Question about Dell Vostro 1700 Notebook
About the blue tooth drivers
Hi, its yatin here..i have a bluetooth device..voastr 1000 dont have inbuilt bluetooth....i want to know of the all available drivers for vostro 1000 on dells website, which of them is for bluetooth?
  • Dan rogers
    Dan rogers May 11, 2010
    if you do not have on-board blue tooth why do you need the drivers for it?
  • 871 Answers
You need to find it yourself cuz the website requires you to specify which and what your product is...
here is the link...
Posted on Jan 05, 2009
I can t f ound my bluetooth device in my acer aspire one d 250 netbook
you need to buy a USB blue tooth for the computer but the computer has the driver progrm for blue tooththen activate it they dont codt much and are called bluetooth dongles
Dec 26, 2011 | Acer Aspire Computers & Internet
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Js bought an hp dv 7 dont if it has a blue tooth cant locate it
installl bluetooth drivers or check device manager in properties of my computer any unknown device or yellow clour device is present.. download and install drivers
Dec 14, 2010 | HP Pavilion dv7-1132nr Notebook PC
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
Hi is there anyone can tell me how can i turn on the bluetooth on msi cr500 laptop please
Step by step guide
Check in bios if blue-tooth is on,
check if the blue-tooth led light is displayed
Check in device manager if the blue-tooth shows up if not install drivers
continue with pairing
Dont forget to say Thanks!
Aug 09, 2010 | Computers & Internet
I cant connect using blue tooth
Start your bluetooth on PC and then in your HTC......I hope u have bluetooth software in your laptop......if not install it....try to search devices in ur laptop dont forget to keep ur HTC in visible mode. when ur laptop identifies the devices try connecting it.....best way that ur laptop gives a key n type the key on ur htc it will connect.....n u can strt data transfers easily......hope this helps......
Mar 11, 2010 | HTC Computers & Internet
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
Bluetooth
If you have a bluetooth button at the front it doesnt mean its inbuilt, most Acer laptops don't have it although the button is there.
assuming you have set up the bluetooth correctly
Your model does list it has inbuilt but, if it is the light should flicker, you should also check the latest driver
http://support.acer-euro.com/drivers/notebook/as_5100.html
Aug 28, 2008 | Acer Aspire 5100 Notebook
Bluetooth
need to first reemove device uninstall it shut down pc if it is vista or xp go to controll panel reinstall at device manger and then as it picks it up insert capti.disc driver for blue tooth device ..it shopuld reconize it if not email me at loney2linda@yahoo.com
Jun 02, 2008 | Acer Computers & Internet
Blue tooth device is not working
hi,
check if your device is enabled, you can do this by ---
right click my computer..-> properties--> hardware tab--> device manager --> right click on the blue tooth icon and clcik properties. --> check if enabled..
if it is enabled check if bluetooth is enabled at startup { type msconfig in RUN in start menu, click startup tab..check if it is enbaled in startup}... or else you have to manually switch on bluetooth each time u intend to use... hope it helps.
hope to get rated as helpful...
regards
bzoy
Dec 31, 2007 | Computers & Internet
Dell Vostro 1700 Notebook Logo
129 people viewed this question
Alun Cox
