Question about Dryers
I have a Hunter fan model 21526 and I think the reciever is out. I downloaded the manual and it say the remote is a model 27187 so I went and bought it from lowes but when I took the fan apart the reciever is not the same, it is round and the one in the fan is rectangle. The manual for 21526 shows a fan that looks nothing like mine. The one I have looks more like the model 22434. Any suggestions?
SOURCE: ceiling fan
hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
Posted on Nov 25, 2007
  • 323 Answers
SOURCE: Remote not working fan...
You can get them a Home Depot. You may have to buy the receiver and the remote together.
Posted on May 26, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
  • 57 Answers
SOURCE: wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Posted on May 16, 2010
macdirk
  • 116 Answers
SOURCE: I dropped my remote and
There should be a series of little jumper switches (usually 4 white I think) inside the remote that should match the fan. sometimes you can get to from the battery cover, sometimes you have to unscrew the remote case. The instructions should mention this. Not sure if the fan itself has switches, or just hard set. Either way that's only 16 combinations to try.
Posted on Sep 20, 2010
Bought new remote& reciever,how to install it
What model of fan do you have? It's a 5 digit number starting with a 2.
Jul 23, 2013 | Hunter Ceiling Fan Remote Receiver...
How can I get a replacement remote for my Hunter Douglas fan
Your original remote is discontinued. One of these Hampton Bay remotes should work for you.
Feb 20, 2012 | Hunter 27187 Remote Control
Red light does not come on when buttoms pressed ,even with new battery,an I obtain a new remote?
Hi and welcome to FixYa, I am Kelly
Kmart and Sears both have replacement remotes for Hunter Fans.
Look on the back of your remote for the model number and you can search
http://searspartsdirect.com using a model search for a replacement.
You can also call the Hunter Fan Company to find out the model of your remote here:
1-888-830-1326. They will ask for the model number of your fan.
The Hunter remotes for the original fans can be one of these 3 models: 27187, 22691 or 27189.
See if you can find one of those 3 numbers on your remote.
Thanks for choosing FixYa,
Kelly
Apr 25, 2011 | Hunter Designer's Choice 5-Switchblades Lg...
Hunter ceiling fan
The usual house wiring for a ceiling fan with two wall switches , is white to white, black to black, and red to the other wire, usually blue or black striped with blue. If this fan has a remote , then it usually only requires one power wire, black and the white neutral.
May 03, 2010 | Hunter 27187 Remote Control
Light turns on by its self
When this happens, providing it isn't a neighbor playing tricks, on you. It is nearly always the Receiver, front end glitching, and it makes the unit think, it is receiving a signal. You need to replace your controller box, if possible. Try a "Reset" remove power to the Controller, leave off for a bit, reconnect power, if that doesn't clear it, then go with the bad controller. Sometimes it can be interference.
Apr 03, 2010 | Hunter 27187 Remote Control
Light won't work on hunter fan with wireless remote
probably your lights are blown replace them.good luck.
Feb 28, 2010 | Hunter 27187 Remote Control
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Installed new hunter westminster and the lights work but no fan. and how do i get my hunter remote to work with fan?
begin by unscrewing one wire nut at a time to be sure that the wires are tightly twisted together before the wire nut is reinstlled. Once you have the fan working manually, the remote will also work.
Jan 07, 2009 | Hunter 27187 Remote Control
Quit
if you get in touch with hunter they will send you a replacement reciever for you unit if its not discontinued
Jan 21, 2008 | Oasis Hunter 54' Ceiling Fan
Dryers Logo
59 people viewed this question
Top Dryers Experts
