Question about Acer Aspire One D257 Netbook
Audio service refuses to start
After installing a hard drive I had from another laptop,, I can't get the "audio service" to start. The little speaker icon on the taskbar had a red X thru it I started the service and all the dependencies (services.msc) .. to no avail. The device manager says the 'device is working properly' but there's no sound.. any ideas?
  • 1 more comment
  • Robin Jordan
    Robin Jordan Nov 08, 2012
    um... no, didn't format anything. I just grabbed an old HD from my pieces and parts drawer and stuck it in the Acer. I know, I know.. probably not the smartest move but after manually installing some devices into the new-ish, but very confused harddrive, ( I guess because it thought it was still in a HP system) everything was going okay until the audio device. However, after a few hours of fiddling with settings (and coming pretty close to drop kicking the acer out the back door), I solved the problem. There is a service called POWER that needed to be enabled. Never saw it mentioned in a list of dependencies or anywhere else for that matter. I just happened upon it when I was making my way down the list of services. Thanls for your reply
  • max carson
    max carson Nov 08, 2012
    I have a POND in the back of my house that full of PROBLEM computers! Nerer tried a DROP KICK! ;)
  • Robin Jordan
    Robin Jordan Nov 11, 2012
    problem solved
    Windows7 has a service (services.msc) called POWER that needed to be enabled. Never saw it mentioned in a list of dependencies or anywhere else for that matter. I just happened upon it when I was making my way down the list of services. Thanks for your replies
  • Acer Master
  • 7,627 Answers
The obvious, is it muted? NO. Disable device in Device Manager, enable device, no change, uninstall audio device, reboot, I don't know your OS, your OS should automaticly ID the audio an add driver. If it does not go to Acer website a download audio driver for your OS. Install manually. You stated,"after installing a hard drive I had from another laptop" . The Harddrive you installed, did you format it and install into this laptop and clone the drive? I am a bit confused by the statment, "after installing a hard drive I had from another laptop"?
Posted on Nov 07, 2012
chinmay_lp
  • 271 Answers
SOURCE: speaker showing No Audio Output device is installed
Try to uninstalled the audio driver.then restart the machine and again install the audio driver.hope this will work for you.
Thanks
Posted on Feb 28, 2009
rockitman187
  • 2559 Answers
SOURCE: no audio device in my laptop
Go here and pick yours.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=500746&prodTypeId=321957&prodSeriesId=432985&swLang=8&taskId=135&swEnvOID=1098#113165
Please rate this solution.
Posted on Jan 16, 2009
  • 73 Answers
SOURCE: Laptop won't boot.
If it used to start up OK, then the hard drive is probably broken and needs to be replaced.
If you're adding a new hard drive, it may need to be partitioned and formatted. Insert your Windows CD, and start up off that, and run the Windows setup. It will format and partition the drive for you.
Posted on Feb 08, 2009
ITTech7574
  • 85 Answers
SOURCE: internal speaker only beeps no real sound will come out.
just install the audio driver on your driver disk that comes with your laptop...Hope this works! ITTech7574
Posted on Aug 28, 2009
nonontech
  • 4737 Answers
SOURCE: I have been having trouble
Click on this link (Click Here) and download and installed the program available on the page i.e. Handy Uninstaller, and run the program, look for installed Realtek through the program (you'll be able to do that) and uninstall them. If it's not possible, remove them from the lists. Now open My Computer, then C:, and All Programs and delete the "Realtek" folder. Restart your computer and try again.
But there's something I don't see on any of the posts, is Microsoft UAA bus driver installed or not?
Please update.
Thanks and Good luck.
Regards
Posted on Nov 01, 2010
I'm trying to increase hard disk space on a Dell
Hi.
The Dell Inspiron 1100 is a laptop whereas the Dell Dimension 2400 is a desktop pc.
The hard drives are incompatible because they are a different size, plus the Inspiron only supports one hard drive so you can't install a slave device. The only way to increase hard disk space is to buy a large capacity internal IDE laptop drive or an external hard drive.
Regards.
Jan 01, 2013 | Computers & Internet
Many errors after installing a new HDD on samsung R480 laptop
HI , there ,
Did you back up your data ? if so just recconect your old hard drive if you didnt format it and run windows go to my computer right click and click properties scroll down the the bottom and you should be able to see your product key jot that down and reconnect your new hard drive install windows and enter the product key.
as for the windows updates look up the error messages , you might have to copy the folder and delete the old oneas sometimes the donwload folderr gets corrupt.
Hope this helps .
Dec 29, 2012 | Samsung R480 Notebook
Disk read error
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 26, 2012 | eMachines Computers & Internet
HP Garden Dreams Pavilion dv5-2129wm problem.
You killed the hard drive. It needs to be replaced and you'll need a new operating system to go with it.
Sep 02, 2012 | HP Pavilion dv5020us Notebook
My dell leptop refus starting i got message : Primary hard disk drive not found , CDBOOT ; Memory overflow error
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 16, 2012 | Dell Latitude C800 Notebook
Hello, i have sony vaio VPCEB46FG laptop & i have
You're getting what's known as the 'blue screen of death' as some may call it.
This happens for various reasons, but usually occurs when Windows encounters a conflict with a hardware component in your laptop. When you try to install XP, are you doing so as a secondary operating system (dual OS boot) or are you trying to install it over Windows 7?
If you are installing XP over Windows 7, try doing a full format during setup instead of the usual quick setup. This may take some time, possibly requiring you to format the hard drive overnight but it may well solve any 'blue screen' issues you're experiencing.
Let me know if I can assist any further.
Best wishes,
Graemevm
May 31, 2011 | Sony Computers & Internet
Every time i start a game or a program doesn't react my medion akoya laptop give a bluescreen and start again... realy stupid... anyone knows how it comes and how i can fix it??
sounds like your hard drive is about to crash . you may not have enough memory installed in laptop or your hard drive might be pretty loaded
May 28, 2011 | Computers & Internet
I received a toshiba update. I did a diagnostic check. It states hard drive fail. Sometimes my laptop fans make a noice. What can I do?
For starters you need to start backing up everything you want to keep. Photos, music, files, passwords, etc... Saving it all to an external hard drive is the simplest way to do this especially if you have a lot of stuff. You can also use thumb drives or burn it to DVD's if you want. Your computer is telling you that it's about to **** out on you. Once you get all your files backed up, you'll need a new (internal) hard drive for the computer. Once it's in, pop in your Windows install disc & follow the prompts. Keep in mind that you'll need to put in the windows disc before you shut the computer off to change the hard drive, this way after you've installed the hard drive and start back up, the windows installer will run.
May 27, 2011 | Toshiba Satellite L655-S5101 Laptop
Acer Aspire One D257 Netbook Logo
230 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
