Question about Gree 9000 Btu 23 Seer Ductless Mini Split Heat Pump
My aircon is not blowing - Gree 9000 Btu 23 Seer Ductless Mini Split Heat Pump
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Most liekly needs to have freeon added to the system, if that doesn't help its propely a problem with the electric motor on the blower.
Posted on Nov 07, 2012
What does exactly means 'INSP' in the aircon display of GW X240 4WD?
I am not sure something inspection or service,may you have to take to dealer.
Oct 11, 2016 | Cars & Trucks
Air conditioner blows hot air
For this problem, I would like to suggest you take help from any of the reliable servicing and repairing team.
I always prefer aircon service for any problem related to my air conditioner, as they are specialized in air conditioning servicing and repair.
Ranging from simple Aircon servicing to Aircon overhaul, they offer all kinds of services and solutions that you need in order to ensure the maximum efficiency of your unit. Also, they take reasonable charges for their various services.
Jun 27, 2016 | 1998 Lincoln Navigator
What could be causing loud grinding noise when i switch on aircon? Aircon now not working but only makes loud sound.
Sounds like the bearing or part of the clutch in the A/C compressor has failed, or possibly component on a/c fouling on something due to recent repairs however would be unlikely and probably just a coincidence..
Check A/C compressor turns by hand, should be firm but not make any noises.
Check for fouling components related to a/c compressor clutch.
Feb 12, 2016 | Cars & Trucks
01 dodge 2500 v8. Air conditioner started out strong, blowing cold air..temporarily would start blowing warm and then back to ice cold...Noticed when stopping and turning corners a hissing noise coming...
Hi. Have your car aircon evaporator cleaned. Check also the drain hose. All water should go out of the car through the drain hose. There might be something clogging up the hose that is why water will run out the floor and that causes also the aircon to work intermittently.
Have a good one!
Aug 13, 2010 | 2001 Dodge Ram 2500 Truck
E180auto passengerside aircon always blowing cold 1992 model
Sounds like the vent control motor is bad. It controls how much hot water flows through the heater core. OR the heater core for that side is clogged
Feb 03, 2010 | 1991 Mercedes-Benz E-Class
No air blowing from the aircon. though the aircon can be switched on and off.
something is wrong with the fan, it may be jammed with a foriegn object or have a malfunction. kids may have stuck things in it.
Jan 05, 2010 | Midea WP10000 Air Conditioner
Aircon not blowing through dash vents
If it blows thru other vents, your air ducts may have come loose. If you don't get any cool air, your coolant is low (it evaporates during the time and below some point it will not circulate anymore). Also the aircon blower can be faulty.
Dec 03, 2009 | 2005 Hummer H2
I have a Mazda mx6 and the aircon won''t work.
what won't work? the interior fan or is all else well except the cooling part? if the compressor does not come on, then perhaps you need to refill gas. in the very front of the car under the hood, you remove the plastic covers where the hood opener is, and you will see some pipes & a canister. on top of this canister there is a clear small round site glass, you can check there for gas if you have dye, or you can unscrew the cap over the refill nipples and depress with you finger nail, air (gas) should blow out under good pressure, not a little only. there is also a fuse you can check situated in the same place, this is for the compressor
Jul 02, 2009 | 1997 Mazda MX-6
Aircon works but blows hot air
I had the same problem (during Summer!!) - If you take the Fan/A.C/Temp Control panel off, you'll probably find the plastic bracket that the control cable mounts to, is broken. I just used 3 zip-ties to hold everything in place. 30 minutes work, & 50c parts!! No problems since.
Nov 12, 2008 | 2001 Daewoo Nubira
Gree 9000 Btu 23 Seer Ductless Mini Split Heat Pump Logo
134 people viewed this question
Top Gree Heating & Cooling Experts
Steve F
Terry Hair
Lawrence Oravetz
Are you a Gree Heating and Cooling Expert? Answer questions, earn points and help others
