Question about TurboChef TORNADO Electric Oven
My toaster showing f5 mag temp and it only toast for 6 seconds then stops any ideas???
The problem is that my toaster only heats for 6 seconds only and it give flash note F5 meg temp
    New Friend:
    Problem Solver:
  • 6 Answers
Assuming its been fixed by now.
thermal-couples on mags trigger at 160F i believe.. forces shutdown for safety.
possible causes..several
mag fan working?
EC fan working?
mag cooling fins packed with dust?
wave guides full of crud causing arching?
mag tip burnt?
faulty mag thermal-couple, unlikely
Posted on Jan 05, 2013
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: F5 - Mag Temp
Hi. this is a control fault. the board has lost the ability to communicate its commands to the temp relay. the sensor is also not working. Due to this malfunction, the control board cant regulate the temperature correctly and you will have to replace the board and temp sensor and relay in order to restore this oven to optimal performance.
Please rate and god bless:)
Posted on Apr 03, 2009
  • 6 Answers
SOURCE: TURBOCHEF TORNADO OVEN...Errors F3 Mag Current and
the mag's only activate while in cook cycle, it will be hot as normal with toasted subs that are cold in the center.
AMP draw the Mag's and ohm the Mag thermal couples
Posted on Oct 26, 2010
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
I have a turbo chef oven, I have F1 and F5 error on the display! Any suggestion?
Troubleshooting...
Faults Requiring Service Call
If one of the below faults appears on the oven display, call 800-90TURBO (88726) or +1 214-379-6000.
* F1: Blower
* F2: Low Temp
* F3: Mag Curr
* F4: Monitor
* F5: Mag Temp
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 01, 2011 | TurboChef TORNADO Electric Oven
Black n decker convection/toaster oven, no power at all. it just stopped working. I have it apart, any ideas to check
Heating element has stopped working. I suggest replacing the system, (unless you want to burn your house down.) If this is not replaced properly, you could very well do just that! :)
Nov 15, 2010 | Ovens
My general electric stove oven does not turn on.. code come out f7 and 5 6..what does t mean
F4
or
F5 Humidity sensor open or shorted Replace humidity sensor. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe.
Nov 06, 2010 | Ovens
TURBOCHEF TORNADO OVEN...Errors F3 Mag Current and F5 Mag Temp just began. They appear occasionally, now and then. Oven temp seems about right to me. What needs replacing or attention? Thanks!
Oct 14, 2010 | TurboChef TORNADO Electric Oven
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Turbochef Tornado doesn't always heat food internally
you could have a problem with the microwave circuit. That would really be the only thing preventing the food from heating internally. I would call turbochef and call for warrenty service again. Is the bread comming out nice and toasty. If the blower for the convection circuit is weak or sticking this also cause the same effect of not properly cooked food.
So check microwave circuit and also check the blower.
Hope this helps if you need more in depth advice feel free to ask
Feb 15, 2010 | TurboChef TORNADO Electric Oven
Turbochef toaster oven cc temp on warm up only 265 deg ir 465
if your a commerical oven tech then just call 1-800-90turbo are you getting an error code i would probably check the convection circuit first starting with the blower motor and checking if the Windings are ok
Dec 12, 2009 | TurboChef TORNADO Electric Oven
Flashed F5 when temp is heating up
HI, this code is signaling that your temperature sensor is malfunction. it will result in major damage to the control board and sensor wiring harness if it is not corrected soon. the will allow for high temps during the cleaning process that will ruin the ovens control circuit board.
replace the oven temp sensor soon.
May 19, 2009 | Kenmore 47834 / 47832 / 47839 Electric...
F5 - Mag Temp
Apr 03, 2009 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
445 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
