I need to know what hardrives are compatible with my computer
I need to replace my sata hard drive for my desktop computer,and i was wandering,could i purchase any sata hardrive eg sata,sata2 or does it have to be the exact same harddrive ie model number as the one i already have installed?My computer was also a home built one.thankyou : )
  • 57 Answers
You can buy any HDD/SSD as long as it has some sort of SATA connection. The differences between SATA, SATAII, SATAIII are mainly speeds. But all will be recognized by your machine.
Posted on Nov 07, 2012
Testimonial: "I got a helpfull,detailed & fast responce. 10/10 :)"
  • Jenny Wood Nov 08, 2012
    Thankyou very much : )
sandrew
  • 2961 Answers
SOURCE: Sony VAIO PCV-RS720G - Hard Drive
kept trying Asus for your board details but their site was down,and also need to know socket type, but you may need to upgrade your bios to support large drives. You can find the motherboard support site here:- http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on May 09, 2007
Sunil Panem
  • 80 Answers
SOURCE: help my second hard drive dont show up
Hi
Make sure it is connected properly.
Then go to Disk Management by typing "diskmgmt.msc" in the Run window.
Then check in Disk Management if there is any unassigned or any uninitialised partition there.
If you find one, right click on it and then select either "Format" or "Initialise".
Posted on Mar 05, 2008
iqbal_del
  • 655 Answers
SOURCE: I need to put a
There are two ways to do that:
If you have a floppy drive attached or you may attach to your lap then.
  1. Goto your Motherboard manufacturer's site and download AHCI driver.
  2. Expand this file (it may be auto extract or zipped) in to floppy disk.
  3. Then start setup normally, keep constant eye on bottom of setup screen you will find a message like 'Press F6 for third party RAID driver'
  4. At that time press F6.
  5. Setup will ask you for the floppy, insert that floppy in the drive and follow the instructs.......
If you don't have floppy drived attached to your lap then.
  1. download the driver and expand it in any folder.
  2. use nlite software to split the driver in windows setup disk.
  3. burn the new splittered setup to cd.
  4. run setup from that CD that will read your SATA drive.
If any problem just Ask me.
Thanks
Iqbal
Posted on Apr 20, 2008
  • 3940 Answers
SOURCE: REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
Posted on May 19, 2008
  • 653 Answers
SOURCE: Acer AM1201 SATA Optical Drive Installation
Normally when u purchase the SATA DVDRW, they also provides u the SATA data cable...
Installation is very simple, just plug the data cable and power cable, power on your pc. That's all.
Posted on Mar 07, 2009
Xerox 7435, got from company who pulled out the hard drive, so I am missing hard drive and the OS, how can I get in going?What type of hardrive do I need?
Hi Arthur
Look at the cable that would connect to the hard drive.
The Data side is either SCSI, or ATA or SATA.
Look these up on Google and see what matches.
All modern Hard Drives are 3.5" for desktop computers or 2.5" for laptops. Visit a site such as OWC (Other World Computing) to purchase a drive.
Only Xerox would have the OS unless you know where there is an old copy.
Check out
https://www.google.com.au/?gws_rd=ssl#q=xerox+7435+specs
Sep 09, 2014 | Xerox Workcentre 7435 Color Multifunction...
Why the hardrive was wobbling while spinning and i can not access the hardrive?
Friend it is might just get corrupted or brocken check it quickly change it. This brocken hard drive can harm your system, what ever you do do it quickly.
Aug 26, 2014 | Western Digital HDD WD2002FAEX Caviar 2TB...
Computer doesn't boot 'no boot device available" it cant find the hardrive it says sata 0-none sata 1-none sata 3-none sata...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 17, 2011 | Dell (Y3392) 80 GB SATA Hard Drive
Runing out for hardrive, can I just add more hard drive. 120gb and want to go to 3-500 gb. Can my model handle it? sr1215cl
According to the specifications, the motherboard supports two PATA hard drives and two SATA hard drives.
You can install SATA hard drives to any capacity you want.
Nov 07, 2010 | HP Compaq Presario SR1215CL (82916052980)...
Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Nov 14, 2009 | HP Compaq Presario V2000 Notebook
Computer hardrive
If your old hdd is a SATA drive you can install it as a secondary drive in your new computer. All you would need to do is install the drive, hookup the SATA data cable and power cable, & boot up. You can then move the data you need to your new hdd. If it is an older IDE drive you would need to set the jumpers to slave[sl] or cable select[cs] depending on what your new system requires. Hookup the ide ribbon cable and power cable from your power supply. Good luck & I hope this helps.
Jun 01, 2009 | Northgate (STAX2517C2) PC Desktop
Hard drive compatible with gateway 300xl desktop computer
I think there is no SATA ports on its mother board. So SATA Hard disks cannot be used on this system.
Without any dobt you can use PATA (the one that we used to see everywhere) can be used. There is no question of compatibility; any size 80,or 160 GB or even more can be used.
Dec 18, 2008 | Gateway 300 X PC Desktop
What is the hardrive used on the Acer Aspire L100?
JFontes,
Your PC has a 160Gb Serial ATA (SATA) drive.
Any SATA drive should work for ya. 160 Gb is a good sized drive, so IF you have room in the case you may want to just ADD a drive to the PC instead of replace the existing one.
According to the specifications for the PC you should have 2 more SATA connectors.
Hope this Helps you.
Dave
Nov 26, 2008 | Acer Aspire L100 PC Desktop
Replacement HD
Do you know if it is SATA or IDE? If you look at your hard drive, an IDE will have a wide cable connected to the back of it. If it is SATA, it will be a small cable that connects it to the motherboard. I think it is SATA. But nonetheless, depending on the size of the hard drive you want, you can get decent hard drives in the $60 range at www.tigerdirect.com.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 12, 2008 | Dell Dimension 2400 PC Desktop
Hard drive
Try going into setup and make sure the computer know it is there.
Dec 16, 2007 | Dell OptiPlex GX150 PC Desktop
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
