Cars & Trucks Logo
Maher Ghali Posted on Nov 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2010 Touran 1.4 how often change the oil for the gearbox and what type and quantity of oil
Marvin
Level 3:
Top Expert:
  • Volkswagen Master 85,242 Answers
  • Posted on Nov 07, 2012
Marvin
Volkswagen Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29034414
Points
266281
VW 1.4i with manual gearbox 5 speed transmission:
1. Oil type: VW G50 & G51, full synthetic oil SAE 75 W 90
2. Gearbox refill = 1,9 litres
3. Filling plug location: Side of transmission
2 Related Answers
Anonymous
  • 4793 Answers
  • Posted on Jun 21, 2010
SOURCE: 2005 Touran 1.9 TDI manual box. Please can you
ep90/1.1/2 litres.
Testimonial: "That was quick: Thanks very much."
Anonymous
  • 251 Answers
  • Posted on Mar 04, 2010
SOURCE: problem with my vw touran gearbox
dealer to reset trans control module
When I should change the transmission oil
contact your local dealership or look at your owners manul and see the exact time that fluids need to be replaced. since you car is ownly 2 years old the local dealership should be able to get you a printout of the cars maintenance schedule
Oil level in Marzocchi ET85
I tried to find this for you. Try using the terms you gave on a Browser search for that Title. There are all sorts of Blogs and hits ranging from the TRW company buying Marzocchi to both the gearbox and fork oil sumps.
Seems Marzocchi also was into the electric Power Steering on cars as well as Ducati products. On the Blogs, there were people talking about changing the oil in their units. This would perhaps help you find the quantity and type of lube they used. I did see a 2.5W oil mentioned but it did not show the application.
Hope this helps you.
Want to change manual tranny gearbox oil, no serv. manual, 4.2 qrts 80/90 weight sound right?
The type is right , the quantity is ok for an gearbox installed in a small car.
Oil Quantity
all these vehicles with manual gearboxes will be quite happy with EP80 or EP 90 either oil will be sufficient .unless you have a ambassador which is rear wheel drive ,then its EP in the diff unit and engine oil in the gearbox but this is only for the ambassador which is a morris cowley from the 50s in the uk
2answers
Problem with my vw touran gearbox
2helpful
How to change the automatic gearbox oil - Seat - Cordoba - 1996
There will be a plug on the bottom of the transmission casing to let the old gearbox oil out.
On an automatic trans the filler is usually on top at the trans dipstick.
On a manuel trans there is a plug about half way up the trans casing.
Drain fully and put in correct type and amount according to your manual. Do not put any old trans fluid in use the type and quantity recommended by the manufacturer!
I find myself just going to a Quick Lube Shop and letting them do it for a few bucks more.. They get it right and it's faster than me doing it myself.
Hope this will FixYa!
jack
2helpful
2answers
Oil Change Instructions for VW Touareg 2004
I just did an oil change service on my Touran last night (same principal as the Toureg). The Touran has a bleeder (there is a seperate screw type cover under the filter) to release the excess oil in filter (not sure it the Toureg has the same)The aluminum casing around the filter is a bit tough to remove, but turning it anti-clockwise with a little bit of force should do it. Try not to use the special tools that are available to grip the casing as you may dent it. The sump plug can be removed with standard tools. I am still working on the reset option for the 'service now' warning
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
