Question about Fun Rise Tonka Mighty Motorized Side Loader Sanitation Truck with Figure
Lost Tonka part
My son has a Tonka Mighty Motorized Side-loading sanitation truck. He adores it, but the removeable "fork" that attaches to the motorized belt and holds the garbage can has gone missing. He's devasted. I've e-mailed Hasbro, which referred me to Funrise. Funrise said they don't have parts or even the product itself available. This is a brand new toy. Any suggestions on where to get a replacement part, short of buying a second garbage truck?
I can't tell you how to get a replacement part (Funrise was SUPREMELY unhelpful for me, too), but we devised a solution for our broken truck.....cut a black hair elastic and thread it through the two holes of the part that would hold the fork. Tie a knot so that it sits inside the little cavity inside that part. Your kiddo can then attach the garbage can to the lifting mechanism by using the elastic--works almost as well as the fork. Hope this helps!
Posted on Dec 03, 2009
How do I replace the lost controller for my Tonka ricochet 4x4
Hello there,
Always try the manufacturers first. 'Funrise' own Tonka.
These are the people who sell tonka and they have a 800 number you can ring.
As they are the people who make it, I am sure they will have one.
http://www.funrise.com/customerservice/default.aspx
Sep 19, 2014 | Hasbro Tonka Ricochet 4 x 4 Radio Control...
Mighty wheelz jeep rear axle too short
I had same problem. Turn the mighty wheelz on its side
and the rear axle will be long enough to attach the wheel cap.
Dec 24, 2012 | Jeep Mighty Wheelz 12v Ride-on Child Car...
I thought the batteries were dead but the truck seems to have died - the batteries are fine - any ideas?
Hi Charlie :) Couple of questions;
1. How old is your son
2. Is Charlie allowed to get wet (check warnings on box or manual)
3. Did you buy it new from an authorized reseller?
I could not find warranty information on Chuck specifically but Tonka in general has a lifetime warranty. According to amazon.com, it has been discontinued. But all is not lost - Chuck is licensed to the following company who is recommended by Hasbro to contact regarding Chuck products (Chuck not working, etc.). See if contacting them will get you some results.
The motorized Tonka items are licensed to the following company. They manufacture, distribute and support the products. Please contact them for further information:
Funrise Toy Corp.
7811 Lemona Avenue
Van Nuys, CA 91405
Phone: 800-882-3808 (U.S. only)
Phone: 818-883-2400
Jan 10, 2012 | Hasbro Playskool Tonka Chuck Talking Truck
I need a clamshell bucket for a Tonka Mighty Crane 758
Only thing I can offer is a link to a current eBay listing for the whole thing.
http://cgi.ebay.com/Vintage-Steell-TONKA-Mighty-758-Large-CRANE-Working-WoW-/300573398306
The only other thing I can offer is a link to Hasbro's Parts Order form:
http://www.hasbro.com/customer-service/orderform.cfm?sku=91046
And you can always call them to see if they can provide the part number even if they don't have tthe part.
http://www.hasbro.com/customer-service/phone-directory.cfm
Good luck :)
Dec 26, 2011 | Hasbro Tonka Toughest Mighty Crane
I am unable to uninstall Tonka search and rescue 2 from my pc, I am running windowsxp
Try the following steps to uninstall that game to your computer :
1. Go to START 2. Click on Control panel 3. Select Add/Remove program 4. Wait for it to load all the programs/application installed on your computer 5. When it is done, find Tonka search and rescue 2 and click remove 6. A window will prompt you if you are sure about uninstalling the program click "yes" 7. A window will then appear again confirming the removal of that game
Hope this helps.
Mar 09, 2011 | Hasbro Interactive Tonka Search and Rescue...
I have the tonka chuck rumblin dump truck an my son tore up the manual an i cant find where the batteries go
The 'talking Chuck truck" is not layed out that way. The retaining screws are found in the tail lights. Undo them and gently pop up the cover to remove. It takes 4 "C" cell batteries.
Nov 07, 2010 | Playskool Toys
I need to adjust the clutch on a 1995 standard mighty max mitsubishi I changed the clutch disc, pilot bearing, throw-out bearing and pressure plate, but the clutch stays against the fly wheel when running...
You will need to turn the cable adjuster so there is only about 1/8 inch of free travel of the cable where it attaches to throw out fork before it starts to move the fork. Once the throw out bearing is achieving its full travel the clutch should release and enable gear selection.
Don't forget to rate this post !!
Oct 11, 2010 | 1995 Mitsubishi Mighty Max
I lost first and second gear in my manual tranny
broken 1/2 shift fork or sheared roll pin. might be able to pull boot up, remove shift cover plate and if your lucky it's just a sheared roll pin, if fork is broken needs trans removed to repair.
Feb 27, 2010 | 1993 Mitsubishi Mighty Max
I just purjust a cd game for my son called Tonka search &rescue2 and it will not load into my new computer
check for the specs or requirements needed for you to be able to run the software, if it match with your pc specs then it would work, or there might be a need to install direct X or java, please check what it is asking for you then have it installed first before running the program
Aug 20, 2008 | Computers & Internet
Fun Rise Tonka Mighty Motorized Side Loader Sanitation Truck with Figure Logo
856 people viewed this question
Top Fun Rise Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Fun Rise Toy Expert? Answer questions, earn points and help others
