Question about Ricoh Aficio 2228C Copier
I have an Ricoh Aficio 2228C machine with an error code SC386 please let me know what is wrong.
I can override this by turning it off and on but when i want to do double sided it only prints on one side but the other side is too feint to read.
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Posted on Jul 17, 2008
  • 10 Answers
SOURCE: ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Posted on Nov 05, 2008
  • 990 Answers
SOURCE: Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Posted on Dec 17, 2008
Bubbabear64
  • 2794 Answers
SOURCE: double sided is no longer an option with mac os 10.5.4
Go into the advanced settings of the driver and look for the settings that tell the copier what features you have. Make sure the duplex is turned on. Normally I set these up for Windows use and I have one client who uses a Mac and he did show me that the features do exist for the print driver.
Once it is enabled the double sided printer feature should work.
Posted on Jan 02, 2009
How do I locate a driver for a Ricoh Aficio 2228C?
http://support.ricoh.com/bb/html/dr_ut_e/re/model/c32_38/c32_38en.htm
Sep 22, 2014 | Computers & Internet
Error code sc393-01 functional problem within copier
Black TD sensor problem, check development unit connections
Feb 24, 2014 | Ricoh Aficio 2228C Copier
Question about my color copier
Replace the yellow drum unit..... Or have your service person come out and do a general cleaning on your copier.. Good Luck
May 06, 2013 | Ricoh Aficio 2228C Copier
What does trouble code "SC
Hello Ryan,
It means your device went thru a self check in an effort maintain optimum copy quality. Your device could not get Magenta (pink/red) to even get close to the target values for that color. The most likely cause (and we hope so) is the Magenta development unit is toast. Replace it. But of course there are a myriad of other fun causes. As a sidebar, you might want to consider replacing yellow and cyan at the same time as they tend to croak at pretty much the same time. You have a quite reliable device as a rule. It's worth the cost. Take care. Let fixya know I helped ya please. SPINAL
Jun 18, 2011 | Ricoh Aficio 2228C Copier
The copier is showing an SC623 code error.
Check that the cable unit duplex reversal is connected.
Replace the PSU if no power is supplied to the devices.
Replace the control front and back of the unit of inversion.
Jun 08, 2011 | Ricoh Aficio 2228C Copier
How to access sp5 on 2228c when changing developer unit
the only way I can help you is to give you a service manual.
The service manual is for 3800C but it`s the same machine.
You can download the manual by clicking HERE.
Jun 06, 2011 | Ricoh Aficio 2228C Copier
In aficio 2228c the error code sc471...??
The unit of the transfer belt is not installed properly
Sensor defective transfer belt
Problem of unity of the transfer belt
May 25, 2011 | Ricoh Aficio 2228C Copier
How do I replace a drum on a ricoh aficio 2228C
It very easy...:) if you have a drum in hand.
Open the front cover. Lift one big green handle. Untainted 2 big black screws and open the drum cover. There you will see four groups of drum+development unit. Pull out the needed drum and pull in the new one. Then close all covers and that's all
pifonski
Mar 01, 2011 | Ricoh Aficio 2228C Copier
On the Ricoh cl 7200 there is an error code sc386. What is it?
sc386 = an error with the black developer. This could be caused by something in the DV unit itself, or the black toner. If you've just replaced either one of these recently, try reinstalling them and resetting the machine. Otherwise, the black development unit probably needs to be replaced.
May 20, 2010 | Ricoh Aficio CL7000 Laser Printer
How to reset the RICOH AFICIO 2228C
What do you want to reset ? is it giving you a service code ?
Aug 13, 2008 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2228C Copier Logo
120 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
