Question about Kwikset Professional Door Lock installation Kit
New deadbolt mechanism very hard to turn.
I am afraid of it breaking the key if I try too hard.
    Novelist:
  • 148 Answers
The deadbolt itself is binding in the door or the door jamb
you will ned to take the pressure ofF the turning mechanism by either readjusting the strike plate(area where deadbolt goes into door jamb(wall side) OR MECHANISM IN THE DOOR
FIX
First determine if the problem in the door or when the door is closed and is binding into the wall side
FIX FOR BIND WHEN DOOR IS IN CLOSED POSITION
If it binds only when door is closed you will need to adjust the strike plate up or down at the door jamb which is easy to fix
1 open door and turn lock in locked position close door up against the door jamb and mark with a pencil where bolt hits jamb
2 open door extend the marks to see where it lines up in relation to the strike plate remove strike plate and move so that the opening of strike plate is between two pencil lines
3 insert some wooden match sticks in old scres holes( jamb them in with head of hammer
4 screw strike plate in positon
5 close door and check lock
Note:
You may have to use a chisel , flat bladed screw driver or kinife to cut some of th soe out to allow bolt to slide into jamb (if it bareley drags you can take a metal file and file it also pt some wd 40 on bolt
FIX FOR PROBLEM WITH MOVEMENT IN DOOR
open the door from the inside turn the bolt in lock and unlock position if it moves hard you will need to take a phillips head screw driver and remove the plate that covers the bolt( on the side of the door where bolt slides out of door)
After you remove the plate turn the lock in lock/ unlock position
if it is still tight loosten the two screws at the deadbolt from the inside of the door do not remove completely
bolt should not be in a bind and should move freely
If it is tight at this point you wil ned to remove the assembly(continue taking 2 screws out) once you have the assembly out you will need to pull the bolt ot of the side of the door
if the dead bolt is real tight you will need to enlarge the hole it goes in by using a round rasp or file
and check the ock manually and with a key
Good luck
Posted on Jan 05, 2009
Gtrano,
Look at a new product on the market called the Sure-Strike. It should solve your problem.
w
Posted on May 13, 2009
I just installed a Schlage deadbolt. If I lock it from the outside (using the key) it locks fine, but I can't remove the key without unlocking it. Now What?
Hi Winston:
Is it possible to try this:
- pull the lock from the door while leaving the deadbolt in place
- turn the mechanism 180 degrees.
- re-install and give it a try.
Let me know how you progress.
Jun 21, 2015 | Schlage Locks & Locksmithing
Why won't my schlage deadbolt key go to the neutral spot in the lock position to remove the key?
You likely have the lever that goes from the outside portion of the lock through the striker/bolt assembly into the inside portion rotated into an incorrect position when you insert it into the striker/bolt assembly.
Sep 18, 2014 | Locks & Locksmithing
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
Key will not come out in unlocked position
I presume you figured it out by now, but if the tailpiece is installed wrong in many deadbolts, the key won't come out in one position or the other. It's called a "timing" problem and the way to fix it is to take it off the door, turn the tailpiece a half circle and put it back on the door. Usually Kwikset locks are designed so you can't put it in the wrong way, but it can happen. (If it's not the timing problem, then the deadbolt unit is defective or broken. They are designed to fail in a way that keeps them locked, so this could be a sign that someone tried to break in, or that someone used the extended bolt as a way to stop the door from closing and it hit the door frame too hard.)
The best way to install a deadbolt lock without the instructions handy is to look at the "lazy" cam and see if there is a way to install it wrong and don't install it that way. Example: If there are 2 ways for the tailpiece to fit in the deadbolt unit when the deadbolt is retracted and only one way for the tailpiece to fit in when the deadbolt is extended, then install the lock with the deadbolt extended and you can't install it wrong.
Jan 05, 2014 | Kwikset Locks & Locksmithing
Double cylinder deadbolt, bolt stuck in jam
You will have to remove cylinders from both sides of door, then stick a phillips screwdriver thru the bolt and push the screwdriver toward the hinge edge of the door.Might take a bit of pressure, depending on how hard its wedged into the jam, and you might break the bolt, but thats about the only way to get it out.try to determine why it got stuck before installing new one.
Oct 22, 2012 | Schlage Deadbolt. Double Cylinder Deadbolt...
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Deadbolt wont unlock
Remove the deadbolt cover by removing the 2 screws. This will get you inside the deadbolt. Try using a screwdriver to pull it back. You may in the end have to break the unit in order to get it out and replace it. I have the same thing happen with a deadbolt. I ended up having to destroy the unit to get it out. You are going to replace it anyway so do whatever it takes to get it to unlock so you can then remove it from the door and install a new one. You do not want a deadbolt that will not unlock.
Jan 09, 2010 | Kwikset Brz Sgl Cyl Deadbolt
Key will not turn to start car.
HI, the ignition switch mechanism is faulty at this point. this will cause the switch mech to become jammed at times. this will also cause you to snap your master key as well. the best action will be to replace the ignition switch mechanism. The lock latch is malfunctioning.(not able to disengage properly)
Jul 08, 2009 | 2001 Saturn S-Series
New schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
Jun 24, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Kwikset Professional Door Lock installation Kit Logo
4,396 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
