Question about Whirlpool AWM6100 Front Load Washer
The cycle does not complete and seems to end during the washing phase with the door light flashing.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Check for blockage at the pump.
Posted on Nov 07, 2012
futureloginn
  • 734 Answers
SOURCE: Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Dec 10, 2008
    jsrock516
    • 5911 Answers
    SOURCE: error messages during cycles
    To all that have posted under this request: You should always try to reset the Central Control Unit (CCU) before assuming you have a component failure on these front load washing machines. In many cases these error codes can be erroneous and resetting the CCU will correct the problem. To reset the CCU, the washer must remain unplugged for AT LEAST 30 minutes. This is verbatim from the manufacturers technical data sheet. If the error code reappears, then more than likely, you have a legitimate component malfunction.
    "Fdl" is usually caused by a door latch failure (but in some circumstances be caused by a failed CCU). If the door latch fails to lock, the washer will not complete the cycle.
    "F02" is usually caused by obstructions in the drain pump causing a slow drain. You must clean out the drain pump reservoir and check the impeller for debris.
    NOTE: The later models of Maytag are manufactured by Whirlpool, using Whirlpool parts and electronics. The error codes and method of correcting them are the same.
    I explain all these error codes under the "Tips and Tricks" section of my profile. If you cannot find what you are looking for there, please use the "Ask Me" feature and I will do my best to provide you with a solution.
    Posted on Feb 14, 2009
    • 56 Answers
    SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
    I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
    Posted on Feb 11, 2010
    blueextc3221
    • 15935 Answers
    SOURCE: Washing machine displays an LF error code.
    LF = Long Fill
    LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
    Is water supply connected and turned on?
    Are hose screens plugged?
    Is water entering the tub? If so check pressure hose connection to machine/motor control.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Posted on Sep 07, 2010
    Testimonial: "We followed your suggestion and disconnected the hoses and they had "gunk" in them. We flushed them out, reconnected and everything seems to be fine."
    blueextc3221
    • 15935 Answers
    SOURCE: Error Code F8E1 on Whirlpool Duet
    f8 is shown when the heater circuit is on with no water in.. it doesnt do it when you unplug the pressure switch because your disabling the heat protect circuit
    THE BOARD IS PROBABLY FAULTY
    F08 indicates pressure switch stuck on full.
    Unplug the appliance from the wall socket.
    Take the top off the machine.
    Locate the pressure switch, you can identify it by the thin tube attached to it.
    Take the tube off, blow down this tube as hard as you can to shift any blockage or restriction in the pressure chamber. Give the pressure switch a couple of good taps with the screwdriver handle.
    Refit the tube and try the machine again.
    If still doing it, unplug again and follow the tube down.
    This end will be attached to the pressure chamber.
    Take this chamber off and thoroughly clean it out, clean out the port into the tub too.
    Reassemble and try again.
    If after this it's still faulty you'll need to start replacing parts.
    I'd suggest trying a new pressure switch first.
    Failing this, if all of the above fails to resolve the problem you're possibly looking at a faulty main control board.
    Posted on Sep 21, 2010
    Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
    Could be anything!
    If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
    Example from user manual: Anti-flood device is activated.
    - continuous flashing of the indicator light of the running programme
    - 3 intermittent audible signals
    - 3 flashes of the END OF CYCLE indicator light
    (which means "i30" fault code, the cycle is interrupted and the
    drain pump switches on).
    Possible causes:
    Water leakage from the tub - sump and various connections
    (pump, upper spray arm duct etc.); floating sensor blocked
    mechanically; microswitch faulty; fill solenoid blocked
    mechanically; circuit board faulty (solenoid triac short-circuited);
    wiring faulty.
    26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
    To cancel a washing programme in progress:
    - Open the dishwasher's door.
    - Press the programme selection/cancel button for about 3 seconds,
    until the indicator light of the running programme turns off and the
    END OF CYCLE indicator light flashes, indicating that the running
    programme has been cancelled and that the machine has
    returned to setting mode. It is now possible to select another
    washing programme. If a new washing programme will be
    selected, check that there is detergent in the detergent dispenser.
    NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
    On/Off button and remains switched off for more then 30 seconds.
    Dado
    Jun 26, 2016 | Zanussi Dishwashers
    Only Power and door light comes on - no wash cycle selection
    To start the door sensor is faulty, in any case you have more than one problem. which is make and model?
    Mar 02, 2008 | Washing Machines
    Hotpoint Ultima WF860T
    Alarm
    code Description of fault User
    code Effect
    E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
    E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
    E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
    E22 Problems with water drain during drying or drying
    condenser blocked E20 Heating phase skipped 8.5
    E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
    with door closed 8.6
    E32 Incorrect calibration of analogic (electronic) pressure
    switch --- Cycle PAUSED 8.7
    E33
    Incongruency between level of analogic (electronic)
    pressure switch and level of anti-boiling pressure
    switch 1
    --- Cycle blocked
    with door closed 8.8
    E34 Incongruency between level of electronic pressure
    switch and level of anti-boiling pressure switch 2 --- Cycle blocked
    with door closed 8.9
    E35 Water level too high --- Cycle blocked with door
    closed and water drain 8.10
    E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
    with door closed 8.11
    E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
    E38 Pressure chamber blocked --- Heating phase skipped 8.12
    E41 Door open E40 Cycle PAUSED 8.13-14
    E42 Problems with door closure E40 Cycle PAUSED 8.15-16
    E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
    E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
    E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
    with door closed 8.19
    E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
    closed (after 5 attempts) 8.20
    E52 No signal from tachometric generator --- Cycle blocked with door
    closed (after 5 attempts) 8.21-22
    E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
    with door closed 8.23
    E54 Relays (motor) contacts faulty --- Cycle blocked with door
    closed (after 5 attempts) 8.23
    E61 Insufficient heating during washing --- Heating phase skipped 8.24
    E62 Overheating during washing --- Drain, end of cycle 8.25
    E63 Insufficient heating during drying Heating phase skipped 8.26
    E64 Overheating during drying --- Heating phase skipped 8.27
    E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
    E71 NTC wash sensor faulty --- Heating phase skipped 8.29
    E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
    E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
    E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
    (door open) 8.32
    E85 Circulation pump faulty --- Drain, end of cycle
    (door open) 8.33
    E91 Communications error between main PCB and user
    interface --- --- 8.34
    E93 Configuration error E90 Cycle blocked 8.34
    E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
    EF1 Drain filter blocked LED-EF0 --- 8.35
    EF2 Excessive detergent LED-EF0 --- 8.35
    Regards David Marsh
    Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
    I have a Maytag Bravos top loader washer and it seems to agitate during the washing phase but when it comes to the spin cycle the water drains but the clothes are still soaked at the end of the cycle, as...
    This happens to me to. It is because it believes it has gone out of balance and has stopped and gone ahead and timed out making you think it has completed it's cycle. I do not have a solution to this other that I am thinking of chucking this washing machine out the door and buying an older machine.
    Nov 20, 2012 | Washing Machines
    I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
    I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
    Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
    Machine keeps stopping and showing fo5
    ALARM CODES
    E33
    switch 1
    --- Cycle blocked
    (door open) 8.32
    (door open) 8.33
    Regards David Marsh
    Oct 22, 2009 | Washing Machines
    We have a WGL 10 US model F&P washer. Most
    Are you waiting long enough? Ours seemed to stall but eventually would start up again. Have you tried diagnostic mode? email me at Yahoo.
    Sep 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
    Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
    Hello
    ALARM CODES
    E33
    switch 1
    --- Cycle blocked
    (door open) 8.32
    (door open) 8.33
    Regards David Marsh
    Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
    Error codes
    Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
    May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
    My tricity bendix washing machine flashing and beeping end light
    Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
    Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
    Whirlpool AWM6100 Front Load Washer Logo
    19 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
