Question about Nokia 1800
My phone is not applied simcard - Nokia 1800
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Either reset phone to factory settings or go to service provider and switch sim card
Posted on Nov 07, 2012
LG GX200 SIM 2 INVALID
Try removing the Simcard and reloading it again.Try switching the Simcards[Simcard 1 into Simcard 2 slot and vice versa] i.e to establish if its the Simcard or the phone with a problem.Also,check the Simcard reaction on another phone.If its the Simcard,contact your service provider for further instructions on re-activation.
Hope this helps.Thanks!
Jan 09, 2012 | Cell Phones
"sim card registration failed" will
is this happens to other sim you inserted on your phone...if still occurs it seems you have a loose simcard socket..or the copper contact itself miss a connection...
try to clean your sim esp. the copper surface also do the same in the simcard slot..
put your sim and gently apply force or put a ply of paper on top of the sim and close the phone cover. turn ON your phone and check if the sim already register....nice day
Feb 12, 2011 | Computers & Internet
My motorola L7 is not reading the sim card. I have had this for a long time with not problems. Can anyone help solve
should be dirt deposited over the sim card or the simcard slot. try cleaning with white petrol or unleaded petrol.
also try with other simcards.
if you have white petrol, use a ink puller and just apply 3 to 4 drops of it over the sim slot and dry it for 15 to 20 minutes. do this twice or thrice, this might work if dirt is sedimented over the slot
Jan 11, 2011 | Motorola Mobility L6 Cellular Phone
When i open my phone it always says that insert sim even if there is a sim
remove your simcard from phone then try to clean your phone simcard compartment and simcard with white soft cloth,put your simcard back into phone,and always protect your phone from dust replace your phone casing or other parts if its broke
Aug 29, 2010 | Nokia 1110 Cellular Phone
My nokia 1600 phones problems Insert SIM
1st, try to clean pin of simcard, you cau use eraser, or maybe simcard ic problem. If you set drop it before, by using soldering iron, Solder with a lot at the end of the soldering iron tip, place on the surface of the ic, the process must be done carefully. never press the soldering tip, leave a lot of Solder is the press. but remember, you need to apply some sim Solder flux in the IC. If the problem is still not finished, then you need to change sim ic new.
Jul 27, 2010 | Nokia 1600 Cellular Phone
My 1600 is insert sim card problemi changed the charger connector.but no resp
Jun 27, 2010 | Nokia 1600 Cellular Phone
My N73 is always restarted, it happens when the simcard inserted, without simcard inside it works normally, what shpuld i do? thank's for the answers.
apply this code on your cell phone.
*#7370#.after applying this code your phone will go on formatted mode.it will take several minutes. if your problem presists on your phone than contact your nearest and well known good software provider.
Jul 21, 2009 | Nokia N73 Cellular Phone
Sony Ericsson K800i Swithces on and off when sim card is inserted
is it globe simcard???it an starter sim,pls replace another sim.if not reprogram may applied..
Jun 30, 2009 | Sony Ericsson K800i Cellular Phone
Start up phone without simcard
Try, carefully, to remove and reinsert the simcard. The points someitmes get a little worn or dirty and need to be moved a bit.
Feb 16, 2009 | Nokia 6085 Cellular Phone
GPRS active
I assume you are using a pre paid sim card. It would be better to call the customer care of your service provider(voda phone) and then you have to apply for their gprs tariffs.
Feb 23, 2008 | Nokia 6681 Cellular Phone
Nokia 1800 Logo
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
