the fill hose which goes from the back of machine to your cold water pipe in your kitchen/utility, in case somebody has turned off supply.where the flexi hose meets the copper supply pipe there should be a thumbturn shut/open valve, turn this 90 degrees or a quarter turn and if you here a rush of water for a split second then you have fixed it.At this point try setting away a programme to see if water is going into dishwasher. If not have a bucket ready and unscrew the flexi hose altogether to make sure water is travelling past shut/open valve.If not you need a new shut/open valve.If water is able to pass this valve reconnect to dishwasher turn shut/open valve a quarter turn to open flow of water again,test machine on any programme again ,if it fills then your sorted, if not it must be your dishwashers internal water valve that will need replacing.Not a major job (located behind fill hose) but make sure electric and water supplies are off first before dabbling and write down your machines make and model number before shopping for part. GOOD LUCK.
    Aug 07, 2007 | Baumatic 18 in. BFD46 Free-standing...
    Dishwashers Logo
    76 people viewed this question
    Top Dishwashers Experts
