Question about Garden
Need piaston and ring - Garden
  • Garden Master
  • 2,478 Answers
On what
Posted on Nov 10, 2012
How seup fax ring
Before selecting the ring to answer, under stand what it is..
Press Menu button, scroll to fax set up with help of arrow keys, press ok button, scroll to answering mode. Select desired "auto, manual, fax & tele/fax.
What are these?
Auto: Auto aromatically tele mode will coverts in to fax mode irrespective of selected ring count. suppose if ring count selected as 4, printer will ring 4 times then stops ringing & converts in to fax mode. It doesn't matter whether it's telephone or fax.
Manual: Printer always telephone mode. To convert in to fax mode, need to press fax button while ringing.
Tele/Fax: Printer detects the incoming call type as tele(analog)or fax(digital) accordingly its will act. If its fax , line converts in fax mode with out any ring(silent detection), prints the received fax.If its telephone,printer rings as tele phone.
* In auto mode only you need to select desired ring to answer(2-6 rings)
There fore first you need to select "auto"mode, then scroll to ring to answer, press ok then select desired ring count, press ok to confirm..
Aug 23, 2014 | HP LaserJet 3050 All-In-One Printer
Wats d gap in rings and n how many kms does the engine has to run
A general rule of thumb for ring gap is .003 " per 1" of bore. Example 4" bore minimum gap at bottom of cylinder for the ring is .012". IF fitting new rings then push the ring to the bottom of the bore ( smallest dia.) and measure the gap . nothing under .010". Max ring gap at this point should not exceed m.025" and if the gap exceeds this then the sides of the rings will have sharp edges from wearing on the piston lands.. The distance travelled depends on the service interval and the air cleaner being used as a dusted motor will need new rings within 15.000miles. and a well serviced motor can exceed 150.000miles before the rings need replacing
Apr 21, 2014 | Cars & Trucks
Jacuzzi tara o ring
What is the o-ring used for? Where is this o-ring located and what is the function of the o-ring?
US Parts Center
Mar 09, 2014 | Jacuzzi Tara, Whirlpool Bath -...
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
How do I undo the delayed ring on a toshiba dk2010sd phone?
just check your ring tone settings check whether u have selected vibrate then ring settings..if so change it to ring..try this....
Nov 22, 2011 | Lands Phones
What is the piston ring gap clearance for the ford laser
Which Piston Ring Gap? First of all you need to purchase a Hayne's Manual for your car. It will give you the specifications under the Engine section of the book. The piston has three rings on it. From the top you have your first compression ring, then your second compression ring (these "clearance" specifications or "gap"), should be the same as measured on the piston insofar as the clearance between the "lands and grooves" or between the ring and the piston groove. The third ring is your oil control ring which will have a different clearance between (for example), the top of the ring installed and the piston's groove. Then lastly, you need to place the compression rings and place them in the bore of the cylinder WITHOUT being installed on the piston. A measurement is then taken between the opening gap of the ring while in the block. To make sure it's lined up properly, invert a non-ringed piston down into the bore from the top to make sure the ring is installed at the same depth all the way around.
If you don't want to buy the Hayne's Manual, just stop by your local Dealership and get the Specifications for the two compression rings, the oil ring and the "installed" clearance or gap on the rings.
Hope this Helps,
~00 Buck~
"Still living on the Right Side of Dirt..."
May 18, 2010 | Ford Laser Cars & Trucks
Trying to locate an O-Ring for the rear shock
I suggest contacting Pro Circuit or Race Tech. Both have the part you need.
May 11, 2009 | 2005 KTM EXC 450 Racing
Piston rings
First, be sure they actually do fit the bore. Take a ring and insert it in the bore. push the ring halfway into the bore using the piston. There should be about a 1/32" gap in the ring. Anything more than 1/16" and you need rings the next size up. If the ring won't go into the cylinder because the gap fully closes, the rings need to be a smaller size.
With the correct size rings, put them on the piston. Some pistons have an index pin in the ring groove Fit the gap to the pin. Put the piston mid-stroke and place the cylinder over the top of the piston. Squeeze the rings closed as you gently tap the cylinder downward and over the rings.
Please rate this solution. Thanks garethholleb!
Apr 04, 2009 | Gilera Runner VX 125 Motorcycles
Need to set ringer on phone to ring in my office
is because the ringging assignment only set to ring at receptionist phone.
u may need contact the phone provider to set the ringging assignment to other for other phone which to ring for incoming call
Jan 14, 2009 | Toshiba DKT-2010 Corded Phone
Need to change ring on fax to 3 rings. it is an hp office-jet 6110 all in one
  1. Press Menu .
  2. Press the right arrow (>) or the left arrow (<) until Advanced Fax Setup displays.
  3. Press Enter .
  4. Press the right arrow (>) or the left arrow (<) until Answer Ring Pattern displays.
  5. Press Enter
  6. Press the right arrow (>) or the left arrow (<) until the desired ring pattern displays.
    • Single rings – The fax machine answers after a single ring.
    • Double rings – The fax machine answers after a double ring.
    • Triple rings – The fax machine answers after a triple ring.
    • Double and triple – The fax machine answers after a double and triple ring.
    • All rings – The fax machine answers any ring. This is the default when not using Distinctive Ring.
  7. Press Enter .
May 09, 2008 | Office Equipment & Supplies
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
