Question about Sewing Machines
Bobbin thread is showing through on top of fabric
Bobbin thread coming through on top of fabric
  • Sewing Machines Master
  • 1,564 Answers
Loosen your top tension... run a test seam. Loosen some more... test.
Posted on Nov 12, 2012
bargainbox
  • 1388 Answers
SOURCE: bobbin tension
This is an issue of your upper thread tension, so take a look at this generic tension solution
If you are in a pickle with your bobbin case, check top tension and bobbin case are free of lint, reset the top tension to 4, and adjust the bobbin tension to suit......some more detail on how to do that, is here
Bargain Box
Posted on Jan 30, 2008
bargainbox
  • 1388 Answers
SOURCE: Huge loops on back of fabric!
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
bargainbox.com.au
Posted on Aug 02, 2009
RickE1
  • 202 Answers
SOURCE: Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Posted on Feb 11, 2009
SOURCE: The top thread gets caught in the shuttle hook and
I am having same problem
Posted on Sep 27, 2009
  • 11 Answers
SOURCE: needle will not sew thread into material
Sounds like the timing is off. Take the bobbin out of the bobbin case and lower the needle into the needle plate. As the needle starts on the upswing, the hook should meet the needle just above the needle eye on most machines. If it isn't meeting at that point then your hook timing will need to be adjusted.
Posted on Mar 17, 2010
Model number 4562. The bobbin thread bunches up. How do i fix?
Check your stitch sample. Is it the bobbin thread that is making a thread mess, or is it the top thread throwing thread globs under the fabric? Usually, if there is a thread problem under the fabric, it is a top thread issue.
Try this:
Remove the top thread completely from the machine.
Install a brand new needle
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Retest your machine and tweak the tension, as needed. If top thread is showing under the fabric, tighten the top tension. If the bobbin thread is showing on the top of the fabric, loosen the top tension. Tension is correct when the two threads meet in the middle of the fabric.
Feb 26, 2018 | Sewing Machines
The tension on the top is out of sync. Don't know what to adjust. Help
Since we don't have a clear picture of what is happening, we can't offer much in the way of advice. Here is something to try:
Remove the top thread from the machine.
Be sure to install a brand new needle.
ALWAYS RAISE the presser foot and rethread the top thread from the beginning. Verify the thread path is correct.
Remove the bobbin and rethread it into the bobbin case and install it in the machine. Make sure the bobbin is turning the correct direction in the bobbin case.
Set the top tension to the midway point (the factory standard tension).
Retest the machine.
HINT: Thread issues appearing under the fabric are usually a top thread problem. Thread issues appearing on top of the fabric are usually bobbin related.
If bobbin thread is showing on top of the fabric, loosen the top tension.
If problems continue, the bobbin tension may also need to be adjusted. HOWEVER, that is a last resort and a very tricky change to make. Be sure to mark where the tension screw is set BEFORE making any changes to the bobbin tension screw (so you can reverse your changes if it doesn't work).
You can also try changing the type & size of needle and the brand/weight of thread. AVOID old or bargain bin threads. Your needle choice, thread, and fabric should be compatible. Using the wrong needle can cause huge problems with stitching success.
Understanding Thread Tension Threads
Feb 14, 2018 | Sewing Machines
Moved my tension button and not sure what to set it on, sewing polycotton curtains
uually your tension should be set between 4and 5 this is a good tension for most fabric
Dec 27, 2017 | Sewing Machines
I have a Singer Stylist Model #7258.Serial #H10229C25810334. When I'm sewing,the top stitch is perfect but the bottom stitch comes out like backward C's. How does that even happen!????
Check your stitch sample. Is it actually the top thread showing under the fabric, or is it really the bobbin thread. Generally, thread problems under the fabric are an upper thread problem. Thread issues above the fabric is a bobbin issue.
Try a brand new needle.
ALWAYS RAISE the presser foot and rethread.
Remove the bobbin, check that it is wound smoothly, and install and thread the bobbin case making sure the bobbin spins the correct direction.
From that point, there may need to be some tension adjustments required.
If the problem continues, you may need to have it serviced. Perhaps there is a burr or snag somewhere that is interfering with the thread in the thread path.
Oct 21, 2017 | Singer Sewing Machines
I have a brother PR1000 and on the test stitch there is too much bobbin thread showing underneath. do I adjust the tension in the top thread or the bobbin tension?
Yes Adjust to more tight see what it'll do.
Bottom bobby is too tight or upper thread control is too lose.
Good luck
Mai
Jul 12, 2017 | Brother Sewing Machines
Upside down stitching
Am having a difficult time picturing this. Sounds like the upper thread is creating loops under the fabric and the bobbin thread is showing on the top of the fabric.
Make sure to use a brand new needle.
Remove the thread from the machine
ALWAYS raise the presser foot and rethread the upper thread.
Make sure the thread path is correct.
Check that the bobbin is turning the correct direction in the bobbin case and the bobbin thread is threaded through the bobbin tension correctly.
Set the upper tension to the midway point (factory standard), however, this setting may need to be tweaked for your particular machine.
Bring the bobbin to the top of the project Before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Retest--begin sewing slowly.
If the upper thread is still showing on the other side of the fabric, the tension is too loose. If it is pulling the bobbin thread up to the top of the fabric, the upper tension is too tight
OR the bobbin thread tension is too loose. (CAUTION: make only small adjustments to bobbin tension--1/8 of a turn at a time!!! It also helps to mark the screw groove location with magic marker on the bobbin case BEFORE making any changes so you can back it out and return to the original setting.)
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 05, 2016 | Sewing Machines
Top thread covers bobbin thread makes. Stitches very thick
Remove all the thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot during the threading process and rethread the machine from the beginning. (Check that the upper and bobbin threads are threaded correctly in your machine.)
Set the tension dial to the midway point. This is a factory standard setting but each machine may vary.
Test your machine. The ideal tension is when the upper and bobbin threads meet in the middle of the fabric. If the upper thread is showing on the bobbin side of the fabric, the upper tension is too loose. However, if the bobbin thread is showing on the top of the fabric, the upper tension is too tight.
Tension is not static--whenever you change projects, ie fabric, thread, needle, you may need to test the tension on some scrap project fabric first. Get the tension adjusted before stitching the project.
Make sure you clean and lubricate your machine regularly to keep it operating--consult your owner's manual and use only good quality sewing machine oil (NO 3-in-1, cooking oil, WD-40, or old brown stinky sewing machine oil).
If you are still having issues, take it for service.
May 27, 2016 | Sewing Machines
Bobbin thread shows on embroidery pattern
The bobbin thread is being pulled too hard by the top thread. The idea is to get an even pull similar to a tug of war. When it is even the thread will form a knot in the middle of the fabric.
To fix this so the top thread isn't pulling too hard lower the tension of the top thread. This should fix it.
May 08, 2015 | Janome Memory Craft 10000
Adjust tension
The tension of the top thread and bobbin thread are in a "tug of war". If the top is "winning" or too high then the bottom thread will be showing on the top of the fabric. If the top is "loosing" or too loose then the top thread will be pulled through the fabric and show a lot on the bottom. They must be evened out so the "tug of war" is even so the knot is in the middle of the fabric.
START WITH BOBBIN FIRST: Remove bobbin and bob from finger. When you have it adjusted right then the bobbin will extend one inch when you bob it. If you can't bob your bobbin you will have to make an approximate and replace. You may have to do this a couple times to get it right.
WHEN IT'S RIGHT: The bobbin and top tension are equal without being too much pull on both that causes the fabric to pull together.
Jan 31, 2015 | Sewing Machines
Brother pe770 bobbin thread is showing on top of fabric.
First check threading. If it is done properly, then it's probably because it is dirty between the lower tension blade and the bobbin case body. Remove this blade, clean, reassemble and it shoud work.
Dec 26, 2011 | Brother PE770 Computerized Sewing Machine
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
