Question about Dell PowerEdge 1600 ( pe1600sc/118/np ) Server
Dell power edge1600 SATA disk failure
Dear sir.,
i have Dell Power Edge 1600 server with 3 SATA hard disk but one drive is now fail that time server is working when after that i try to fix the problem but now serer is not working what can i do recover the server pls. help to me as soon as possible
thanking you
Sujith
    Genius:
  • 1,913 Answers
Hi sujeeth sir h r u?
Posted on Jan 05, 2009
  • kishor khatri
    kishor khatri Jan 05, 2009
    check in bios that sat is enabled.also reconnect all cables.
    sta harddisk detected in bios?
I have a Dell Power Edge 2950 running on Ubuntu. Is there any program that i can run to check my hardware because i had a Error message E1810 HDD disk failure. i remove the disk and put it back on but i...
You may have a damaged hard drive and it needs to be replaced. If the system is still under warranty, Dell will replace the drive free, you just need to go online, supply your systems tag number and follow the instructions from there. If you have just the one drive, you will need to restore the information froma a backup. If you have a RAID set up, once the hard drive is reinstalled, the RAID will sync the drive to the others.
Good Luck
C2Solutions
Oct 14, 2011 | Dell PowerEdge 2950 (becwfk1_6) Server
My laptop do not detect my hard(mk3265GSX) laptop is Dell inspiron 1600
Ensure that the hard disk is a working one and properly fix into your DELL laptop.
Best regards.
Jul 18, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
NO HARD DISK FOUND DELL POWER EDGE 2950
Your probably got one ofthe following:
1. har drive crash
2. Hdd controller failure
Ether witch will need replacment parts and that you would see a local tech for if you do not know what your doing. You might need a new hard drive or acontroller in this case.
Thanks and please do be considerate and leave postive feedback ratings.
Jun 07, 2010 | Dell PowerEdge 1600SC Server
How to install sata hard drive on dell power edge
You have to "FDisk" or "Partition" the Drive before Windows will see it.
XP - Goto: Control Panel | Administrative Tools | Computer Management | Disk Management
Vista/Win7 - Goto: Control Panel | System and Security | Administrative Tools | Computer Management | Disk Management
You will see hopefully both Drives... Highlight the New One... Create a New Partion by Right Clicking or use the Pull Downs. It will ask size etc... use the defaults.
Next Format the Drive - Select the Drive again...Right Click Format using Quick Format to save time and you should be set.
Jan 02, 2010 | Dell PowerEdge 1600...
Windows - Delayed Write Failed
This points out to a problem with one of your hard drives. Run CHKDSK on all drives you have, & if any problems are detected on any drive, run CHKDSK /F on that drive.
Apr 04, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Feb 26, 2009 | Dell PowerEdge 1800 Server
Dell power edge 1600 server
Is this hard drive in a RAID set? if it is, you will need to replace it with the exact same drive. After you do that, you will need to go into the RAID controller bios and initiate a rebuild.
Jan 10, 2009 | Dell PowerEdge 1600...
Hello sir, I got Power Edge 2600 used not new from a friend, It works fine but its hard drive is damaged. so I was wondering if i can install SATA drives with 7200 rpm to the system? and if so, will it...
This system does not support SATA, personally I would get a 10000 or 15000 rpm SCSI drive.
If really want to use SATA, you can get a SATA controller that plugs into one of the PCI slots. You can probably pick up one for under $50.
Jan 03, 2009 | Dell PowerEdge 2600 Server
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Aug 18, 2008 | Dell PowerEdge 1300 Server
Dell PowerEdge 1600 ( pe1600sc/118/np ) Server Logo
239 people viewed this question
Alun Cox
