Question about Dayton Gas Furnace Heater
Where is the limit switch located? - Dayton Gas Furnace Heater
  • 91 Answers
Should be around blower housing....
Posted on Nov 07, 2012
Can Rate Limiting Be Configured for an Eth-Trunk on a Modular Switch and How Can the Configuration Take Effect?
The modular switches(such as S2309TP-EI-AC) support rate limiting for inbound traffic on an Eth-Trunk. This function can be configured using the qos car command. After this command is executed:
· If the member interfaces of the Eth-Trunk are located on different LPUs, the configured rate limit applies to each interface individually.
· If the member interfaces of the Eth-Trunk are located on the same LPU, the member interfaces share the bandwidth specified by the rate limit. The bandwidth is distributed on the member interfaces randomly.
Jul 25, 2016 | Office Equipment & Supplies
THE HIGH TEMP.LIMIT SWITCH IS OPEN NEED LOCATION
The high temp switch connects to your power board at "Limit In" and "Limit Out". Follow those wires to the switch. I would see if you're under the Norcold recall. Give them a call and check. If you're not, here is where you can get an upgraded thermal switch:
Norcold High Temperature Limit Switch V2 0 by ARPrv
Apr 24, 2016 | Norcold Inc Norcold 1210IM Refrigerator
Where is limit switch reset located
The limit switch is located in the front of the fryer. Depending on the model it can be on the left side or right. There are two types, manual reset and automatic. If you have a manual reset limit, you will see a little red button sticking out.
Jul 10, 2014 | Imperial Kitchen Appliances - Others
Jandy lx400n l
high limits are both on the side of the inlet/outlet water connections
Aug 25, 2013 | Pool & Spa
Furnace blower runs continuously but no heat
sounds like the furnace control (low voltage) circuit is open, or in other words you either have a fuse blown or a limit switch that needs to be reset. Most newer furnaces have a small knife like fuse, usually 3 or 5 amp located directly on the circuit board. Limit switches that have a manual reset are usually located in the fire box just above the burner. There may even be a limit switch located on the blower assembly. If you fuse was blown, you may need to find out what caused the short in the circuit or it will do it again. If the limit switch was tripped, you need to turn the furnace back on and watch the flame to see if there is "roll out". It it continues to trip or blow fuses you need to have the unit serviced.
Apr 10, 2011 | Dayton Gas Furnace Heater
The blower on my Dayton furnace runs but there is no flame/ignition. Just blows unheated air. It continues to run regardless of whether the thermostat is calling for heat or not. Anyone have any ideas?
When the blower motor run all the time, that mean you have a safety limit tripped. One of the limit is located on top of the burner, to reset that all you have to do is press down on a little tap that sticking up in the middle of the switch. The second switch is located at the flute pipe, to reset the switch is the same procedure. The third limit switch is located on the heat exchanger box itself, this one cannot be reset, you will need an ohm meter to check for contunuity. Set meter to ohm function, if the meter read nothing then the switch is bad. Good luck.
Feb 02, 2011 | Dayton Gas Furnace Heater
Where is the high limit switch. led is flashing 4 times telling me to open the high limit switch.
There may be a couple of them. One is located over the burner and will have two wires going to it. It is usually located inside the furnace box and covered with a plate with two screws. The wiring diagram will give you the color of the wires to help locate. The other may be located on the burner and looks like a small stack of quarters with two tabs at the 9 and 3 positions. It will also have two wires going to it and may have a small reset located between the two wires. Push in on the dark red tab to reset. Check your air filter, it is the main cause for high limit to fail.
Jan 23, 2011 | Fedders F80A0703 Heater
Oven wont bake....everything else works??? Mod # KGRT607HBT4
It is either a high temperature limit switch which is located on the rear of the appliance under the steel panel or the actual bake element itself. You need a volt meter. Disconnect eletrical power and check continuity on your limit switches with the wires disconnected. If there is no continuity the limit switch is bad. The element should have continuity or a specific resistance that you would need to locate in your technical literature for this appliance.
Nov 04, 2010 | KitchenAid KEBC107 Electric Single Oven
Where is the hi temp limit switch located?
where is the high temp limit switch located on my laars 44000 pool heater
Jun 02, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Dryer won't heat
Limit switch is locate inside the unit near the element housing.(High Limit thermostat)
Jun 15, 2009 | Kenmore 63942 Dryer
Dayton Gas Furnace Heater Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
