Question about Packard Bell Easynote Tk85 Laptop Motherboard Mb.br702.001 Mbbr702001
Amber light flashes and laptop wont power up
Every time i press the power button an amber light flashes (with the picture of a light bulb) and the laptop wont power up
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
The ready light is flashing green then amber. What does this mean
This lights pattern means the waste tank needs the blotter replaced.
Then once replaced, the tank reset needs to be performed.
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and release the Resume button
4. Press Resume button 2 times then release BOTH buttons.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Jun 15, 2010 | Canon i950 InkJet Photo Printer
The amber light on the power supply on my HP 550 laptop is flashing 8 times when i press the power button.it does not start ....
This is taken from page 11 of the user's manual (http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01627018/c01627018.pdf)
Blinking amber: A battery that is the only available
power source has reached a low battery level. When
the battery reaches a critical battery level, the battery
light begins blinking rapidly.
In other words, attach the charger to the laptop and let charge for at least 1 hr before trying to restart your computer.
Mar 24, 2010 | HP Business Notebook 550
Canon i9950, Operator error,5 amber blinks
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 02, 2010 | Canon i9950 InkJet Printer
Do I need a new print head?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
8. Your printer should respond as normal.
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
Toshiba satellite pro 4200 wont start,just 1 flashing amber light
I had a similar problem on SatPro6100. Mine was LSSSLSSL (10010001).
Thinking that the laptop was buggered I decided I would take it apart and have a look at the insides.
Whilst it was apart I also disconnected the BIOS battery.
Couldn't find anything that looked like it had burnt out so put it all back together again.
When I turned it on again the darn thing was working fine!!!
Go figure!!
The whole thing was apart for about 2 hours or so.
I don't know if it was removing the main battery and leaving it out for that time or whether it was resetting the BIOS (by disconnecting its battery) that fixed the problem.
Anyway, I have managed to get all my data off the laptop so not too worried if it screws up again.
I do however always disconnect the power source BEFORE shutting down the laptop and only reconnect it after I have pressed the on button. Seems to be working fine (for now!)
Hope that helps someone out there!
Mar 11, 2009 | Toshiba 20GB 5400 RPM NOTEBOOK HARD DRIVE...
MY SONY LAPTOP WONT BOOT
The flashing amber light means the screen is in power save mode. Since you are not seeing a "No Video Signal" things are looking up.
You want to use the menu buttons on your screen to navigate through and locate the power save time out settings. Its best to set it for 'never'.
If that makes the change a fix, let me know, I'll guide you through the settings on your desktop display to control the display time out.
Regards,
Worldvet
Jul 24, 2008 | Computers & Internet
Packard Bell Easynote Tk85 Laptop Motherboard Mb.br702.001 Mbbr702001 Logo
88 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
