Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
I can not control my spa heater on my wall control panel #(7751) but, I can control it manually if I press the button in the main box. Do you think something wrong with my controller?
RS control panel 7751
    Top Expert:
  • Jandy Master
  • 4,262 Answers
See if 4 pin connector is connected or if plug is loose also see if wire is cut
Posted on May 02, 2015
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
  • 246 Answers
SOURCE: We have an AquaLink RS4 All Button control in the
can't be made the only is to cancel the delay on the back dip #4 heater cool down turn off breaker when do this also change assign jva at system setup
Posted on Sep 13, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 990 Answers
SOURCE: the panel back light on myh Aqualink RS All
I don't think so but go through your menu to see if the backlight is enabled. I have never heard of one burning out unless a surge or something fried the whole unit.
Posted on Nov 03, 2009
Testimonial: "To my surprise, it was not enabled, and that was the problem. I don't know how it got disabled, because it has been on for 7 years, but. . .Thanks!"
How do i get my spa out of sleep mode
It would help to know what spa you have, but the most common controls out there are manufactured by Balboa Instruments. If your top-side controls only have four buttons try pressing "temp" or "set" button followed by "light" button. Once there, pressing the "light" button usually cycles through the programming. On some models the "temp" button must be pressed to confirm the selection.
http://www.balboawatergroup.com/Topside-Spa-Panels
Sep 14, 2014 | Pool & Spa
What does "Firmware Rev B 13" n on indoor control panel? Help! Robert
The firmware message is the firmware on the wall mount control. The wall control would seem to be getting power, giving you the firmware rev only. Your communication with the main board has been lost, broken wire, main board has gone bad or for some other reason can not receive and instruction from the main board. If you have a spa side control, if spa side works then board may be ok, look for bad wire. If spa side is not working disconnect and power cycle the system and try the wall mount with spa disconnected. You may only need to replace the main board. More info on your system would be needed in order to suggest the proper replacement.
Sep 04, 2014 | Pool & Spa
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Easy touch control system temperature set at 75 but heater does not change from manual setting
make sure the temp on heater is set at 104. otherwise easy touch panel wont override manual setting from the heater. if you press the mode button on easy touch panel, and it doesn't change, then one of the relays inside the panel is the problem
May 15, 2014 | Pentair Mastertemp Heater
Jandy RS 6 panel not working. After pressing reset button, all lights on panel come on and there is no effect from press panel buttons. panel reads "Rev 6700 C." Have pulled out red 4-wire panel...
check wire going from 4 pin to controller see if by 4 pins wires touching or try controller with short wire by system wire sounds like shorted sometimes cut by landscapers
Mar 30, 2013 | Jandy AquaLink RS2/6 All Button Dual...
My Jandy rs control panel 7751 has gone out?
Yes! Although you the lighting is part of the circuit board, you can order a NEW Circuit Board and install it yourself! Shop around I believe we paid about $375 about a year ago.
The new circuit board should come already pre-wired with a connection plug. Disconnect power to the unit at the breaker. Gently pry off the cover to expose the old circuit board and plug. Gently wiggle the old plug off and attach the new board. I believe there are a couple of screws holding the board in place. The new board should come with instructions as well. If you are at all handy.... save yourself the install fee from the pool tech!
Mar 24, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I have Jandy RS4 system with 4-button poolside controls for additional spa control. Inside house control panel stays totally lit up saying ''Rev 6700'', and cannot communicate or control pool operations. ...
Oct 07, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy aqua link main control box
Do you have a 4 button switch in the spa and is the light on the button that is slightly under water? If so , the button is bad as the water is completing the circuit and turning the light on and off.
Repalce the button or disconnect it at the outdoor panel.
Oct 28, 2008 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
66 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
